lsvtec problems
Old Apr 10, 2005 | 10:35 PM
NumberB's Avatar
Default lsvtec problems
i had a 1990 b18a with a b16a head on it. it has the lsvtec conversion kit, and what i think is a p72 hondata ecu. car is also turboed, but missing t he upper charge pipe and blow off valve(someone stole it). Anyway, i was wondering if anyone knows of some typical problems that these lsvtec swaps have? right now it is only cranking, and not starting. I just finished putting on a new ls timing belt because it matched the old b18a pump. the timing is correct i think, the distributor is at bottom left at tdc and the cam gears align perfectly at tdc. the firing order is 1,3,4,2 right? starting from bottom left and going clockwise? just curious as to why i have never got this car to start. any help would be much appreciated as this is going on a year and a half now.
Old Apr 12, 2005 | 09:57 AM
resol's Avatar
Default Re: lsvtec problems (milb16a)
either bad distributor or timing off.
Old Apr 12, 2005 | 11:44 AM
NumberB's Avatar
i got the timing ont he belt to match up at tdc and opposite tdc, it also has a well new cap and rotor..
LeegodaEG
May 6, 2013 08:33 PM
mikester_91
Feb 14, 2005 07:45 PM
DrewDown
Nov 18, 2004 07:05 PM
handa
Jul 30, 2004 11:19 PM
Origin
12
Feb 11, 2004 09:31 AM
