View Full Version : Honda Accord (1990 - 2002)
- Engine knock question
- 1992 Accord LX code 41
- Autocrossing
- SRS Light
- location of reverse light switch
- Accord keeps dieing. Getting frustrated!!
- 94 Accord turns over but won't stay running
- 95 Accord cranks but won't start
- performance intake pipe and air filter
- 02 Accord CPE OEM Foglights
- exhaust question?
- Partial throttle hesitation problem.
- Sir Transmission
- Suspension Help....
- 1989 accord failed emissions
- Question about oem foglights for an 01 Accord
- clutch and flywheel compatibility between F22 and F23
- brake light problems
- interior change
- Gas milage down the toilet
- left turn signal causes engine to die
- Changing ATF
- 5th gen swa?
- 2000 Accord inspection problem from engine swap
- disabling ignition key warning beep on 2007 accord
- 99 accord transmission conversion
- Brake Kit
- CODE CHECKING
- Random Power Failure
- 1998 V6 Vafc2
- 93 accord lx idle problem
- driver side front tire hops/vibrates
- a/c belt getting hot
- trany help PLEASE:(
- 2001 EX v6 e-brake light issue
- help...
- 1997 DD project..... Transmission issue's!
- Solid CEL Light?
- 99 accord 4 auto to manuel tranny swap, Bolt on?
- spark plugs / wires?
- I think I have a bad CV joint can anyone confirm.
- quick question, what kind of oil should i use on a 91 accord w/ 180k?
- 94 accord gauge cluster
- 98 accord Lucas fuel treatment
- 1998 Accord gas cap / P0420 code??
- Reccomended Mods?
- Setting the clock?
- test pipe to downpipe PROBLEM
- ANYONE HAVE RECOMMENDENTIONS FOR A BOTTOM END
- Lower Control Arms for a 5th Gen
- Recommended spark lpugs for 98 4cyl accord
- whats up everybody, i need modification some help
- engine overhaul/ rebuilt on a accord
- a/c removal
- queston about f23a4 cat?
- MORE HP from a f22b DOHC
- no compression 95 accord.
- Side airbag light keeps coming on
- Can I rent the Pulley Holding tool at an auto parts store or ?
- Important Oil Light Question
- 94 Accord Ex problems..
- Couple more timing belt change questions....
- 94 accord making a wierd noise when i start it up
- Accord starts then dies.
- About to get an Accord tune up..
- Overheating.. sometimes?
- 93 exhaust advice
- 98 Accord with jdm h22a failed emission REALLY bad!!
- 97 accord engine mount problems
- Question about gettin new Brake Pads and Rotors
- adjustable ball joint question
- 92 accord lx *help*
- Q: Crank Pulley Holder Tool
- resettig ecu after seafoam
- JDM - SOHC vs DOHC ENGINE SWAP F22B
- How do I vaccum test the EGR valve
- 91 accord no start after accident.
- I'm In Need of Serious H22A Help!!! Please!!!
- Sun Visors
- Camber Kit Differences
- check engine light came on in my 91 accord
- Transmission leak some assistance
- strange idle problem
- Problem with the heating system, car blows in cold/warm air.
- replacing rear brakelines (hard lines)
- 192 degree thermostat in 94 Accord
- h22 swap into 6th gen accord (98-02)
- 90 drive axles popping out, replaced both of them, tried different set as well, anyone help?
- weird start issue?
- 92 Accord DX - Passenger Headlight (dim) will not work.
- Will Master and slave clutch cylinder for a f22 fit a f23a1?
- 1992 honda accord engine surge
- 92 accord wont start
- bit of sputtering
- Question regarding crank pulley bolt.
- 1989 Accord?
- spark plug tubes....please help
- Idle problems?
- speedo not working
- engine code?
- Quick Question...Stage 3 Clutch/Flywheel Set-Up...
- Temp and Fan Speed Lights Not Working?
- 95 accord odometer and speedometer work sometimes!!!!!!!!!!! help
- Wiring help
- 1998 Honda Accord v6 Coupe 2dr automatic fuel economy
- 1998 Honda Accord v6 Coupe 2dr automatic transmission problems
- dirty fuel filter = bad MPG...why?
- 91 EX heater not working. Help?
- whats your best mpg?
- taillights....
- 1992 Honda Civic LX hydrocarbons won't pass e-test
- vtec controller help...
- H22 for my accord?
- 95 Accord EX Coupe, A/C not working....
- 1998 Honda Accord v6 Coupe 2dr Gauge Instrument Cluster D4/D4 lights
- no spark on 1995 accord
- howl sound
- Where is the clutch bleeder valve??
- sway bar bushing replace?
- Stiff accelerator. Throttle cable?
- F22B1 fuel rail... which one REALLY fits?
- Update on hesitation under acceleration
- 98-02 accord manual - bt download
- transmission problem
- How do I troubleshoot my headlights?
- 1989 Accord
- 1994 F22B1 Transmission Auto to 5 - speed Info NEEDED
- 93 Bumper with Foglights
- Squeky Clutch Cylinder fix?
- Where can i find a hole through the firewall for power wire? 98 coupe EX
- CD5 with ABS issues
- 1989 accord LX-i issuses
- 01 Honda Accord odometer light change
- Head bolt torque f22a6
- anyone running a f series with p28? or other chipped ecu?
- struts for my honda
- 14:1 SOHC???
- h23 head into a f22a6 block
- car dies after 3 mins?????
- Ebay High flow catalytic converter/Test Pipe
- F series question
- f22 tranny/h22a tranny?
- accord problem
- help with accord
- 99 accord valve adjustment problem
- umm?
- exhaust
- slow engine warming up
- shift cables or tranny?
- Possible Starter blown?
- Mugen Parts
- poor gas mileage, cannot find HO2S sensor
- 95 accord lx overheating
- timing belt change
- 2002 Accord Brake problems
- 2000 4-cly EX. Q's. (ex. misfire, and turbo)
- M6 x 100 mm bolt
- 1993 Accord Muffler
- 91 Accord LX slowly dying, HELP
- Gurus help. Quick question on 97 Accord non vtec. Timing belt problems.
- 95 accord radiator
- Prelude immobilizer removal? (for my h22 swap)
- front end problems
- Timing Belt Gear
- weird suspension sounds
- Suspension mods - what's out there?
- Tailight question:
- Power Door Lock Actuator, Relocking
- 1988 LXi ATF EXCHANGE
- The sport button (S) light is not working fine in 90 EX
- Replaced distributor and code 9
- HELP:: 1997 ACCORD STEREO REMOVAL
- Spare Tire Rubs?
- ACCORD RUN ON LPG?
- Correct Tire Pressure
- Best Accord Swap
- Help an F/H family member out!
- 93 starting/running/codes question
- Oil Burning
- f22b1 speed sensor problem
- anyone knows where can I get this CD?
- 5th gen Accord drivers... what brand of springs and shocks are you using?
- act clutch causeing master blow out?!?!
- Need Held With A 91 Accord Auto Seat Belts & Instrument Cluster Not Working
- yet another problem with the car
- What could cause a "slow chug-chuging" on start up??
- Radiator fan... old issue, odd scenario
- Accord Picture Thread (discussion)
- need help key stuck in the switch.
- new engine or pay for a timing belt replacement
- Oil vanishing!!
- need help with 93 accord
- **Help/ Advice Needed** Loose area in steering and Emissions Code
- 98 accord transmission capatability
- ***Help*** Accord Won't Start (Fuel)
- 91 accord starting problems
- Pilot Custom fit round 3" fog lights
- Idle boucing when first started up and warm?
- Aftermarket intake's new MPG
- Does 94-97 accord auto trans interchange with 97 acura 2.2 cl? help!
- Is it possible to just clean an EGR valve? (not ports)
- Windshield wipers dont move on 94 Accord
- f20b sir and sir-t
- Having some problems with the locks
- 97 accord exr wipers
- 1992 Accord is failing emission test
- I reach 3rd gear and it starts to "jump" or "shake"
- 95 accord heating
- New to H-T.. just sayin whats up
- 94 LX Wagon.. Where is the CEL Jumper?
- 94 accord distributor leaks
- My Honda shop manual says i can adjust the fuel mix
- CEL P0740 transmission clutch control solenoid
- Windows, Tach, Speedo, Clock, Temp Gauge, Dash ndicators, all died at once
- 1997 Accord balance shaft knock?
- Loud Screeching Noise when Braking
- New to Honda, looking for a simple starting point.
- how hard is it to replace blower motor? 1997accord
- 94 Accord leather issues
- 93 Accord Ex-R
- honda accord 2.0.y reg
- Fuel Pump
- Help with Vacuum hoses
- Another overheating issue
- My dad's Accord is STILL squeaking...
- eibach sportline - rear springs aren't captive
- Weird Clicking noise ???
- 91 Accord rear wheel bearing
- 98 accord. Gauge cluster
- 1993 Accord on the fritz ... Help.
- 96 Accord Replacing complete headlamp
- new alternator question
- 95 Accord EX Smoking/Can't Turn Off
- Need help with 94 accord ex flexplate
- need a lip
- After Tranny Swap Speedo Problem
- Water on floor of passenger side of car after rain
- Radio Lights dont coe on...
- Valve Guide Seals
- Nooob Question i know
- Poor fuel economy, rough idle, no low end power
- 98 accord engine swap
- '95 EX Auto Accord w/ OBD1 H22 swap....what ECU?
- 95 accord
- Change thermostat, then car wont start
- h22 swapped accord hitting rev limit at 6500
- 91 accord ex wont start after cam seal installed!?!?!
- 2 wire to 3 wire iacv adapter plate - f23a1 intake manifold
- new intake... need help
- 1990 Honda Accord...Car trouble
