Log In
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 [330] 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. 1987 Accord Aftermarket - Do they make anything?
  2. Dash lights
  3. 94-97 jdm accord power side mirrors
  4. to those with h&r race springs on there 94-95 accord
  5. 4th gen accord hp
  6. How to retard the timing on a V6 accord 02
  7. anyone here knows how to use a heli-coil after you have rethreaded a tranny ?
  8. accord tranny mount for sale - link inside
  9. Moonroff Water Leak
  10. problem with speed odometer
  11. question about aftermarket pulleys
  12. 94 Accord major oil leak
  13. 94 sohc vtec in a 93 accord
  14. 98 Accord V6 Timing belt replacement
  15. just got dynoed
  16. 4th gen for a 5th gen? 4door only, or 4th gen sedan EX 5spd only
  17. need shift plate and clutch pedal
  18. Question for poeple who change their own oil...
  19. anyone know where the fuel pump relay is
  20. Anyone have pics of these engines?
  21. Should I swap a H22 OBD 1 or 2, into my 6th gen Accord?
  22. h&r sport springs on 5th gen lx
  23. Anyone got these rims on a 99-02 Accord?
  24. 6th gen accord v6
  25. F22b DOHC ECU question
  26. need to find clutch and flywheel for h22
  27. maintnace required light
  28. knocking noise
  29. O2 (Oxygen) Sensor & the Catalytic Converter.
  30. H&R race springs with 18s
  31. A/C Problem...Need Help
  32. F22B2.....w/ F22B1 Head...Possible? Not familiar with SOHC
  33. Engine Light Need Help
  34. i have carbon fiber hoods, i dont need hoodpins right?
  35. shiftronic on my car?
  36. Gone to the dark side.
  37. Upgrading Stock Horn To Hella Supertones...
  38. tapping after rebuild
  39. Anybody want to trade for a 5sp '94 accord in FL?
  40. 1990 acccord ex wheel bearing replacement?/ stuck on heat
  41. installing o2 sensor in 90 accord ex [f22a6]
  42. Free AEM Intake
  43. 96 accord h22 swap. distributor crisis. need help
  44. Boosting an automatic 96 Accord EX I4 VTEC feasible?
  45. H22a into F22a wiring problems
  46. Free horsepower???
  47. 5th gen with kyb agx quick question
  48. removing front (bottom) sway bar? what happnes?
  49. generation code for accord
  50. 5lug swap with camber problem!
  51. remove rear "H" emblem
  52. Is there a larger size radiator I can fit in my accord?
  53. Fiberglass
  54. 1996 Accord EX , Front end suspensions makes popping and squeeking noises
  55. 1996 Accord EX Rear Disc Brake popping sound
  56. Crashed accord need to know if frames bent
  57. Selling Lude & Getting a 2003 6 Speed coupe..any parts yet??
  58. accord radio wire harness
  59. H22 Shift Cable
  60. Who has the best price on a replacement headlight for a 90' Accord?
  61. Eibach Pro-Kit or Sportlines??
  62. How to find BUILD DATE of a 1998 Accord LX?
  63. OEM exhaust robbing boosted Honda Acura's power?
  64. Axles - need help
  65. H22A swap in a 6th gen Accord?
  66. I Need Auto 96-97 Accord in South FL For testing: Nick has blessed this topic:
  67. VTEC 4 timing belt
  68. need to know how to install helicoil on transmission mount to transmission
  69. need help hookin up r1 rpm monster tach.
  70. what parts for obd1 conversion?
  71. need help on replacing headlights
  72. newbie changing brakes
  73. 98 accord 4 cyl vtec automatic 4 dr
  74. CAI ???
  75. car rasied it'self WTF part II. . .more details
  76. Eibach Strut Bar for a 6th gen Accord V6 Coupe fit a 02 4 cyl Coupe?
  77. performance for 03 accord v6 other than intake and exhaust
  78. brake trouble on 94 4 door ex
  79. Wheel wobbles on 91 accord
  80. Accord Stalling & Stuttering --> HELP
  81. Accord H22
  82. HKS turbo installed. SAFC Hack fuel management as well
  83. Dampness
  84. need help hooking up auto meter tach on my dash---5th gen
  85. DIY Shock/Spring Install on 6th gen accord
  86. engine upgrade for 91 model EXI?
  87. Question about 90-93 accord
  88. accord vs celica
  89. buying accord tips!!!
  90. AC Compressor Problems - 92 Accord
  91. Farewell to my 94 LX
  92. Fuel Pump??
  93. Coolant problem
  94. Intake & header question for the experienced...
  95. Lowered Suspension Clearance Question
  96. not aligned drive side window 1993 honda accord 4dr
  97. Fuel gauge and temp gauge doesn't work
  98. what kinda iol goes into the 5-speed transmission breather?
  99. whats size bolts for a transmission
  100. Just curious
  101. 94 engine problem!!
  102. code 6 on a 1990 lx need some help
  103. Just bought a used car need help..some kinks!!
  104. 91 Accord door speakers
  105. Damp smell in air vents
  106. rear brake disk conversion
  107. 97 accord front rotors
  108. 1998 Accord LX runs hot
  109. New 2003 Accord LX V6 owner...wheel question.
  110. Window Stuck!! help
  111. Metal sound at 2200 rpm
  112. how much should i sell my car for?
  113. 99 accord sedan power window comes out of track
  114. 94 accord ex
  115. Turbo Accord
  116. Accord Side Airbag Light
  117. Accord V6 Idle limiter
  118. Accord 6G transmission problems
  119. 18" rims
  120. car raised itself!> wtf
  121. My turbo accord is getting a trans swap
  122. raise my compression
  123. filters
  124. can anyone tell me how can i get two bolts from the tranny mount?if its stripped
  125. transmission question
  126. '95 Accord EX Coupe Price Sound Fair?
  127. vibrates in reverse(auto tranny)
  128. Clutch Master/Slave Cylinder Problem?
  129. weird RPMs on 4gen
  130. 95 Accord engine power loss
  131. Reading computer code on a '99 EX?
  132. strut help
  133. installing headlights, need some help...
  134. f22 lx motor
  135. Can Someone Run a Full Carfax report for me?
  136. 99 4cyl stalls under braking
  137. Ignition Advance Using 98 Octane - F22B1
  138. How low of a drop can i go b4 i need a camber kit?
  139. 97 EX accord h22 swap. dizzy differences.
  140. Autometer Guages
  141. lowering accord?
  142. Clock does not light up!
  143. Walker O2 Sensors
  144. 94 accord to 2000 Special Edition
  145. Accord.. Stock exhaust.. bit sounds like an aftermarket???
  146. installed H23 upper intake manifold/throttlebody on F22a6 lower intake manifold
  147. i need a engine my car is too slow i want to go fast
  148. 1997 Accord Special edition
  149. one more time im sry i asked b4, whats the engine code for a 95 ex accord coupe?
  150. Mugen Cooling Fan Switch
  151. Need quick help with springs.
  152. Anyone use Eibach Pro-Kits w/ Tokico Illuminas on a 6th gen?
  153. Anybody road/drag race thier Accord?
  154. 2000 Accord automatic transmission warranty
  155. 90 accord lx 5sp...idling low with ac on only
  156. tps sensor compatibility accord/prelude
  157. maint reqd
  158. Power Door Lock Question?
  159. P/S fitting
  160. People from NJ, i need help~!
  161. A20 swap out options
  162. 03 Accord Windows
  163. big gap on sportlines?
  164. Post Tire size, Wheel Size and Offset *Approved by Nick M"
  165. Car making loud ass whinning noise
  166. help with shavin door handles on 93 honda accord
  167. just got my car yesterday
  168. Diffrent between 4-2-1 and 4-1
  169. odometer and gas mileage meter malfunctioning (96 accord lx)
  170. Hard to shift
  171. Getting new tire
  172. 94 Accord LX Interior
  173. 1988 accord lx-i
  174. How different are accord railing from civic railing of a recaro?
  175. Who has a real Euro R H22A(JDM) or an EDM H22A7 in their Accord?
  176. fuel pump relay
  177. what kinda bumper is this
  178. **FAQ and links to their answers**
  179. 5th gen
  180. OK, we are going to design/fabricate a good N/A header for F series people........
  181. Codes ???
  182. Fuel system setup? along with a few other questions.. built f22s, boosted or h22 swap peeps
  183. need help for "2oo2" accord ULVTEC accord (ecu)
  184. looking for turbo kit for 91 honda accord
  185. need feedback, important! thanks guys! and gals!
  186. boost for f23
  187. swap it up?
  188. boost on 4th gen.....replace pistons and seals??
  189. nitrous
  190. Need Help Buying an Accord
  191. 98 jdm h22a swap
  192. 4th gen to 5 lug
  193. oil over filled
  194. h&r sports springs on a 5th gen accord.....how low with stock struts
  195. How to get started on a transmotion swap?
  196. ecu problems
  197. 4gen ECU code 41
  198. Car leaking coolant, any ideas?
  199. How to install the trailer hitch wiring assembly?
  200. Replacing rear rotors & bleeding sequence question
  201. Intake Manifold ...help?
  202. Stock 14" wheel specs for 91 accord sedan? (steelies)
  203. okay idling problem computer difference
  204. how much the cars weigh?
  205. CEL/Error Code question 2000 Coupe 4cyl
  206. h22 in a 6th gen, help please
  207. Parts Search
  208. anyone make crank pulleys other than Unorthodox?
  209. 1994 accord JDM (non-stanley brand) headlights
  210. torque specs for valve cover bolts?
  211. F22A1 w/F22B1 head swap: complete.
  212. How many years have you gone without changing the timing belt?
  213. STARTER PROBLEMS... with new flywheel
  214. H22 6g Accord
  215. Intake Manifold Compatibility
  216. what other f22 header flanges match the f22b1?
  217. How much lbs. of torque impact wrench do i need to work on my accord...
  218. difference(s) in Prelude/Accord differential?.......
  219. Header what kind?
  220. Att: those of you who have completed a 6gen h22a swap, need wiring help!
  221. b20 engine go in 1996 accord
  222. Test pipe/High flow cat ?
  223. Car Wont Start...
  224. How to check ecu code in 95 accord?
  225. Timing Belt--Years?
  226. Used Car Search Help
  227. quick OEM brake upgrade question
  228. Installing CD player into 92 Accord
  229. 5th gen help
  230. parking lights not working
  231. Turbo accord question
  232. my clutchmaster stage 4/ flywheel installation experience. 56k BEWARE!!
  233. euro-r crank pulley questions
  234. Can someone verify this Accord manual?!
  235. Do they make aftermarket ECU's for 2.2 non-vtec 94 accords?
  236. Seat Swap HELP!!!...4th Gen Lude into 4th Gen Accord
  237. Timing belts
  238. will a prelude shifter work on an accord
  239. Best site to get Ground Control? for 5th gen
  240. Recaro railings. Civic to Accord?
  241. Ideas for fixing up the body
  242. 93 lx (auto) rear mtr mount questions
  243. h22 h23 what is the diff?
  244. accord pin outs anyone?
  245. H22A Accord Power Steering
  246. What's The Best Exhaust For My Accord ...
  247. Need some help with muffler problems...?
  248. what do stock accord get as in MPG?
  249. 97 Accord, ABS/Parking Brake Light
  250. Making power with an 84 hatch??
