Valve adjustment? Compression?
Old Apr 17, 2005 | 11:35 AM
SixguN's Avatar
Default Valve adjustment? Compression?
I am looking at all possibilities for my ticking noise coming from my swap. I can hear it comin from the head, but It sounds like it is coming from the botttem end also. My car has no pick up after 3500 rpm's. My friend said he seen white smoke when I first drove it. Which I think was just condensation sitting in the motor. And that was the only time smoke came out. My compression test was all over the first time I did it, and It was cold. Also, my car idles between 1000 and 2000 rpm's.
Since I am blowing no smoke, Shouldn't my compression be good?
And, Is this signs of needing a valve adjustment? This idea was brought to my attention once before. Also, my friends dad is into this kind of stuff and he thinks it is what I need. Sry for some of the repeat Q's guys. I am just so confused on this problem. I hear 10 different thngs from 10 different people. Thx in advance
Old Apr 17, 2005 | 06:50 PM
Lord Helmet's Avatar
Default Re: Valve adjustment? Compression? (Sixgundone)
it wouldn't hurt to get the valves adjusted and do a thorough compression and leak-down test if you're concern about the white smoke issue.
Old Apr 17, 2005 | 07:44 PM
SixguN's Avatar
Default Re: Valve adjustment? Compression? (sleeperciv)
Thx. I am going to check into it tonight. Making sure I am heading in the right direction.
Old Apr 20, 2005 | 04:07 PM
radteg's Avatar
do that vavle adj. and then check ur vac lines again...double check everything that u have done. could also be ur ecu but not to likely
ewilliams1990
Jun 28, 2014 03:44 AM
acman1
May 21, 2007 12:06 PM
fasil911
Jan 30, 2007 06:09 PM
JFG Kevin
Jul 19, 2006 07:49 PM
RGoose18
May 21, 2004 10:13 AM
