tranny swap
Re: tranny swap (crx_racer86)
Do you mean actually physically changing the mechanical cable operation on the tranny to hydraulic? If that's the case no you cannot do it. HASport sells a conversion kit to go from hydro to cable and vice versa but that's not how it works. Say you use a hydro tranny in an EF cable chassis, the HASport kit replaces the slave cylinder on the tranny with a cable operated mechanism. Basically it's converting the hydro tranny to cable operation. But to go the other way starting with a cable tranny, you can't change it to operate as a full hydro tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_racer86 »</TD></TR><TR><TD CLASS="quote">no i have 92 civic hydralic and around here i cant find one out of 94-01 integra that i need but i can get all kinds of cable so hasport makes a conversion for this?</TD></TR></TABLE>
Yes it will allow you to run a cable B series tranny in your hydro car.
88civichbz6
01-29-2005 06:07 PM
