View Full Version : Honda Accord (1990 - 2002)
- Opinions on a 99 Ex 5-spd?
- trouble with 5th gen interior, easy, please help
- EX motor into LX body- What should i expect?
- 88 Accord Clutch/Tranny Problem...
- Exhaust Question
- rear brakes accord '95 LX
- Idea for making window switches light up on our accords..
- i need some advice for kits...
- Just bought '87 Accord LXi and...
- whats up with this P13ecu chip!! (91 accord h22a)
- knocking noise coming from the front?
- Front end and mild rear end shake
- ECU Code list for Odessey?
- 03 cl type s or 03 accord v6 coupe
- Amazing...British Accord Hatchback Com
- Gemeration explanation
- Question on my h22a swap!!!
- What tire size for 19s?
- 2000 accord "brakelamp" on
- Battery/cable replacement
- Door Won't open >door actuator
- The way it shifts......
- Conversion: Accord SM4 Manual to Automatic Transmission
- How often to change oil on Accords not driven too much?
- engine noise,,,help??!!
- MSD ignition package >> I need some help please!!!
- The cheap accord cat-back exhaust....
- Ciger. outlet not working on 6th gen coupe v6 (99)
- oddometer quit at 204500
- Anyone have an extra ICU?
- H22 Tranny / LSD Question
- 02 accord SE factory alarm problems,
- Road Trip Coming up!
- "Sports" light always on.
- 05 accord lx wheels
- can i put 5w40 in my 03 accord LX?
- Wheels on 6th gen
- OOPS! simple simple simple!
- accord euro R
- people with auto to manual swap
- wanted:shell
- need help with timing belt
- Mant Required
- 1992 Accord rotor replacement
- Black Rim /w Polished Lip 4 ACCORD
- Black clear coners and Headlights
- accord code
- Are these Ture Sizes o.k. for Stock Accord ??
- wire harness different or not
- could a sledge hammer break a body kit?
- surging at idle help
- f22 turbo
- can you UBERDATA a POA ECU
- Sorta a sad situation
- Lont Time on Speak (Looking for a good Turbo Kit)
- Painting urethane parts?
- rev limiter on new accords
- ok ive done all the searching i can stand auto to manaul swap on my 93 accord lx
- acura cl 97-99 = 5th gen accord???
- window regulators and carbs
- where is the linearair/fuel solenoid on a 92 accord?
- h22 problems
- 1999 Accord EX 4 DR 2.3 VTEC 4 Cylinder Oil in Coolant`
- My power atenna is busted and it is making a noise..
- 95 honda accord help///<<dumb girl w/ a car
- spark plug help
- 1996 door lock actuator..(researched) questions.
- intake any1 ?
- JDM DOHC F22B Engine... Will an H22 tranny FIT?
- How to unconnect this wire?
- K Series in 5th Gen
- anybody sellin Turbo manifold for F22B USED OR NEW
- 4 to 5 lug conversion(6th Gen)
- what the heck is a linear air/fuel solenoid
- Can a bad EGR valve cause bad gas milage
- Tranny problems...
- 96 Accord Stupid lock actuator..(researched) questions.
- Maintenance required light.
- rain x = fog!!!
- 1990 accord automatic not shifting correctly.
- Project G21 (H23A1 + F20A)
- Location of A/C compressor clutch relay 1990 Accord
- air bags
- 97 TL
- Should I retire the Accord?
- h22 swap in 91 accord
- accord 90 ex-r heat problem
- need help tanny prob, code p10715 1997 accord automatic
- 91 Accord LX with transmission problems
- 94 Accord,Many Problems
- New Accord Owner
- Gathers CD player
- Help diag. brake switch
- help a new member
- P1491
- Using an OBDI distributor
- i Cant find the fuel pump relay
- where is the pcv valve located on my 1988 honda accord??
- 1999 honda accord engine wont start
- Oil change
- stripped bolt threads on block
- Accord shakes when i put Brakes
- 88 accord motor swap
- HID Lights for an '05
- winter beater help!!!
- So i wanna get some new rims...please help
- REFLASH PCM?
- 97 ACCORD STEERING CLICK???
- Accord Lip ANY1?
- hmmm transmission probleM??
- cd changer question
- how to remove hood emblem?
- 92 Accord LX jerks going into revearse
- Need paint in Wisconsin (midwest - tristate area)
- need to replace calipers on 2000 accord
- Can't get Lower Timing Cover on 97 Accord reinstalled - Pls Help!!
- Problem with Rear Brake Caliper Piston
- DRL - daytime running lights
- rim 6th gen
- is it worth it?
- 94 accord, ex - 4 cyl: best appraoch to r&r automatic transmission?
- Engine Swap Question
- axles for 92 accord h22
- '91 auto - lockup control solenoid going bad?
- 92 accord rear bumper falling off do to rust?
- ewwwwww( the curse continues)
- no codes
- Ball joint removal for CV axle removal help.
- gotta question...temp going up???
- Accord Clear corners ?
- anyone make a chip with f20b maps for obd1 ecu?
- 18" wheels for 03 Accord
- New accord. SHoul be modded right off the bat?
- Alternator
- Auto Tranny Q
- yellow lumics on black projectors?
- Intermittin problem when staring, need ideas
- accord 93 coil diff than 92?
- TIRE SIZE ???
- 94 accord with 96 front end? whats needed?
- Help!! Hit a pothole - whole bunch of damage...
- Help. Door wont open
- skunk2 springs
- stick too long
- help with car shaking
- Does anybody know......
- Megan Racing Products For the Accord
- Gauge help
- should I turbo my F22B2?
- will the chrome grill fit in a 94 LX 4 cylinder?
- I A C VALVE
- JDM Accord with Volk wheels and nitrous
- Seat Question
- painting 1990 honda accord ex stock rims! : )
- retro fit 96 accord?
- Accord v6 light problem
- custom exhaust cost
- 88 accord. when clutch depressed, wants to die...
- OFF TOPIC - 97 accord......pulleys
- motor rocking/shaking too much
- 95 Accord - Another Suspension Problem
- 98 EX Coupe - Dash lights out
- itbs... where to run vacuum lines?
- Honda TSB help
- Wheel Hubs
- help with adjusting valve clearnace
- What color black was the accords in 2002?
- last second suspension advice
- 1990 Accord Drivers Door won,t open
- please help with cel
- 89 Accord Sputtering Problem
- 5 spd Parts list ?
- need little help 01 accord
- accord engine Q
- 95 Accord SRS light light on even after reset
- inoperable temp gauge
- rim off set for 98' accord?
- turbo a 90 accord w/ a 94 f22 head?
- no spark
- Window Wont Roll Up
- 1990 honda accord is the new K car?
- Questions about my 85 Accord LX
- Update time for the 'basic guide'.
- Need help!!! rotor problem
- 90 accord trans
- 96 accord exhaust buzz
- SPRING INSTALL
- H series into 5th gen
- H23 DOHC VTEC
- Is there a link to: F22B1 into 90-91 Accords?
- whiteface gauges for cd5...???
- RMF = Randy Monroe's Finest on my CB7
- Traction Control System - 2003 Honda Accord Coupe
- engine degreaser
- What would be better for me
- AutoShifting and chirping Tires!
- question on new accords
- 95 Accord Automatic Shifter
- k24a1 piston dome?
- Bought a beater - Someone tell me something about it, search blows.
- '04 Accord V6 won't crank
- After throttle body spacer install....surging idle
- Speedometer & Odometer not working
- new to this
- 4th gen JDM/EDM Armrest in black
- 5th gen airbag
- rear lip install help 96 accord
- sylvia rims on a 96 accord?
- 2002 Accord engine reving
- can i and how can i swap a integra Ls non Vtech moter in to a 1992 are 1996 accord
- 1997 power door lock problems
- 94 Accord won't start when on hill, front is higher than back, and it sit's for 12 hours in the cold
- 91 Accord Won't "Lock" In Park
- 97 accord EX "msd ignition distribuitor cap" ???
- Accord late-93 ignition barrel- key stuck in lock.
- 1/2-finished suspension install
- how to install parking lights on 92 accord
- how to install a fully automatic antenna on 92 accord
- P1259-VTEC System Malfunction
- transmission fluid analysis automatic
- 1989 Accord - Buzzing noise under carb...
- Accord 98 LX dying constantly
- Neuspeed sport springs
- accord coupe front bumper cover swap
- Honda Accord Seats 1988
- Is the exhaust for a 5th gen 6cyl the same for a 4cyl.
- head bolt options, 95 accord VTEC?
- Honda Accord 3.0 liter '98 Catalytic Converters
- AM Radio noise when Directionals are on
- Auto-2-manual question
- Questions about NITROUS.....
- Accord w/ jdm H22 here can i get a motherfucking cap
- clunking noise
- emergancy lights
- OIL Question
- TRANSMISSION, quick question?
- Picked up an 06 Last Night
- AC/Heater blower sometimes quit.
- Help i have a automatic tranny problem
- HELP!!!ACCORD
- how to remove needles from gauge cluster
- looking for 90-93 accord lip kits???
- 03 Accord Scrambled Radio
- timing belt change
- DIY DRL hibeam?
- accord brakes
- 5th gen: LX and EX compatibility
- 90 accord ignition problems
- 97 accord new motor and ish
