obd2 b16a2 into 95 civic Ex.
Re: obd2 b16a2 into 95 civic Ex. (VTECin5th)
Alright boss, I'm new here as well but you really should use the form search. The questions have been asked and anwsered numerous times. You want to drop this b16 a2 into an eg chasi which means teg mounts, keep the old wiring harness from the eg, teg axels (94+), probably gonna need a new ecu (ie p28 all chipped and programed). You'll probably need shift linkage out of a vtec sol or make your own and if you've got A/C the bracket from a sol as well. Try investing in Aaron bonk's (from hole shot racing) books. There is alot of useful info in them, for around 20 dollars. That should get you on your way.
3rdgencrx
70
02-22-2007 08:41 PM
the_unknown
12-30-2006 09:59 AM
