90-93 DA rear disc brakes on EG ?
Old 04-15-2005, 01:21 PM
Jmunk's Avatar
Default 90-93 DA rear disc brakes on EG ?
I've been trying to find a donor car at the local yards for a rear disc brake swap for my 93 Civic Hatchback. I can't find any 94-00 integras that have anything worth while still on them. My question is can i get the rear disc brake setup off a 90-93 integra ? Will the trailing arm bolt up to my EG without a problem ? I've found some threads that say it will fit without a problem and others say it won't fit. I would rather swap out the whole trailing arm vs. swaping out the spindles. So if someone could tell me either way that would be great thanks.
Old 04-15-2005, 10:15 PM
Lord Helmet's Avatar
Default Re: 90-93 DA rear disc brakes on EG ? (Jmunk)
direct bolt on
Old 04-16-2005, 02:34 PM
Jmunk's Avatar
Anyone confirm this ?
Old 04-16-2005, 05:55 PM
Default Re: (Jmunk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmunk &raquo;</TD></TR><TR><TD CLASS="quote">Anyone confirm this ? </TD></TR></TABLE>
You=
Old 04-17-2005, 06:05 AM
Jmunk's Avatar
Thanks. Anyone confirm this ?
Old 04-17-2005, 08:07 AM
alexb16hb's Avatar
Default Re: (Jmunk)
i have read i think every thread about swapping brakes(because I am in the process to do it myself) and 90-93 Teg brakes will work just fine.
Old 04-17-2005, 08:48 AM
H22HondaCRX's Avatar
Default Re: (alexb16hb)
thay will work 90-93 on a ef i dont know about an eg i know the 94-00 will work on the eg
i would say that it would wrok i would like to know to 4 shor
Old 04-17-2005, 09:54 AM
Jmunk's Avatar
Thanks. I guess i'll go pick some up and let you know how it goes.
Old 04-17-2005, 10:27 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (Jmunk)
Yes, it will work without a problem
EG-SIXV-TEC
10-02-2012 10:58 PM
nicky352
12-20-2010 03:43 PM
ED3_FTW
12-16-2006 04:32 PM
Dev90gs
03-27-2004 11:17 AM
ihaterice
07-14-2002 08:17 AM
Quick Reply: 90-93 DA rear disc brakes on EG ?
