H22a4 vac lines and dizzy
Old Apr 15, 2005 | 05:18 PM
SixguN's Avatar
Default H22a4 vac lines and dizzy
I need a pic of the intake manifold from a h22a4 for the vac lines. I think mine are messed up.
Old Apr 15, 2005 | 05:52 PM
Turbogixxer's Avatar
Default Re: H22a4 vac lines and dizzy (Sixgundone)
https://honda-tech.com/zerothread?id=650329
Second post down.
WHat do you need for the dizzy?
Old Apr 15, 2005 | 06:13 PM
SixguN's Avatar
Default Re: H22a4 vac lines and dizzy (Turbogixxer)
My bad. I keep forgetting about that thread. My car keeps throwing a code 3. I replaced the map sensor allready and it stopped. And then it just came back on. My car will idle at 1300 rpm's and once I give it gas, it bogg's out. I was told I can't run OBD2 injectors on a OBD1 p13. Could my wiring be wrong?
Old Apr 15, 2005 | 06:14 PM
SixguN's Avatar
And for the dizzy, can it be advanced?
Old Apr 15, 2005 | 06:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote"> My car will idle at 1300 rpm's and once I give it gas, it bogg's out.</TD></TR></TABLE>
Check your vacuum lines going to the map.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote"> I was told I can't run OBD2 injectors on a OBD1 p13. Could my wiring be wrong? </TD></TR></TABLE>
You can, but the ECU is not scaled for the smaller injectors. You may run lean in Vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote">And for the dizzy, can it be advanced?</TD></TR></TABLE>
No, OBD2 dizzys have a bottom leg that does not let you move it.
Old Apr 15, 2005 | 06:27 PM
SixguN's Avatar
My map sensor screws into the top of my throttle body. Do I need to take it off and hook a vac line to it or something?
Old Apr 15, 2005 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote">My map sensor screws into the top of my throttle body. Do I need to take it off and hook a vac line to it or something?</TD></TR></TABLE>
Sorry, forgot H22a4 TB have TB mounted MAP. Make sure the hole is clean of ****.
Old Apr 15, 2005 | 06:36 PM
SixguN's Avatar
Cleaned. When I first ran codes, I got a 12, 36, 41. Well I have them figured out. But then everytime I run the car for 5 minutes and run for codes again, they keep comin back. And then I get them to go away. And then they come back. Could wiring be a issue here? Also. I was told I would run lean too. But actually, I am running rich.
Old Apr 15, 2005 | 06:45 PM
It maybe wiring, how long does it take for the CEL to come on after you start the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote"> Also. I was told I would run lean too. But actually, I am running rich.</TD></TR></TABLE>
It matters your fuel pressure. More fuel pressure, more fuel the injector will spray at the same dwell.
Old Apr 15, 2005 | 06:51 PM
SixguN's Avatar
My cel comes on right away. But I think that it comes on because of the egr cel(12).
Is there any other reason fo rmy car bogging out once I give it gas.
I have been tryin to figure this out for a week. Everyday.
Old Apr 15, 2005 | 06:54 PM
Few things, timing and if your map sensor is bad. Make sure you have the right connector on the map.
Old Apr 15, 2005 | 07:20 PM
SixguN's Avatar
The only other plug that is the same and is near the map would be the Egr plug. Right? I will double up on some of the wiring.
Old Apr 15, 2005 | 07:25 PM
SixguN's Avatar
Oh, and also I did check for codes again. Now I only have cel 12 (egr). But it still bogg's out when I give it gas.
Old Apr 15, 2005 | 07:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote">Oh, and also I did check for codes again. Now I only have cel 12 (egr). But it still bogg's out when I give it gas.</TD></TR></TABLE>
Look into timing and EGR. If the EGR is opening at the wrong time, it will cause the car to bog.
Old Apr 15, 2005 | 07:53 PM
SixguN's Avatar
Can't I just Disable the egr valve? I have cleaned it out and tried everything with it. I can't get it to work properly. When I give it gas, it sounds like popping coming out the exhaust. And then it konk's out.
Old Apr 15, 2005 | 08:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sixgundone &raquo;</TD></TR><TR><TD CLASS="quote"> it sounds like popping coming out the exhaust. And then it konk's out. </TD></TR></TABLE>
Sounds like timing. Check your cam timing and igntion.
Old Apr 15, 2005 | 10:34 PM
SixguN's Avatar
I checked. Timing is good. I know that h22a4 dizzy's can't be adjusted but when I was looking at it, I seen were there were marks on it from being moved. You think it has a OBD1 dizzy on it? How can I tell if it is a OBD1 dizzy?
Old Apr 16, 2005 | 01:07 AM
SixguN's Avatar
Well, It's running. I took off all the spark plug wires and did the timing again. I cleaned everything out and checked everything twice. So it was either timing or ignition. Anyways. I took it on the highway. I didn't get on it though. I am going to take it easy. When I first got the swap in, I could here a ticking noise. I thought it had something to do with the timing. So I futz with it for a while and the noise is still there. I can hear it coming from the bottom end. If anything, I hope it isn't too bad. I am going to take another CR test tomorrow. The test I did the other day wasn't good. Car was cold and It was the first time I did a compression test. Here were the results.
Cylinder #4 222
Cylinder #3 170
Cylinder #2 195
Cylinder #1 160
I hope that part of this was from the cold, being a noob at doing a CR, and something else. But with that ticking noise, I won't be surprised if it doesn't change much.
Well, thanks and I will post my new CR tomorrow.
IAluder95
Sep 4, 2007 03:12 PM
EG9_808
Mar 2, 2007 11:23 AM
efyou
Dec 22, 2005 03:21 PM
aut0tek
Jan 4, 2005 10:28 PM
ferio 95
Jan 21, 2004 03:39 PM
