what ecu for b20
Re: what ecu for b20
apearently the P75 ecu is a little rich for the B18b so its only a touch lean on the B20. I wouldn't risk it though a chip kit with basemap from an online retailer is less than 50$ and if its a mostly stock motor they can probably get the basemap closer than the P75 would be stock.
if your obd-0 use a pr4, if you are obd-1 use a pr4 or p75 whatever comes easiest to you. if you are getting a p28 cheap get it save it till you go vtec or sell it/trade it for said ecus with money on their side. treat it like a bored over b18a/b your splitting hairs otherwise
cmon now people, this aint' that complicated. Get the P28 chipped and have a B20 bin loaded. 72 bucks through xenocron and your done.
that way you have the P28 if you ever have the need for the vtec capability, but it'll operate a b20 just fine with the right bin loaded.
back from the dead lol didn't wanna start another thread
friend is gonna run a stock b20 shorty replacing his LS block..
should he run a p28 with a B20 pin, or p75??
or just use the LS ecu with some sort of FPR??
I'm having the same issue, B20b running a PR4, it takes forever for my check engine light to turn off and allow the fuel pump to prime, at first I thought it was my PGMFI relay but I plugged in an old D15 ECU and it cranks instantly, just runs like ****
Hey there I’m still new to the car world. Bu I yeah So I have a 96 gsr with a b20 non vtec. And it has a obd1 ecu u and I’m guessing it’s going bad. So I’ve been asking guys and some say b18 and b20 run same ecu, but I don’t know which ? Help thanks
[QUOTE=ChRis Thao;51706556]
P75 ecu should work
I'm trying to get a 1998 B20z2 motor to run had an old ecunon it it was from an H23 its a P14 it was work can I use this or no, should i stick to a P74-P75 or should I use the CRV ecu with P3F
I would use the P3F ECU if you can... the intake manifolds are quite different, but it may work fairly well. If not, the next best stock ECU would be a P74/75. The P14 is totally wrong... and there would be codes. Ideally, you would use an OBD-1 style ECU with a tuning solution.
Derek Perez
06-21-2017 08:28 PM
