PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 [258] 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. looking for an exaust
  2. Temp Gauge is Flipping Out
  3. Trade my mustang for an Accord?
  4. coilovers won't fit???
  5. coilovers won't fit?
  6. short shifter
  7. H22a3 PS = H22a1 PS?
  8. 2 small annoyances with my 97 Accord
  9. speedometer problem '91 EX
  10. Temperature Rises, What Could Be The Problem??
  11. 94-95 lip
  12. Driverside Door wont open!
  13. Max spring rate
  14. F22 w/ F23 dohc head?
  15. got an 86 accord lx for $50.00 dollars
  16. What size are these?
  17. A few questions about my accord.
  18. WTB Green 99 accord front end!
  19. i think i have a bad throw out bearing.
  20. 93 Accord EX No-Start (No Spark)...Very Puzzled
  21. Best combo for a 04 accord
  22. Newbie here...Need help badly on how to replace my Starter on my 87 ACCORD LXI
  23. Camber kit suggestions for a '99 Accord
  24. Thank you Accord forum members
  25. next upgrade
  26. 2003 Accord clutch adjustment
  27. 93 accord what spring should i use to drop under .75-1.2inch?
  28. removing window decals....
  29. Honda emblem size for 5th gen
  30. Spacers and studs for a 5th gen...
  31. audio problems
  32. 95 accord turn signal doesn't work?
  33. engine swap
  34. twin carb on 89 accord
  35. H22 Header on F22 base
  36. H23 swap in a 91 accord
  37. balance shaft removal in an f22???
  38. Noise in AM Radio
  39. balanceshaft removal on h22
  40. Spark Plug Cables Help
  41. 93 Accord Lowered a little and Control Arm hits wheel well with Camber kit
  42. The ole "D4" Blinking symtom!!
  43. catalytic converter
  44. 1995 accord for sale in classifieds
  45. Oil
  46. need quick help - 02 accord lug pattern
  47. Speakers
  48. Short Shifter for 96 honda accord LX
  49. 89 accord power window question...
  50. shock install help
  51. JDM HALO HEAD LIGHTS
  52. Custom Short Shifter for 6th gen CG3
  53. Removing Adhesive?
  54. HELP!! TCS, ABS AND DASH GUAGES MALFUNCTION 2004 accord ex
  55. Exhaust Gaskets
  56. Big QUESTION, Please help
  57. 6th gen auto to manual VSS wiring
  58. Large Exhaust Tip
  59. 91 accord Projector Lights...Where can i get them?
  60. Howto: Fix Accord DRL Light Relay (pics, guide)
  61. 1994 Accord EX does't start consistently
  62. Is my manual tranny fluid leaking? (pics)
  63. Honda Accord 2001 ULEV Oxygen Sensor
  64. Mechanical Differences in engines.
  65. '94 accord ex Canadian tail light removal
  66. Accord Rough Idle
  67. That Smell
  68. few questions about H22 swap in 5th gen
  69. APEXI WORLD SPORT 2 EXHAUST 94-97 HONDA ACCORD
  70. F22A6 intake manifold
  71. F23A4 build
  72. help: JDM H22a into 92 Accord EX with auto tranny but no spark
  73. accord trans. upgrade
  74. 2001 Accord CEL, i need list of codes!
  75. Adding keyless entry to 1999 honda accord sedan
  76. Clutch Replacement Interval
  77. Where is the Daytime Running relay module?
  78. What mod should be next?
  79. Another Harmonic Balancer Question??
  80. Maintenance Light - How do you shut off?
  81. H22 motor and f22 Tranny???
  82. VAFC Pinouts
  83. Clutch safety switch on 92 Accord lx
  84. Shaking problem.
  85. Accord Tune up and Chip ?
  86. Auto to manual conversion on a 1992 Accord LX
  87. 95 Accord Coupe Mods
  88. what is this called ?
  89. Will a 95 Accord Tranny fit a 95 Odyssey
  90. aem v2 squeaky noise
  91. motor knocking?
  92. Engine Rod and Stroke Question
  93. Fixed TPS/EGR but broke this off...anyone know what is it / what it does?
  94. 2004 Accord Sedan Require Camber Kit on a 3"+ Drop?
  95. Got a new 05 v6 accord and tranny is kinda sketchy help !!
  96. Tire choice
  97. signal lights for my accord
  98. Can I swap 93 Accord rear disk brake into 94 Accord?
  99. Engine??
  100. 94 accord h22 with ecu problems
  101. Noob with a brake problem
  102. powder coating?
  103. ACCORD EX TRANSMISSION PROBLEM??????
  104. '98 Accord EX Coupe Stock Stereo question...
  105. Problem with DC Sports header
  106. FS: Stock block F23 turbo setup
  107. I'm a virgin
  108. Newbie here thinking about buying a new car
  109. FRONT LIPS
  110. G3 brake rotor screws stripped- am i screwed??
  111. loud noise from under hood.....sounds like an air leak???
  112. Another prop valve question....
  113. Possible bearing noise from tranny in 98 Accord DX 5-speed manual
  114. 92 honda accord damn accelerates itself
  115. Need wiring help
  116. My Accord has been doing sudden stops while driving. Could be battery... suggestions?
  117. saving money steering shake when braking
  118. #2 cylinder running HOTT!!!!
  119. jumping tach
  120. question about replacing cabin filter 99 accord, please help
  121. H23A Vtec putting it in 1999 accord
  122. Does 94 Accord LX Wagon auto comes with rear disk brake?
  123. NSX Manual Tranny to 6 gen v6 Accord
  124. EGR Problem...HELPPPP
  125. JDM BLACK HOUSING HEADLIGHTS
  126. Audio In Port 99 Accord
  127. 6th gen h22 swap - harness/ecu question
  128. Another NewB(To Honda anyways)
  129. how low can u go without....
  130. 3.2 type s?
  131. steering wheel shakes when i brake?
  132. Squeaking noise
  133. Help on changine auto to manual
  134. replaced fuel pump car still doesn't start 90 accord coupe lx
  135. Need help with swap. JDM 94 H22 into 94 Accord LX cpe
  136. Help!! My daily driver is down & I want opinions
  137. 6 speed for the f22?
  138. Shake when I brake
  139. I'm a newb here (kinda)
  140. Vibration in gas pedal
  141. my accord shudders when i accelerate..what can it be
  142. will accord 96-97 front bumper cover /grill fits 94-95 models?
  143. drum wont fit on right side????
  144. 02 2.3 motor and trans in a 93 accord
  145. Is this legit?
  146. HELP! I got a 89 Accord and theres a clicking noise when I accelerate and white smoke!1
  147. where to find 96 door panels...can't find anywhere
  148. air condition problem...
  149. EGR valve
  150. Code 41 for Accord 91?
  151. 92 accord EXR probs Elctrical guys well anyone with experience
  152. H22a Engine Build/Uberdata, Looking for Basemap....
  153. timing belt
  154. Accord History
  155. how to install body kit
  156. need help with mounts
  157. 1994 Accord won't start
  158. Tire size
  159. which head type is this? p13 hf-1
  160. 93 accord rear seat removal
  161. Wholesale Accord Parts
  162. Tips on how to bring back the lustre of the paint?
  163. 92 Accord Oil leak by Oil filter
  164. 92 Accord Tail Lights don't work
  165. h22 install prices?
  166. 94 accord fuses
  167. 94' F22 Valve clearences
  168. '95 Accord Airbag Brain
  169. will a 94-97 turbo kit fit a 90-93?
  170. Need an answer to some ?'s... QUICK!
  171. 99 Accord odometer and climate control area lights are out
  172. GAS LEAK!!!
  173. Speed sensor
  174. tire size
  175. 01+ Accord/Oddessy owners..
  176. Starter replacement 91 Accord
  177. Skunk 2 or Apexi
  178. driving noise from front wheel(s)
  179. Speed Sensor on ebay?
  180. How Do You Replace Rotors on 90 Accord?
  181. dust shield/mud guard removal
  182. 96 accord (tranny trouble?)
  183. 5th Gen | H22 | Skunk 2 IM | Which CAI fits?
  184. need a title for an 96 accord..sad story.
  185. Energy Suspension Hyper Flex System in a 4G Accord
  186. Motor mounts
  187. Accord info.
  188. cannot remove pcv valve
  189. Fitting a j's racing intake?
  190. f20b in a 4th gen ?
  191. sohc vtec d16 into a 85 civic sedan
  192. Help with timing belt?
  193. Clutch Goin out?
  194. JDM accord headlights...
  195. need help with center console lights in 03 accord
  196. peak/hold resistor question
  197. 5th generation Accord
  198. Questions about 89 Accord
  199. Connecting Ipod to 04 Accord.
  200. has this been talked to death? K-series ?
  201. uneven spark plugs
  202. Ever installed the air conditioning?
  203. newbie with a few questions
  204. 5th gen v6 trunk same as the 4 cylinder model?
  205. 6th gen F23 turbo oil return location
  206. 97 ex.. removing radio
  207. how do i hotwire my lighter outlet?
  208. Transmission problem?
  209. ABS modulator
  210. Tec advise
  211. owners manual?
  212. Radiator flush & fill question, plus what brand of antifreeze?
  213. -1990 Accord Technical help plz
  214. climate control AC button gone bad??
  215. Need Help on a Rear Bushing!!! ASAP!!!
  216. grinding in 5th gear
  217. Engine light on
  218. clicking and oil in cylinder?
  219. Engine Code P420: Catylist System below Threshold
  220. My sleeved/ turbocharged F22a1
  221. Quick Question
  222. Please help was running and now it wont.
  223. Carfax
  224. My friend just broke a bolt on the valve cover.....what now?
  225. 96 accord vtech motor into 90 body
  226. Black Widow Side Skirt Install
  227. few questions please
  228. Turbo Accord Owners post your turbo setups.....
  229. 91 LX Clutch Problems
  230. Cross drilled rotors: A Mistake?
  231. hey HENRI stop being a turd
  232. Brake fitting stuck...what can I do??
  233. H22/H23 Accord Swaps Gas Mileage
  234. how are all you turbo accord's engines doin?
  235. What do u guys prefer. F20's or H22 on a 98-00 Accord?
  236. help with engine removal!
  237. Gen6 3.0 convert to Manual. Is it reliable in the long run?
  238. honda accord 02 to euro r conversion
  239. accord 96 v6 turbo!
  240. Is the prelude f22 block the same as the accords F22B2?
  241. Removing the dash on a 2002
  242. it's about time
  243. Question on rotors for a 97 Accord.
  244. 5th gen auto to tiptronic transmission
  245. 5th gen H22 EGR Help
  246. Where to find
  247. '89 accord parts for sale...
  248. h22 in a 3rd gen accord lxi
  249. Loud rattling or chattering noise at high rpm (5000-6000)
  250. Is a spark plug a spark plug?
