View Full Version : Honda Accord (1990 - 2002)
- H22 head on F22 Motor????
- what is this sound
- transmission
- Gas tank capacity
- Need PN for water neck from Upper Rad hose to block
- 93 Accord SE with fluctuation of idle at 1200rpm to 2000rpm....
- brakes
- Product review: new exhaust install (non-performance)
- I have a few problems
- Honda Accord Euro R Service Manual ?
- 2000 accord missfire problem
- how do you take out the air filter resonator?
- part numbers
- F20B swap
- 91 accord headers
- 97 Accord won't start, burning out rotors/distributor caps?
- fuel delivery...
- Help needed - think garage doesn't have a clue
- Need advice on a NEW (17K miles) 1994 Accord....
- Problem after starting!!!
- "starting air valve" on Euro R intake manifold??
- 96 accord lx vs ex exhaust
- Rough idle
- Other Honda/Acura Model Injectors
- I know everyones heard this before but im gettin suckered into an ebay turbo kit
- POTHOLE
- transmission - shifting hard, slipping - 98 accord lx
- 1990 honda accord ex hard starting when cold
- Weird Electrical Problems
- Exhaust upgrade, worth it?
- thread size for top motor mount??
- Brake Rotor replacement spec?
- Auto trans torque capability?
- h23a1 head + f22b2 block = ?
- Help!!! Brake Light/turn signal problems! 2000accord/ex/v6
- My First Post
- 95 EX V6 occassionally doesn't start?
- Looking at a 1998 Accord EX V6 with 1HG- VIN#
- Installing Strut Bar
- advice on shocks
- does anyone know where
- Blown head gasket or something else?!
- CAR STALLS!! HELP!!! v6 accord 98
- Honda accord 2000 4dr TAILLIGHTS
- need to know if this swap can be done
- Lowakkord signing in.
- how to get to corner lightbulbs on 99 accord
- Spoiler removal
- 94 Accord O2 Sensors?????
- dc headers ceramic coating
- water from tailpipe
- HELP with broken axle!!!
- oil dipstick
- Cranks but doesnt turn over. This morning. HELP!!!
- HELP!! Surging idle on 2000 Accord 4cyl
- update on my friends 97 accord problem. We got the engine codes. Help?
- Stock F22 HP/Torque curve
- 99 accord suspension
- No Signal to ECU
- 94 Accord DX tranny problem?
- overheating 95 Accord EX I know its the fan but what needs to be replaced
- quest. what years change?
- Starter problems
- can I use a manual throttle body on auto?
- tire
- Need the advice of someone who knows automatics
- cost of a auto tranny rebuild
- 92 Accord EX 4 cyl - tach reads low at idle only - approx 200~500 rpm
- Cooling fans always going on after parking the car?!
- Temp gauge falls to "C" in WOT
- 92 accord with oil soaked spark plugs
- Oil Leak!
- oil leak
- spark tube oil leak.. looking at gasket sets.
- How to light front bumper lens?
- 98 Rear Drum Brakes: Fluid or grease leak?
- proportional valve help
- Check Engine light
- rebuild a tranny 94 accord lx auto
- 1989 lxi idle problem
- How can I make it faster?
- 90-93 coupe exhaust request/question...
- DTC P0441
- idles irradicaly and no power at all.
- oil in radiator
- turbo or supercharger
- modulo lip on 5th gen accord
- ?CEL WITH 0BD2 - OBD1 HARNESS?
- 2 CEL codes & a puddle of fuel...
- Milk Shake in COolant Reseroir
- Needles In My Gauge Cluster
- will ex accord greddy headers fit my lx accord?
- 1994 Accord 2.0i wont start?
- F22/a/b1/b2 F23(sohc) mounting
- warranties..?
- 1986 Honda Accord Rough/Surging idle.
- Radiator fan sensor help please
- Port and Polish Head - F22b1
- UPGRADING A 97 ACCORD TO FOG LAMPS AND XENONS... HELP NEEDED!!!
- knuckle question
- 99 accord oil in the radiator
- how is the best way to drain power steering fluid?
- one headache to another no start h22 in 97 coupe
- 95 wagon??????????? help me??????
- 98 - 02 Accord/CL wheel fitment
- V6 MOTOR MOUNTSs....HOW MANY ?
- Noisy valves : Will seafoam quieten it?
- Need help.....car won't start.
- auto to stick conversion NEED HELP PLEASE
- 97 accord window problem ...
- 94-95 Accord Amber Bumper Lights
- Accord Fog light question
- Tune up mileage questions
- power steering fluid bubbling after alternator replacement
- 99 Honda Accord Help
- I put Too much oil in my engine
- intake manifold
- Problem with Headlights
- Do I have a bad wheel bearing, or a bad inner CV joint?
- OBD2 - OBD1 IAC sensor problems..........HELP!!!!!
- 92 accord manuel shifter problems
- suspension help please!!!!!!!!
- 98 v6 accord idle screw((FACTORY SETTING))
- skunk 2
- '98 Accord won't go out of park
- 2000 Honda Coupe - Door is CLOSED, and handles are broken
- 1989 Accord - Can't identify the source of a fuel leak.
- want a light bulb that gives better visibility at night.. any suggestions
- Bulb Question
- 95LX - Muffler -$70 installed - Good price? Need a quick answer please
- Cabin Filter
- Inspire
- 1998 LX stuttering/jerking when i press the gas... help!
- headers
- f22b turbo thread
- Brakes starting to squeak! :[
- Just seafoamed today! Pics & flix
- Timing Belt Shopping list. (Just wanna make sure)
- Car cuts off after i shift it into Reverse
- h22
- Aftermarket LCAs?
- 1994 f22b1 into 1993 accord
- Depo Headlights Question.
- car sounds like it's going to fall apart after brake job.
- Engine starts running rough while driving, then CEL comes on and smooths out
- Break Light Problem
- Maintenance Light blinks 10x...
- 92 accord wagon exhaust
- '97 Accord auto tranny - is there a filter of just the "strainer"
- Auto-x wheel size
- 1994 Accord routine front brake and bearing job .....it started off SO easy !
- turn signal issue
- idle problems ??
- What ARP bolts to use ??
- Acura 2.2 Cl HELP PLEASE!!!
- Usdm H22 / JDM H22 / F Series Oil Pans... The same or Not?
- 94 accord h22a4 idle problem
- Running lights stay ON, headlight switch? 94 Accord
- H22 swap question
- idle problem
- Seafoam
- 94 Accord HID problems
- racing seat sliders/brackets
- 90-93 Accord Automatic Transmission Noob Question
- Noob Question about F20b
- low mpg. and smells like gas inside car.
- Check Engine Light : 1996 Accord
- Stock Alarm Problem on a 1998 Honda Accord
- So what happens if you put fuel injector cleaner in when you got a full tank?
- H22 swap in a 95 Accord coupe question.
- 1994 Honda accord No spark
- Broke my radius rod on my 92 now i cant get it out! HELP
- 90 accord coilover damper kit
- Problem with Temperature Dial on 96 Accord LX
- re: idle surge IACV problem? NO CEL
- help me with exhaust stuff!
- 98 Accord Catalytic Converter Nuts / Bolts
- im having problems with problems with gas mileage
- 1999 Accord 3.0 V6 MISFIRING like hell
- 94-95 accord, will 96-97 tail lights and trunk bolt on and look ok?
- 93 accord sunroof problems!
- Problems with my CD coupe input please
- Windshield
- Screech sound when cranking (95LX)
- 91 Honda automatic trans. problem
- 90 honda accord won't start! help
- which motor to use daily driver all motor.... f20b or h22a
- RHD Accords?
- Odd MAP sensor problem
- Brake pedal, low!
- Pass. Brake light won't light up
- Thinking about getting HIDs, but wanna keep the factory housing.
- 91 Accord EX, 5sp transmission trouble
- car chugs in low rpms, something is NOT right
- help with h22 accord axle setup.
- Camber kit suggestions
- idle surge
- Interior stinks when it rains !
- control arm help
- f23 h22 5th gear
- 1994 accord Shifting Revs
- f23 headswap ( in progress ) pics
- window bashed
- f22b swap in 95 accord lx
- Clutch or torque converter?
- Dumb base idle question, I've searched the forum...
- F22s: which is best and why?
- keyless entry ..wont work in 97 acord se w/ obd1 ecu???
- rev to 5000 rpm and goes flat wont rev past
- Radiator Leak
- my speedometer is going faster than what i'm really going.
- OBD2 connector location on european Accord 1.8L LS from 2001
- 96 accord ex - v6 - banging sound
- is this possible swap
- cg accord turbo
- what should i do?
- lock actuator? locks not working
- cooling fan keeps coming on
- axle problems need help?
- H22 Starting Assistance
- '93 Accord no spark.
- H22
- 12V Red Wire For CD Player Not Hot
- 2001 accord v6 auto trasmission problems - what do I do?
- how to adjust idle on 93 accord
- Too rough for a daily driver? Maybe overboard?
- 1992 Honda Accord 198,000 miles. $850 is it a good deal?
- noob question
- Camshaft
- Headlight bulbs ???
- noobie help on a 95 EX Auto
- power outage
- looking for rims/parts for a 91 accord
- Klunking noise in front end
- Auto Transmission shot?
- instruction for installation of door handle
- Oil Light turns on
- 2001 Accord doesn't always start
- A couple of tune up questions here
- f22b1 what flywheels fit?
- Oil mount?
- high idle at start
- wipers don't go all the way down
- Lubricant Sealant
- Crankshaft Oil Seal???
- 55.9 mpg 2000 Honda Accord Ex
- ***New to the site***
- 1999 Honda Accord 4cyl with idle problem
- Good experiences
