View Full Version : Honda Accord (1990 - 2002)
- H22 block fs questions(threw a rod)
- 2004 Accord Oil Changes
- Prop valve question
- what ever happened to accordv6.com??
- 1991 accord wagon
- How do I remove the antenna mast?
- help! DIY 1994 Accord Flywheel
- Radiator Options
- Gas Mileage - 1994 EX
- easy question...
- Intro and basic tuning questions
- was wondering where you guys bought this..
- squeaking noise after alignment
- using a "plug and play" unit for my 01v6,. is it worth it??
- Alarm System???
- Converting To Power Locks & Windows, Someone Help!
- Am I being lied to about my automatic transmission?
- 93 ' timing mark question
- performace exhaust
- window rattle 2003
- H23 thottle body/F22a6 intake manifold
- help
- Coolant Burning
- need help with body rust
- Anybody Use an HKS Super Mega Flow Intake?
- carbon fiber spark plug wire cover for H series valve cover?
- 94 Accord EX reaar brake problem
- ported F23 intake manifold---pics inside
- I need help with my car pleaseeeeee!!!
- RSX Muffler on accord
- '87 Honda accord staring Q
- Auto Tranny slipping- Need Advice
- what should i look out for in getting a dyno
- 1993 Accord EX needs TCM
- Dunlop Sport A2's - Noisy tires???
- Replacing synchros and gears ?
- auto trans & rpm
- idle problem
- Rear alignment
- tail light ?
- Accord Gas milage.
- brake experts needed
- Shake in the steering wheel.
- H23 Head
- 88 Accord problems...a little help please
- Rear Speaker Wiring Question
- little off the subject
- Vibration in the steering wheel, braking at 60+ miles... help
- 91 Accord automatic transmission control unit
- seats?
- h22 into 91 lx
- Idle drops, near kill, engine light, noise in distributor? 4th gen
- Integra Headrests
- exhaust question
- 15x6 steelies??
- underdrive pullleys on f22b1.....what belt??
- h22 fears........
- turboing my accord, thoughts?
- dash
- speaker adapter plugs
- quick question
- OT: Making a turbo
- Chaning Axle Joint..Anybody know how?
- Brake Disk... what to get other than OEM?
- Estimation on money
- 2004 Accord rims
- Monster Tach
- How to get broken bolt out of head
- Brake Wear Problem - 99 Accord Coupe
- Exhaust manifold leak on 97 accord....how should i fix
- Koni Yellows
- New V6 6spd into 5th gen possible??
- 5th gen weights
- recall on the accord?
- Hesitation going around the corner
- Naval Jelly safe to remove rust?
- Parting out Accord, parts for 94-97
- What Settings on KYB AGX for normal street use?
- my plans for lowering and suggestions
- 5th 6th generation transmission problems
- Upgrading Power Lock & Windows
- Tower Bar
- springs
- performance ignition module?
- Options on 2004 accord
- 99 accord v6 header
- Gas tank rusted out - 155,000 miles
- 90 Accord problems please help!
- Is dere anyway to pass smog wit a jdm h22a motor?
- H22a power steerin noise
- skunk2 muffler?
- vacuum question
- anyone have dyno sheets for aem sri on accord 6th gen ?
- best suspension prices?
- Is it my axle or my suspension????
- how do I replace gauges in dash?
- DIY porting?
- MUFFLER
- PCM Problems on 97 LX F22B2, OBD2 throwing cel
- Honda experts- Please Help! -'89LXi computer
- changing pulleys
- 96 accord howto's needed
- Turbo F22B1
- Parking lights and instument lights out on an 89 Accord LX
- NEED HELP ON BRAKE ROTORS
- Idle Adjustment
- Questions for engine swap on a '97 Accord LX sedan
- i got a couple questions
- obd1 distributor
- motor swaps
- Wat is a resistor?
- 1998 Accord EX V-6 Odometer Bulb
- stock rear lip
- dirty o2 (oxygen sensor) ? Will it read lean or rich?
- Oil leak... need advice
- sup guys, need some help.
- oxygen sensor
- my sister's 99 accord threw a 41 code?!!!
- Installing New Headlights
- OT: Was'nt on for a couple of days
- transmission fluid leak
- front lip install?
- lower ball joint removal
- Just ready to do first ATF change TODAY - but need help, being cautious.
- Turbo question for 6th gen Accord
- 4G Accord JDM Info
- what do you think ???
- 1991 Rear Window
- Climate COntrol buttons broken>?
- Intake resonator?
- questions about headers
- Do D4 warnings disappear ... or is my mind playing tricks on me?
- Valve covor for 16 valve?
- are the flanges on DC sport stainless steel headers also SS?
- Slot Brake Rotators ?????????? NEED HELP
- Where to find good deals on Roators
- Clutch slave cylinder replacement.
- No exhausts for my LX!!
- EGR wiring for 6th gen H22 accord
- mirror relay location???
- suggestions for coilovers for a 94 Accord LX
- Aite peeps code 45
- Accord 2004 Ex radio
- How To: Install an S2000 antenna on your Accord!
- Brake Fluid + Power Steering Fluid
- Can Apexi WS coilovers be revalved?
- 95 Accord Axle Problem/Question
- Angel Eyes projectors...rewire
- What type of Tuner Lug nuts do I need?
- What's the best method/parts to use when lowering a 97 accord 4dr LX?
- Can't shift out of park, and no speedomter
- 97 Accord transmission BOYA vs AOYA Auto
- 98 V6 - EGR valve insufficient lift and EGR insufficient flow error codes...
- PIC request 94 accord purge control solenoid valve please.
- Anyone have pics of the Auto trans solenoids for a 94 MY? ...
- Motor Size???
- H22 Swap and losing pwr steering pump
- Steering lock
- Accord Suspension For Sale 98-02 6Th gen
- :: Hybrid H23/F22a6 Intake Manifold conversion questions.
- Q: Are there two D4 lights, while in Park position: steady and flashing? n/t
- h22 swap is done just need some guick help
- 1 last ? on auto tranny d3 flooring vs 1-2-3-4
- Driverside window motor making loud weird noises
- OT: Supercharged F22b1 inside
- Makin loud noise from the powersteerin of a h22.
- fog light problem
- short ram vs cold air intake (when it comes to turbo)
- quick need to know fast..
- third gear
- broken bumper?
- KYB GR2 shocks on 98-02 Accord?
- how does this look?
- 87 Accord Water Pump / Timing Belt -- Need Help
- Has anybody used Apexi coilovers?
- f22 ecu interchangeable with h23 ecu?
- TYC Elegante 98 Accord 4dr Tail-lights
- The 6th Generation
- Turbo kit for 2004 honda accord ex V6 coupe
- '94 OIL PAN DROP
- Turbos!!?? T3 Turbo on an 2.2 SOHC V-tec
- Q: D4 blinking dash light ... & can I use Dexron II Synthetic?
- 1988 Honda Accord Won't Start
- How difficult: JDM H22 into 90-93 Accord (both automatic)??
- 2door Accord v6 or toyota solara?
- 94EX Anyone change the rear defrost button "on" indicator color (from orange) ?
- What do you guys use to take off Axle Nuts?
- Please HelpMe Need Car For Work
- bolt pattern for accord....
- obd1 h22 into 96 accord lx, wiring info needed ASAP
- loud noise cummin from my h22!
- WHat is the name of the color the the green paint on a 95 accord?
- 1998 accord air conditioning problem
- I need a doorfor a green/teal 95 accord
- Brake Light on dash ON although all brake lights are working
- dual runner swap.
- What are the symptoms of a failing slushbox?
- power window motor, need help!
- removing axle
- Tips on Tuning a '98 Accord
- CEL but no Code, No VTEC
- whoever can tell me if my swap is possible and how much work it would be, you're good !!
- Locating/Identifying SCS service & MES connectors help needed. 98 accord
- For Beginners
- Im Having a problem with my accord!!!!!!!!!!!!!!!!!!!!!!!!!
- Who all here has plugged the EGR port?
- might be head gasket?
- Are you in: Closed deck vs. Open Deck
- My starter just took a dump and was stuck in the "ON" mode for like 2 minutes..
- NEED ANSWER! 1997 Accord Harness, 1994 H22a motor
- 92 lude to 92 accord rear brake conversion??
- Are the axles bad
- 1987 Honda Accord LX 2.0L Carbureted PCV Valve Location
- SAFC Cant read Throttle Response
- modding my 92 accord lx
- New to board, engine sound question for 87 Accord
- Intake instalation for 90 lx
- got one little question
- 3rd gen dash pic please
- Broken Side view mirror on my 90 accord lx
- Good deal on this Accord? New to Hondas...
- This should be my last post on this topic.
- 99 Accord EX 4 cyl very poor gas milaege.
- code 7 on a automatic trans
- 91 honda accord modifications
- 89 accord hp
- 94 ex catalytic converter
- O2 sensor light--'01 accord
- 89 Accord swap
- Distributor & EGR wiring. Plz Help
- dual exhaust systems?
- lxi question
- 6th Gen Accord - DSM 450cc install?
- question about my accord
- Check Engine Light comes ON. Weird??
- How-to guide for installation of new shocks
- Poor Gas Mileage - 91 Accord
- odd noise from front wheels
- Draft:Newly replaced brake pads are squeaky (2001 Accord EX)
- Lighter question pinpointed....
- Want my Auto to shift harder (93 LX)
- head and intake port and polish?
- Changing front rotors on '94 EX
- REmoving Stock BLue UV Windshield Tint
- 97 accord lx. oil on top part of spark plug
- Oil question
- Airbag question
- Brakes question!!
- Question about maintenance light
- vtec head on a 91 is it possible
