auto to manual how the hell are my brake and reverse light gonna work
i'm just finsihed my auto to manual on my civic and i was think how the hell are my brake and reverse light gonna work if anyones has a solution let me know thanks
Re: auto to manual how the hell are my brake and reverse light gonna work (lscoupe)
You need to run some wires from the sensor on top of the tranny. You will see it because you wont have a plug for it. So, the wires have to go to the green and yellow wires from where the auto shifter used to sit.
Your brake lights are not affected by this swap at all.
The reverse lights are another story, but most people don't bother with them..
Re: auto to manual how the hell are my brake and reverse light gonna work (locash)
http://www.rywire.com - I'm in the middle of a writeup and only need this info to complete it.
https://honda-tech.com/zerothread?id=1219564
The old write up i found said to run both wires on the tranny straight to the old shifter wiring and clip them on but a friend did it a while ago by just running the missing wire since it already has one coming from the tranny stock. So i'm investigating which wire to plug it into. You can test the directions i have up right now on the Rywire site. look far down the right hand side
bpatterson6003
04-14-2009 10:00 PM
x still jaded x
07-04-2005 10:49 PM
