98 itr engine into a 97civic. electrical load question... did a search....
I just finished doing a swap into a 97 civic dx, I used a 96-98 civic ex harness. The engine is a 98 jdm itr. The problem we are having is when the A/C is turned on, at idle the rpm drop down to between 200/500 rpm and the engine shakes like crazy. I figured it was the electrical load sensor was not reading, but then I remembered that the jdm p73 has a different pin out for the electrical load sensor. Does anyone know what pin I'm supposed to switch from the harness to make the ecu read the sensor?
thanks
thanks
Re: 98 itr engine into a 97civic. electrical load question... did a search.... (thejdmkid)
Can anyone confirm if the p73 from any year has an electrical load detector.
anyone with a pin out for the ecu of any 96-up integra i think they should all have the electrical load detector in the same pin location.
thanks
thanks
VargasCTR98
03-28-2007 02:34 PM
Hybrid-Fusion
12-03-2005 09:46 AM
