View Full Version : Honda Accord (1990 - 2002)
- Tein lowering springs & KYB shocks. Anybody have this combo? 98-02
- Antenna ideas, non-power types...
- how to reset cel
- VALVE TORQUE SPECS
- H22 in a 94 Accord
- I have honda accord 1990 model manual
- 97 engine swap
- 1998 Accord Ex Alarm problem, please help
- Accord ORB II Code
- Water comes from under the dash when AC is on... Windows fog up with heat on.. ?? 96 EX Sedan
- Q: 94 EX, V-TEC, Can I reuse the EGR chamber gasket?
- ram air or cold air?
- 92 n 96 accord gatta sell
- 95 Accord issues Quest. need answer.
- HELP with DIY suspension find
- blinker problems
- h22 intake manifold on a jdm f22b dohc
- Can anyone who knows photoshop plz chop me a 06 accord coupe?plzplz
- Limp mode
- Experiences with carbureted 88 and 89 Accords? Reliability in mind.
- automatic wont shift past 3000rpm
- Need one rear steel wheel
- paint color help
- could anyone tell me what these codes are?
- What Lip will fit my car????
- Valve cover stud?
- just bought a 93 accord i have questions
- 1983 Honda Accord
- Where is the Baro sensor?
- open deck or closed deck h22
- Gonna Toss This Out There....
- How To ?
- 93 Accord SE Ignition switch
- idle problem
- Im lookin for opinions on what to do next.........
- H22 oil leak
- seat belt beep
- halo headlights
- accord wagon rim question
- 1999 Accord - Maintenance req'd light?
- Spoon Lip
- Tach accurate?
- obd2 p13?
- accord pricing
- Is there a liner underneath the trunk lid?
- brake problems 96 accord .
- intake "pop" noise
- h22a, accord wire haress question
- done waiting for honda to release a lip for its 07 coupe accord.
- 1991 Accord Distributor
- looking for a 96 accord lx ground points??
- i have some questions
- engine code problems?
- speedometer on & off
- Spittin', and a sputterin', ad being real laggy.
- Wanted: need door rubber..92-93 accord
- Ex headders on my Lx
- D3 Question
- Quick question?
- maintenance light
- code 21 on a 92 accord non vtec
- '96 accord v6 leak(trunk, back seat)...any possible leads
- HELP: does a 99 4cyl motor fit in a 91 accord
- Oil Question
- K24?
- Can someone hook me up with a spark plug cover for my h22?
- What wheels are these?
- Quick question about 94-97 accords..
- Accord obd1 vs Civic obd1
- 90 accord electric seatbelt problems its stuck forward any ideas?????????????
- heat problem
- DropZone Vs. Maxspeed Coilovers
- need some help from the accord guys
- 2002 Accord cold idle problem
- 2009 Honda Accord review
- 97 Valve Cover Gasket
- How do you jump the Service connector?
- Turbo or H22??
- ? on rims on a 6thgen 4door
- Where is the service check connector
- Electrical Gremlins
- '90 Accord dies and has problems starting again
- 93 Accord torque convertor question?
- 1999 wheel studs
- Need help. IAB wiring!
- unusual gas mileage?
- synthetic oil in h22 accord
- Motor Swap
- How to properly adjust the trans cable???
- Why won't it run? DSM injectors in an Blown F22
- prelude seats?
- kickdown switch
- Engine Swap ??'s
- Chassis Code?
- Want to buy stock air filter housing top and bottom 94 accord
- buzzing from my pcv and bad gas milage
- headunit install
- Help, can anyone identify this hose?
- ADR rims for SALE....$250
- SRS light reset
- 99 LX CEL code p1259....what is it?
- Idle speed 99 accord
- ADR rims for SALE
- timing belt
- Odometer Troubles
- HID Upgrade Results
- Oil leak on transmission assembly....
- POWER STEERING LEAK! HELP!!!!!
- auto trans filter?
- 1988-1995 Chilton Accord/Prelude books?
- vacum?
- 94-97 Honda Accord rims?
- redline probs need help fast!! please help
- shifting the gear to neutral without clutch
- Check the pressure of the AC system?
- Torque Converter Lock Up
- Rear Disc Brake Adjustment
- Problem with my h22 Accord
- apex'i VAFC problem
- Help Please - Wire to Gas pump
- safe turbo psi?
- f23 tuning????
- spark plug wires
- Steering Wheel Airbag
- Nitrous on an F22A4 w/ 208k miles
- Turbo F22A4
- PT3 chips
- I want acceleration
- my accord is getting hott. first thing I should check is??
- Amount of power gain from performance parts
- moving motor
- terminal exponder doradiator
- 5th Gen Fog Light Wiring ...
- '97 accord
- Streeing Wheel
- HELP OIL LEAK!!!!!!!!!!!!!!!!!!!!!
- HELP can you swap prelude transmission into accord
- amp on stock HU in 4th gen
- 1990 color options
- install an intake
- help with check engine light
- stock alarm problem help!!!
- 93 Accord dischage R134a
- Day time running lights?
- Problem with my accord, fan won't stop !! HELP !
- 1989 Honda accord exi shifts hard
- i am looking for a part. is there a forum for parted wanted?
- 94 Accord 4dr windshield = same as 94 2dr???
- Just bought a 1989 Accord EXI runs fine till it warms up then idles rough
- Honda ECU p13 p28
- 92 accord transmission problem f22
- '86 LX to LXi swap
- Turbo
- 99 Accord Transmission kick from park
- DSM aftermarket turbo manifold to ACCORD?
- which vacuum line to seafoam?
- Need help/reco for where to look/buy body kit for my accord
- synthetic oil
- tranny swap
- 1990 2dr EX-R Door Speaker Question
- P13 vs p72
- 91 honda not starting
- Transmission case question
- Removing 1996 Bumper/Cover
- Class Action Lawsuit for tranny
- Will this head fit my F22b
- a little help
- Rattling on the suspension
- need a quick answer guys for a noob ?
- 93 Accord Not starting. Please help
- 1990 Accord w/ H22 Auto Swap No Vtec????? HELP!!!
- Transmission Control Module
- Maintainence Reset
- Stereo In Accord EX-L
- h22 head install on f22b2 help
- 94 Accord EX Problem....
- another swap post lol
- Anyone Else in here with a 03+ Accord like myself?
- how to ecu auto to manual convert?? 1996 accord 2dr
- Someone Broke Off My Antenna!!
- Engine performance parts for A20
- Oil Crankcase Cleaners.
- sleeved f23 picture
- 1990 Honda Accord EX 2.2L ?
- baessy noise and engine vibration
- timing chain configuration
- I only get 240 miles to the tank without jackrabbit driving! Help
- accord with vtec problem
- 5th Gen door handle problem.
- Broken bolt!
- 1989 accord, auto help please
- right front axle
- euro r ecu
- rear lip
- 1995 honda accord engine troubles
- leather seats for 06 accord lx
- Help... f23 rod bolts
- cv axels
- Looking into getting a used 1998 Accord. any advice/tips?
- Looking for a B16aG1!!!!
- Ignition problem?
- MANY HONDA PARTS FOR SALE 1994-1997
- Anyone have pics of H&R lowered 98 accord??????
- 2001 Accord - Bad Tensioner or Balance Shaft
- 1985 accord help
- question about h22 swap in 4th gen accord
- 92 accord electrical problems(no dash or tail lights)
- need help with timing belt on a f22a1
- Apexi v-tec controller help
- JDM antenna!!
- rear shocks removal prob.
- new to this need parts for accord
- DIY black corners question
- off topic - paint code of purple accords or dark blue accords please from 98 to 2002
- display went out
- j series
- Did the 94 - 97 2 dr Accord come with BLACK interior?
- Accord Transmission Question
- 96 accord vtec 2.2 problem
- Turn Signal Question
- D-16 accord?
- Camshaft bearing cap bolts torque spec question
- engine swap
- Need Help!!!!!!! 5 speed Tranny swap
- 1992 Honda Accord EX Shifting Problem
- K Swap into older Accords?
- 5th gen 2.7L V6 vs. 6th gen 3.0L V6
- NEED 98 accord Tranny AsAp!!!!
- Major Accord Question!!!!
- 88 Accord LX (manual 4dr pwr everything) DOOR PANEL REMOVAL
- 1996 Honda Accord Airbag light on
- need some quick help guys - msd cap install
- eibach prokit or H&R race springs?
- Ecu problem.
- SRS Light on
- VTEC in my 99 LX
- ???what 5 lug hub fits on the 94-97 accord???
- F22B1!
- prelude and accord interchangeable parts?!?!
- smoothest drop?
- Honda Warranty?
- does anybody know oem spring rates? 91 Accord specifically…
- DIY - rear brakes for 1990 Accord
- F22C in the S2000 same as the f22a1 in accords ??????
- 98 accord manual to 5spd swap...
- Service Manual for 2000 Honda Accord EX sedan V4
- Did the EX model for the CD5/CD7 only came with these rims?
- question for VTEC experts
- accord euro-r rims
