problem with vtec not working
Old Apr 20, 2005 | 04:44 PM
bluedxhatch's Avatar
Default problem with vtec not working
kay i did a mini-me head swap on my d15 block, and my engine light is on. so i did the manual code scan and it shows that its my vtec pressure valve. what id like to know is which part is the vtec pressure valve. is it the part with the green plug on it with the two wires? or is it an internal part in the solonoid? let me know asap!~ fanx
Old Apr 20, 2005 | 07:04 PM
VTECVillain's Avatar
Default Re: problem with vtec not working (bluedxhatch)
The pressure switch is the round green 2 prong plug, the solenoid is the square 1 prong plug. Did you remember to remove the oil jet from the block before bolting on the head?
Old Apr 22, 2005 | 05:23 PM
Default Re: problem with vtec not working (VTECVillain)
ohh kay sweet man. i'll be on the lookout for one of those. and yes i did pull out the oil jet. so all should go good as soon as i get that pressure valve. ohhh and i dunno if you'd know what this is all about. like right now i have the ground wire dissconnected b/c it stalls as soon as i attach it. and i cant start it when it is hooked up. what da H???
DJ4Jesus77
Honda Civic (2001 - 2005)
Mar 18, 2011 02:45 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
team 15
May 2, 2007 05:06 PM
crxtreme27
Aug 8, 2002 01:09 PM
