what parts for obd1 conversion?
Old Jun 16, 2003 | 06:29 AM
brega3's Avatar
Default what parts for obd1 conversion?
what parts do I need to do a obd1 conversion? and is it hard to do? thanks
Old Jun 16, 2003 | 06:40 AM
btlfed1's Avatar
Default Re: what parts for obd1 conversion? (brega3)
conversion harness and obd1 ecu. Plug and play
Old Jun 16, 2003 | 07:21 AM
brega3's Avatar
Default Re: what parts for obd1 conversion? (btlfed1)
I have the ecu where can I get the conversion harness? and for how much I could get it?
Old Jun 16, 2003 | 07:25 AM
btlfed1's Avatar
skunk2 makes one and try Tkeller I know he has some to
Old Jun 16, 2003 | 07:27 AM
brega3's Avatar
one other question... is it worthy to do that converfsion? what gain should I spect from this conversion?
Old Jun 16, 2003 | 07:29 AM
btlfed1's Avatar
easier to tune the motor.
Old Jun 16, 2003 | 09:39 AM
vierth's Avatar
And you can use hondata with obd1, but not obd2
Old Jun 16, 2003 | 10:46 AM
KTeller8's Avatar
Default Re: what parts for obd1 conversion? (vierth)
obd1 ecu's can be chipped and you can use standalone for tuning:
also they have less junk clogging their brain performance wise: you can get obd1 ecu's so much cheaper, if you ever boost or do a swap: obd1 items are cheaper and easier to find: you can get better results then on a obd1 system
its SO MUCH EASIER
Old Jun 16, 2003 | 05:58 PM
Blown90hatcH's Avatar
I have your harness that you seek. Check the BB forum as I have a sale going on.
Jason
Old Jun 17, 2003 | 07:07 AM
KTeller8's Avatar
Default Re: what parts for obd1 conversion? (Blown90hatcH)
i will vouch for his work: I Hope he can get mine rare custom one done:
Old Jun 18, 2003 | 12:47 PM
m0t0rhead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brega3 &raquo;</TD></TR><TR><TD CLASS="quote">what parts do I need to do a obd1 conversion? and is it hard to do? thanks </TD></TR></TABLE>
You'll need an OBD-1 distributor as well as ecu and harness. Otherwise you won't be able to adjust timing. 96' and up accord's distributors aren't adjustable. The timing is controlled by the obd-2 ecu.
Old Jun 18, 2003 | 12:55 PM
AsiAnVenOm's Avatar
in addition you will need to replace your OBD2 injectors with OBD1 and add a resistor pack.
OBD2 injectors are 290cc saturated high impedance, Vs. OBD1 345cc peak & hold, low impedance injector.
Old Jun 18, 2003 | 02:27 PM
brega3's Avatar
Default Re: what parts for obd1 conversion? (Escobar)
hey all those parts? I thought it was only replacing the ecu and that was it... I think I will probably just sell the ecu that I have
Old Jun 18, 2003 | 02:51 PM
hotaccord92's Avatar
i have a 93 ex that i am parting out ill will sell u all the parts u need cheap like $50-65 for all let me know hotaccord93@aol.com
Old Jun 18, 2003 | 04:40 PM
Default Re: (AsiAnVenOm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsiAnVenOm &raquo;</TD></TR><TR><TD CLASS="quote">in addition you will need to replace your OBD2 injectors with OBD1 and add a resistor pack.
OBD2 injectors are 290cc saturated high impedance, Vs. OBD1 345cc peak & hold, low impedance injector.</TD></TR></TABLE>
You dont have to change injectors on this conversion.
Old Jun 29, 2003 | 12:29 AM
m0t0rhead's Avatar
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
You dont have to change injectors on this conversion.</TD></TR></TABLE>
Really ? Explain.
The ecu is mapped for those injectors. I think performance would be sacrificed.
Old Jun 29, 2003 | 12:33 AM
iam7head's Avatar
Default Re: (Escobar)
well, you not using 100% of the injector all the time.
you can tune to a extend without getting bigger injector.
the logic is that you prolly dont need bigger injector if you are running
NA
Old Jun 29, 2003 | 04:55 AM
97F22B2's Avatar
Default Re: (iam7head)
So you wont have to switch the injectors over for the OBDII-OBDI swap. Im doing this because im running boost with an Jondata chip and editor. But ill be using DSM 440's instead.
Also, in 96-97 Accord they already have a resistor pack, they dont need one to run those injectors.
Old Jun 29, 2003 | 06:13 AM
brega3's Avatar
So basically what I need is the harness and the distributor then. is this correct?
stevil_knevil
Feb 10, 2009 01:39 PM
Goodbye My Love
Jun 27, 2005 03:31 PM
mjrage
Sep 14, 2004 05:58 PM
1zach4
Jul 31, 2004 02:42 PM
greekspeed
Sep 25, 2003 03:15 PM
