dizzy trouble
Old Apr 14, 2005 | 12:43 PM
ITRnorway's Avatar
Default dizzy trouble
i was converting my b16 from obd0 -> obd1 today, and the firsth thing i started with was to change the distrbutor, and after that did i plug the p28 ecu to the conversion harnes and the old wiring.i did not hook up the o2 sensor.
but when i tried to start it did it sound like it only was running on 3 cylinders, (un burned gas in the exhaust)
so i shut i down right away and checed the wiering to the dizzy, and installed a set of new plugs.
and now it is just dead! wont start at all. when i m checking for sparks is it just the on one of the plug wires, and a second one comes on somtimes...
what can the problem be?? how can i messure ifd its ok??
Old Apr 15, 2005 | 07:55 AM
ITRnorway's Avatar
Default Re: dizzy trouble (CRXnorway)
BUMP
Old Apr 16, 2005 | 11:09 AM
egsleepercivic's Avatar
check for spark, you might have fried the coil
Old Apr 16, 2005 | 07:45 PM
locash's Avatar
Check the distributor wiring. Depending on the adapter used, the wiring is different, check your ecu adapter instructions..
Old Apr 17, 2005 | 10:18 AM
ITRnorway's Avatar
can the coil be bad if get spark in one plug?? i thought the coil just created hig voltage and the dizzy did send the spark to the right plug.
Old Apr 18, 2005 | 05:07 AM
could be the igniter
Old Apr 19, 2005 | 11:21 AM
ITRnorway's Avatar
Default Re: (egsleepercivic)
found out one problem. the coupling between the dizzy and the cam was broken. so thats why it did not rotate... so now im getting sparks. but the car wont start
Old May 3, 2005 | 10:47 AM
ITRnorway's Avatar
should i get an MSD coil or just get an OEM?
Old May 11, 2005 | 09:40 AM
ITRnorway's Avatar
Default Re: (CRXnorway)
could it be the coil that is broken if the dizzy dont deliver a good spark and if it fails to deliver spark at the right time?
Old May 17, 2005 | 06:43 PM
radteg's Avatar
u can get a msd cap and all that jazz...if it doesn't solve it then the somewhere there is a wire that is shitting on everything
Old May 18, 2005 | 06:31 AM
ITRnorway's Avatar
Default Re: (radteg)
well, i have matched the colours one distributor harnes right. so that should be ok. but when i messured the dizzy yesterday. was i not able to messure resistance between the terminal A and C. but between A and B was it fine..
can i just use an external MSD coil and bypass the internal?
but i do get spark on all the wires!!! aint that strange that it wont start. it smels fuel on the spark plug
Modified by CRXnorway at 4:38 PM 5/18/2005
Old May 18, 2005 | 11:33 AM
ITRnorway's Avatar
BUMP!
Harrymonk
Nov 29, 2018 03:31 AM
FTNW
Dec 7, 2010 01:10 PM
andrew714
Dec 13, 2007 09:35 PM
AznBlueBoy
Sep 8, 2006 08:21 PM
menappi
Sep 21, 2005 03:41 PM
