PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 [338] 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. My car got broken into and i need help please !!!
  2. tranny return line slipped off...major damage?
  3. Best mods for a Stock 94 Accord 4 cyl/5 spd
  4. 2000 Accord V6 problem..help please.
  5. oil coolers: more power and/or more engine life?
  6. oil filter?
  7. Chassis codes for Accords
  8. brake lights not turning on, Help.
  9. I've never seen these OEM foglights on a 94-95 Accord...
  10. Head gasket Symptoms
  11. Why don't accord's have tranny filters?
  12. Greddy over Apexi
  13. quick help.. what size is the hub nut?
  14. f20 swap worth it?? help me out people!
  15. 98 Lude SH engine in a 95 Accord?
  16. questions about doing Accord brakes
  17. another weird problem.
  18. installing 1998 Honda radio into 1995 Accord
  19. over revved!!!
  20. Offset of Accord V6 15X6.5 steelies?
  21. manual accord v6?
  22. need assistance on h22 swaps and parts....
  23. my engine is seriously IDLEING, please tell me why?????
  24. 87 Accord-oil in breather
  25. FINALLY ! Throttle Body Spacer is on.
  26. Accord won't start
  27. For those with the V6 manual
  28. H22a Accord P/S
  29. 1990 Accord Tranny
  30. Will an 03' civic Si muffler fit a 90-93 accord with modification?
  31. accord with h22a1 turbo
  32. all motor or FI?
  33. Maximum Spacers allowed on 91 Accord EX rear camber, the bolt/washer type?
  34. 4TH gen tranny went bye bye on friday!
  35. Need some help/advice on the accord.
  36. Clutch, labor prices
  37. change brakes and cars shakes a lot.....
  38. pics of interior?
  39. Brand New 2003 Accord 6-Speed - HIT IN DEALER's LOT prior to pick-up. What would you do?
  40. 2 quick questions about f22b1 intake manifold
  41. tires
  42. window trim question
  43. Problem with Lighter?
  44. 6th gen seats in 5th gen
  45. Cam's
  46. chassis code question
  47. motor swap recommendations for 93 accord
  48. D4 light flashing
  49. B&M Trickshift Auto tranny fluid
  50. Rod knock
  51. 97accord clutch is slippin????????help anyone
  52. What is a easy swap for my 89 accord
  53. Fuel Pressure Regulator...
  54. 87 Accord eratic Idle?
  55. In the market for a car.....questions
  56. h22 vtec distributor
  57. EGR block (disable system how to)
  58. Intercooler fitment? How big can we go?
  59. Turbo Kit
  60. Fuel Pressure Guage
  61. What year is the Coupe Milano Red?
  62. should i worry about this problem?
  63. Head Gasket for H22a
  64. '98 Auto trans
  65. '98 OBD-II MIL codes, general question
  66. HID lights-H4?
  67. h22a engine with f22b1 g/box probs
  68. question about recaro seats...
  69. changing fuel pump on 6th gen
  70. klunk klunk noise
  71. 94 window regulator replacement!
  72. stroking accord v6
  73. do oil, fuel, tranny fluid additives really work?
  74. prelude/accord brakes
  75. h23 vs h22
  76. which sparkplugs to use? for turbo accord
  77. --==Cold Air Intakes for $50==--
  78. H22 Crank?
  79. no spark
  80. cv axle... replace myself?
  81. what tool to use to cut hole bigger for CAI install? need help now!
  82. Key doesn't want to leave ignition
  83. DIY intake..?..
  84. Throttle body for F23A1?
  85. Recommend to do/change/fix on 98 accord??
  86. H22a swap in 5th gen reliable?
  87. Skunk2 rear lower tie bar for our fattie
  88. Getting cruise control to work
  89. 91 accord ex oil leaks into spark plugs
  90. 4th gen tranny swap
  91. 97' Accord EX fully loaded with everything from the factory except..
  92. b4/after injector data from RC
  93. Doing brakes this weekend, got some questions...
  94. camber question
  95. anyone have5th gen pictures of bolts for transmission mount?
  96. can anyone lend a stock accord airbox (1990 coupe) for smog? *bay area* ca
  97. 4th gen exhaust
  98. 94 accord Alternator upgrade!! need help!!
  99. hard to replace gasket?
  100. h22a ecu's
  101. need help on door panel removal...
  102. need help
  103. Newb Question
  104. Suspension/ fuel questions..
  105. f22a1 turbo manifold
  106. fog light switch wiring diagram
  107. Fast Idle Thermo Valve on F22B1
  108. Turbo Mani
  109. need turbo piping help ASAP!!!!
  110. temperature gauge
  111. Auto to Manual conversion for 92 EX
  112. 94 door panel replacement
  113. damn weather control light
  114. CAI install for 4th gen
  115. no boost or nitrous
  116. SoCal People
  117. jet performance chip
  118. tranny prob's 94 accord ex
  119. My new Grocery Getter gets hit after 2 days! ! !
  120. my tranny is going in a limp-in mode
  121. 91' exhaust
  122. disc conversion on a 4th gen
  123. 98-02 Accord ECU Diagram
  124. h23 on a f22
  125. how to bleed and abs unit
  126. egr question
  127. Positive intake pressure?
  128. Need help.. 94 accord wheel bearing
  129. Best Exhaust system for 98-01 Gen ACCORD?
  130. $300+ for a 30,000 routine maintenance for a '99 Accord (4 cyl)
  131. removing front bumper/headlights
  132. 87 Accord - Fuel filter
  133. whats the difference between H&R springs between 90-93, 96-97 compared to 94-95
  134. Questions about H22 swap
  135. Smell from exhaust
  136. 87 Accord reverse lights
  137. bGround wires Control?????
  138. Can someone help me figure this out...
  139. need to replace rear light
  140. 92 EX rear sway bar on a 90 LX, will it go?
  141. Connector Issues, Please help
  142. driving without gas cap, good or bad?
  143. changing motor mounts?
  144. potholes and suspensions
  145. MY turbo Accord
  146. Brake master cylinder problem?
  147. 85 accord for $500, what swaps are possible?
  148. Exhaust Problem?
  149. i was just thinking.... fluidyne civic radiator in a 94 accord?
  150. OT: GB on apex'i exhasut/electronic..CHeap!
  151. need accord owners help
  152. The passenger side headlight (low beam) wont work.
  153. h22a swap
  154. ECU pinouts or wiring diagram
  155. Another radiator question (it has to do with the tanks)
  156. how to program an Automate remote?
  157. If you hear a rattle in the 03 accords, check this out first.
  158. lsd tranny ?
  159. zeals??
  160. injector cleaner in gas?
  161. timing belts and stuff
  162. Car makes a NASTY squeeling sound!!!
  163. Serious radiator problem.
  164. 94-97 accord questions
  165. wiring vafc for 03 accord v6
  166. abs brakes
  167. The 5 lug swap topic ONCE AND FOR ALL
  168. accord swap
  169. old injectors
  170. How to get rid of engine statics?
  171. stock prelude intake fit my car?
  172. Engine swap into a 1988 Accord Lxi Coupe
  173. auto to maual in obd2
  174. Installing H22 in a 95 Accord EX Automatic
  175. Ebay parts
  176. OT:What the Hell?
  177. VAFC code 22 questions??
  178. Fuel capacity for fourth gen?
  179. Dsm Fuel Injector question(for boost)
  180. Brake pad needs changing...
  181. wiring harness
  182. accord rotors
  183. F23a1 in 4gen accord? need info--is it worth it?
  184. swap question
  185. Fuel system questions, elementary explanation
  186. Stock 0-60 times
  187. Problem with KONI's on 90 Accord 4 Door
  188. Anyone know about engines from Raceup.com??!!??
  189. Niedejb I have a question if you could help me
  190. Really Fast Tire Q.
  191. which company makes a mast for the power antenna for 94 Accord?
  192. brake pads
  193. air condition compressor swap
  194. heating, cooling system not working
  195. Timing marks on 90 accord
  196. lowering a 94' accord..
  197. quick question about suspension
  198. Where is the communication port connector
  199. Newest year can swap out 89 honda accord dx with.
  200. NOS, Nitrous Express?? Which is better, cheapest place to find?? Couple of Q's
  201. h23a questions
  202. f22 turbo manifold
  203. Driveline Vibration at 5 mph / 1500 Rpm's???
  204. AT to MT
  205. Brake light On.???
  206. skunk2 studs
  207. help with slow starting
  208. SRS Light came on after taking out seat! Can some one link the "paper clip DIY" for me?
  209. help...... my brother in laws 95 ex is blinking non-stop
  210. 94-97 Accord Ingalls rear camber kit
  211. Exhaust Questions
  212. front right blinker is out.. how to replace?
  213. racing hart wieght
  214. 92 accord ex heater core
  215. heater core
  216. 91 lx cruise control not working
  217. Is it my axles or my tie rods? makeing SQUEEKING NOISE
  218. obd-II ecu wiring diagram needed
  219. what are the best type cams to get for f18b motor
  220. Cold air Intake in a f18B motor
  221. Differences between 90-93/94-97 Accord suspensions
  222. bad starter?
  223. what year prelude intake manifold will fit a 95 accord?????????????????????
  224. got a question about 87, accord hatch LX-i FI?
  225. 88 accord question
  226. engine back in the car (PICS)
  227. Window slipping out of place when rolling up/down...any fix?
  228. evap prob
  229. possible solution
  230. Spring/Shock Install
  231. Driver's side door sticking..
  232. h22 oil burners
  233. 2000 V6 Accord vs. 2000 Jetta VR6
  234. the price of my car? if to sell for American Dollars...
  235. 94-97 Accord Owners!
  236. high output alternator
  237. Accord Service manual....
  238. auto tranny.. where does this hose go?
  239. Depressurizing the fuel line before fuel filter replacement?
  240. Opinions on clutch and pricing?
  241. Techna-fit brake lines
  242. Another One - 2001 Prelude Rollover, 25k 5spd - $3k - LOS ANGELES
  243. car wont start cuz its so cold??
  244. 2003 Accord Engine Swap
  245. Update: Thinking about buying an Accord, which years are better?
  246. accord 4d = 2d seats?
  247. Airbag Install Cost
  248. crazy idle after trying to adjust?
  249. wiring for a vtec light
  250. Possible salvaging of 91 accord....
