View Full Version : Honda Accord (1990 - 2002)
- Honda parts, will they fit
- drivedhaft ?
- chained h22
- abs?
- Emissions System in 93 accord h22
- thinkin on guttin
- JDM headlight bulb? H1? not sure, quick help!
- New Here.. Need Opinions..
- 90000 Miles Maintanence - Help Me
- Need help w/IAB sensor
- Rims
- Radio swap 94 to a 98 Accord?
- Accord 1991 SE Shifting issue
- 98-02 Accord v6 springs to spare?
- Accord work
- Y CHECK ENGINE
- Heated power mirrors on Acura TL
- have a 4ws accord?
- 1989 Accord
- 6th Gen Switch from Manual A/C to Auto A/C?
- Help with 91 Accord suspensions
- Help With 01 accord
- brake fluid
- oil smell?
- what are the obd? for various model accords (example 92-95 civic-obd1)
- accord/prelude help please
- Door Stopper Thingy
- top dead center (please help)
- VTEC gone wrong??
- Is there a way that I can make my air/fuel mixture leaner without bringing to a shop?
- adjusting spark plugs
- Would I get more power out of a fidanza lightweight flywheel or fuel pressure regulator and fuel rai
- 1991 Accord Trunk Leak again
- Broken Swaybar End links?
- Hondata
- 94' with engine going...
- question about brake fluid
- Steering Wheel for Gen5
- Looking for specific post
- Mud Flaps/Guards (94-97)
- squeaking noise from rear while going over rocky roads
- '99 accord dash removal to replace radio
- How to remove cruise control??
- accord lx 98 low beam?
- need some info about 96 accord coupe
- MY 2003 HONDA ACCORD RADIO CODE
- k24 accord turbo w/ r33 skyline turbo
- finding / replacing speed sensor in '94 accord lx
- 92 accord <95' h23a swap...axles????
- now what?
- Questions about 01-02 CD changer
- Oil in Spark Plugs.
- help honda accord 91
- oil question
- Catalytic Converter Help
- 1998's fender flare - fittable to 1990???
- Does removing the rear seats mean you need a roll cage or is just recommended?
- Accord Aerodeck?!?!?!?
- Need pic of hood strut bracket of V6 accords
- 03 Accord. Help!!!
- FOGGING UP Q ?
- Is my Tranny Funked?
- OT: (Originally Post in Kill Stories) Accord Kills Modded WRX. WRX blows headgasket
- R134a a/c Retrofit
- 5th gen header fitment
- Banjo bolt on fuel filter leaks
- 2005 Accord Coupe V6 6-Spd - questions
- obd conversion dizzy wiring for f22
- Rear rotors retrofit?
- Valve noises
- h22 auto 2 manual conversion
- 5th Gen Daytime Running lights?
- Engine/Transmission Swap
- 98 accord will jumpstart but not start on its own!
- 05 Accord Gauge lights..
- H22 swap need help
- Old school 86 accord, plz help
- air filter dimensions
- 96 EX-V6 Tranny swap?
- 1991 Honda Accord
- 95 H22A anyone? give me your F22B1!!!
- 1992 Accord Radiator Fan Problems HELP PLEASE!!
- What tires are good for my car
- Tranny problem
- Accord EX
- Where to leather wrap seats in So Cali?????
- 98 - 2002 owners info needed
- 2004 Accord EX V6 mod questions
- Automatic transmission
- Hi, all
- Tire size for 17" x 7.5 rims?
- a good idea??? anyone ever done it? (accord black housing headlights ONE PEICE)
- accord f22 in a 94 prelude ?need help
- 4th Gen Roll Cage Pics......
- Hi all, i have this problem but don't know what causes it.
- 02 sensor
- HOOD WONT CLOSE!!
- f20 vs h22
- HOW FAST ARE THE ACCORD TYPE EURO?
- MY 92 ACCORD HAS A WINDOW MOTOR PROBLEM..
- Balance shaft woes
- S7 Guages, need help w/ installation
- Engine swap
- 1991 Accord trouble starting
- 5th gen transmission problem
- Problems w/ battery
- Teins or konis
- Hood plugs
- how much boost
- rust...
- accord diesel to usa? when?
- bosal performance products
- Hi Ya'll - First Time Accord Owner Here
- Air Bag Light On Dash
- Thinking Turbo.. Have sum ?'s...
- NEWBIE O2 SENSOR QUESTION
- 94 Accord Bumper Removal Problems. Searched aleady/Not in Haynes
- 89 ACCORD 2.0 CRANK TIMING MARK FOR TIMING BELT ??????????
- another CAI question
- 98 V-6 Accord Auto CEL and Tranny Code
- check engine
- engine hood won't close
- f22 mini me swap help!
- 94 accord emission problem
- problem with window wipers
- tranny fluid chage
- car doesn't start with spare key
- WHITE GUAGES ???
- Spoiler
- help help help - wheel bearing
- Accord Throttle Body Cleaning or Aftermarket
- What are the engine codes of the new Honda accord?
- 2001 Accord V6 coupe, how much boost can the trans. take?
- ABS light on
- Radio lights out
- help me out
- trial user
- removing lip kit
- installin cold air intake.
- Turbo or no Turbo?
- Bleeding the power steering system??
- how mcuh shipped for accord Euro R to USA
- tubo advice needed
- Possible Detonation in 2001 V-6
- brake noise
- Buying a used Accord - 100k miles.
- F22B Motor
- My car got broken into, Fu*k theives
- thinking of getting an accord........
- Switching a AUTO Tranny to Manual Tranny???
- removing trim peices/doorhandles
- Axle Q's
- OBX HEADERS 6GEN AV6
- anybody have a wrecked accord?
- need help..jdm parts gonna install
- is there a way to hook up my...
- 94 Accord retro-fit...
- help 97 accord engine rumbleing..and shakey at idle<<<<<
- Transmission?
- Help with side markers...please!!
- timing belt broke in 85 accord
- 91 Accord squealing when put in reverse
- h22 motor swap need help
- 4th gen daily driven Accord running 12.72 @108 All motor (hope for "NA" guys)
- lsd
- Double Clutching
- Tire Question
- Need advice on buying a used accord...
- belts
- failed emissions
- Riding on Different Tire Sizes??????
- Tranny on 02 Accord-Help
- Short Ram Intake For 6th Gen H22 Accord
- 93 Accord
- brake balance
- reseting ecu
- 91accord ex 5spd popping/grinding noise
- 05 accord wheel ?;s!?
- Is there a way to swap the rear drum brakes for disc brakes in the 05 LX
- obd1 obd2 why?!!? wtf!!
- just gave away 2g's
- How do I know if my car is capable of having a turbo installed?
- car sounds like a diesel
- Obd1 conversion
- Help on CEL code #9
- Japanese People Gave me a Weird Tool.....
- H22 swap HELP
- Can slamming the brakes hurt the half shafts
- Speedometer works part-time...
- New guy on the block. Performance and Shifting Questions.
- weird noise coming from engine at rpms 1000-1500
- Car misses
- new clutch and flywheel
- Suggestions: H22 headers and exhaust
- Hi all I have problem with finding the transmission drain plug oil
- Help! New guy! prefromance and shifting question
- wheel bearing - need help
- Tires
- Help, before i junk the stupid accord!
- H22 Swap..
- Bird shit on the hood that has become cemented on
- tranny help!
- acura cl seats
- H22 turbo manifold???
- Grinding sound at first stop on 03 EX
- Best place to buy replacement catalytic converter???
- side airbag light
- h22 stage 2 cams????? need info please
- 98 Accord Ecu conversion
- Torque Specs
- Problems with the way my Accord is running!
- Windshield sprayer
- Honda accord V6 2000 Exhaust
- Power steering leak on a '01
- Small Clanking Sound when backing up
- Replacing rotors?
- quick question about remote start...
- ahh accident
- Poly front engine mount
- Signs of a broken tranny mount!!??!?!!
- Rota-Flight?
- A/C Bracket
- Axle On '94 Accord Gone Bad....
- Wheels?
- Honda radio locked up after wrong code entered. Help
- exhaust vibration...
- H23 head??
- 98 V6 Coolant loss. HELP!!!
- Pics of my F22a with darton Midsleeved and fully built for boost.
- changed struts and..no help
- Some suggestions on fixing a transmission related issue
- stupid heater core!!!!!!
- Engine Swap Question
- Accord 03 motor vibration between 2000 and 3000 RPM
- Engine skipping and seems to be running rich....
- top speed
- Is the 95 vtec and non-vtec intake manifold the same.
- can someone tell me why my 95LX is 130hp and 93EX is 140hp?
- 92 accord engine into 95 accord
- 99 Accord 4 cyl check engine light
- JUST BOUGHT A NEW ACCORD!!!! Couple of Questions....
- How many?
- noise from driver rear side when turning right. wheel bearing???
- help installing air intake
- h22 swap,,,, high admission rate ?????????
- scaping sound, not brakes!
- 94 accord lx 2.2 intermittent speedometer/odometer
- 90 accord electrical problems
- drivers glass
- Code Reading (OBD II) Question
