newbie changing brakes
Old Jun 15, 2003 | 11:33 PM
LoneReaper's Avatar
Default newbie changing brakes
I have searched all through here, yahoo, google, ask, etc and i can't find pics and instructions on how to change pads and rotors on a 94 accord LX i found a few things about the stupid setup with joints and etc. can anybody link me to a site that has step by step instructions. Thanks
Old Jun 16, 2003 | 06:47 AM
D21X's Avatar
Default Re: newbie changing brakes (LoneReaper)
buy a haynes manual. lots of info in there. oh btw, getting the bearing/hub/rotor off the spindle is a biatch, and dont pound the bearing or it will be damaged and u will have to replace it. i would just get the bearing/hub/rotor pressed off the spindle. it'll run u at the most $80 to press both sides off. brake pads are a piece of cake tho. goodluck!!!
Old Jul 1, 2003 | 06:45 AM
Donald F's Avatar
I am also trying to change the rotor on a 93 accord LX. Do you have to remove the Spindle to get the rotor off? Thanks
Old Jul 1, 2003 | 10:14 AM
bacal36's Avatar
Default Re: (Donald F)
its harder for the 4th gen (from my experience) because we have a pressed rotor... I took mine to a shop to get it done.
Old Jul 1, 2003 | 10:37 AM
D21X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donald F &raquo;</TD></TR><TR><TD CLASS="quote">I am also trying to change the rotor on a 93 accord LX. Do you have to remove the Spindle to get the rotor off? Thanks</TD></TR></TABLE>
if u can remove the bearing/hub/rotor off the spindle then no, but most of the time u cant because it is rusted on so u have to get it pressed off.
http://website.federal-mogul.c...1.pdf
here's a site iono if i posted this yet, but when u go behind the rotor to get the 4 bolts off, it's hard as hell to get it out of there, thats why u have to remove the spindle, take it to a machine shop to press it out. goodluck!!!
Old Jul 1, 2003 | 08:52 PM
TypeSH's Avatar
Default Re: (D21X)
my solution to that, buy longer 10x1.25 bolts, around 60mm threaded completely down the bolt. Screw them in lightly in place of the 12mm ones in back, and pound away w/ a hammer, cris cross pattern til the hub+bearing fall out of the knuckle. Dont do it to the stock ones, you may ruin the heads of the bolts tahts why.
curtie94
Oct 12, 2011 12:04 PM
Jetro
Jan 7, 2011 12:19 PM
crazykarlnow
Aug 28, 2007 05:22 AM
Joetravelall
Feb 20, 2007 03:25 AM
LillDragun
Jan 23, 2004 10:35 PM
