PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 [312] 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. Stock tires
  2. difference in japan specs from U.S. f22 engine
  3. How to loosen a stubborn bolt located on front lip?
  4. Accord 91 whit F20A, advice
  5. I have F20a in a 91 accord , i need help
  6. f22b2 into a 92 accord?
  7. help wit a v6 accord
  8. Looking for your .02
  9. 97 H22A4 SH Swap Help
  10. 91 accord se parts car for sale
  11. oil stains on valve cover - need info
  12. 3" exhaust
  13. '02 accord power steering box
  14. Help Please - Tachometer cuts out, car hesistates
  15. 94-97 black housing headlamps/// i can't see s*@t
  16. F22A header to F22B
  17. turbo'n h22 keep f23 tranny or go with the h22 tranny . . .???
  18. New Member, quick audio question
  19. espeiler springs???
  20. Springs or Coilovers?
  21. Apexi Tanabe my exhaust
  22. Gas Light Didnt Work....Now Im Pushing.....
  23. H22 vs Turbo F22
  24. 89 Honda Tranny Drop... I cant get it out..any thoughts?
  25. Shifting problems
  26. I needhelp with the H/C guage in a 93 honda accord.....
  27. Help???
  28. Greddy evo fit accord
  29. HID Lighting?
  30. possible to do a 5speed conversion on v6 automatic?
  31. Toque specs for axle nut on 89 accord
  32. 89 accord elec. carb
  33. AUDIO ????
  34. 5th gear grind
  35. any 1 haver a pic of their 5th gen with amber corner lights ??
  36. Help with timing, balancer belt 2000 2.3 Accord
  37. Got a wierd clutch problem
  38. Can the manuel seat belts from a 92-93 work on a 1990 LX?
  39. accord any fast?
  40. h22 into 95 accord
  41. stock steelie lug type?
  42. fuel filter
  43. for automatic tranny
  44. Revving and dropping?
  45. Is the 94-97 Accord SOHC motor the same...
  46. Need Help Fast....91 Accord
  47. help!!!!! bumper lights
  48. need help fast (autotrans)
  49. How many 3rd gen accord owners are on here?
  50. 5th gen speakers in the dash???
  51. would this tire size affect the car? 5th gen..
  52. Any difference between the front seats of a 90-93 coupe and 4 door LX?
  53. 2004 Accord Coupe EX V6 6 Speed Impressions
  54. Clutch damper removal question
  55. help, hood wont open!!!
  56. ECU pinouts for 4 cyl 00 accord auto help please!!!!!
  57. question about braided brake lines
  58. Which would you pick? 94 Accord EX (auto) v. 96 Accord (5spd) See inside for details.
  59. Brakes erratic
  60. Dyno Tune
  61. 91 octane hinders our HP???
  62. Exhaust Question
  63. '90 accord drum to disc conversion
  64. Tweaked Suspension...
  65. I smell something burning...
  66. Cat flow differances?
  67. How much can i get for 94 accord ex?
  68. Axis se7en's
  69. Help! Power steering fluid pushing out from reservoir cap
  70. left turn signal acting weird
  71. where do u guys buy your parts?
  72. mhow do i add air to my tire
  73. 95 Accord auto transmission issue
  74. Looking for any accords w/ AN-R header on H22
  75. Camber Kits
  76. Battery Relocation?
  77. Hard selling a low-mileage Accord
  78. Oil loss
  79. 92 Accord Battery dies...again:(
  80. Clutch problems... PLZ HELP
  81. How many PSI on a stock F22 engine??
  82. 5 point harness
  83. OEM pads with resurfaced rotars...break in time?
  84. spark plug wires and coil
  85. Buddy clubs
  86. kyb agx's
  87. 6gen h22 accord supercharged
  88. how can u make a 95 jdm h22 smop legal?
  89. caliper price quote
  90. Hmotorsonline
  91. why does my accord shake so hard when i put it on reverse?
  92. Ind glow gauge help plz
  93. What rpm do you guys with F22/F23 trannys rev at??
  94. (98-02) Accord Automatic Transmission Question
  95. will a prelude steering wheel bolt on?
  96. Thoughts - Nology Profire ignition module
  97. S2k Seats in a 5th Gen Accord...
  98. Passing godforsaken smog!!!
  99. heres the dilemma, any help appreciated....
  100. stock ride shocks
  101. looking for parts for a 1990 accord lx
  102. Anyone bought h22 from them?
  103. alternative to konis
  104. still misfiring!!!
  105. web cam
  106. Motor Swap 99 accord
  107. Coileovers? Springs?
  108. rough idle
  109. Your Exhaust... Info Needed
  110. frankenstein motor 1990 accord lx. what do i need?
  111. lowereing 92 accord
  112. need help installing headlights
  113. Replacement for my stock tranny
  114. Nology Profire ignition module
  115. :OT: 5th gen accord HID ballast locations...
  116. Thanks to everyone
  117. Door Handles
  118. Headers
  119. HOW CAN I GET MORE MONEY FOR THIS CAR, PIC INSIDE
  120. What have you all gotten on your compression test ?
  121. how rare is this
  122. H22 <---> F22
  123. 89 carb hell
  124. '95 accord w/ h22 Axle?
  125. Turbo in 6th Gen V6 - Advice Needed
  126. camber kits
  127. Welcome me to Honda with some help for my 86 Accord LX :)
  128. Why doesn't anyone want my accord?
  129. 98-01 accord coupe 4 cyl. lug pattern?
  130. Fog lamps?
  131. Accord 6th gen 1/4 times?
  132. brake caliper upgrade question
  133. CV boot dumb ???
  134. Will the '01-'02 coupe bumber fit on the '98-'00 6th gen's?
  135. auto
  136. Powertech 4-1 Header
  137. WTB: front right fender wall
  138. just got into a small accident with my car..
  139. Proper way to ?
  140. Coilover Sleeves on Prokit???
  141. Where to put the Sirius antanna?
  142. my car is afraid of the ground.
  143. Problem with automatic transmission.. Please HELP!
  144. 3.2 TT vs. H22turbo
  145. security code
  146. Do 4th gens attract rocks?
  147. Fogs
  148. 99 v6 accord? swapped with h22?
  149. 2000 accord check engine light
  150. ABS noise and light problem
  151. 97 ex TURBO parts???
  152. need recipe for souped accord
  153. Removing Stock Deck
  154. what clutch do you guys use
  155. Headlight Bulb Problem
  156. Just wondering if front end damage is fixable
  157. H22 motor needed
  158. struts- yellow or blue
  159. h23a1 block w/ h22 head versus buying a jdm h22a vtec motor
  160. Will these fit on a 94 accord?
  161. 93 accord h22 overheating
  162. car is stuttering...
  163. My car is dead
  164. Audio Intallation Help for 2000 Accord EX
  165. Removing 5th Gen Bumper
  166. axle problems
  167. Accord Tranny Help
  168. 94 Acord dash board lamps
  169. pounds makes the difference?
  170. Misfire
  171. 5th Gen Bumper/Fog DIY
  172. Black ice sucks.
  173. crack radiator..confused!
  174. security systems
  175. power between h22,f23
  176. Kumho Ecsta KH11
  177. Best place to get a new starter?? and can you just replace the starter solenoid?
  178. are the dohc F-series blocks and the h-blocks the same?
  179. f22 crank compatible w/ h22?
  180. H22 w/ F23 auto tranny?
  181. largest width size on a tire
  182. Accord F23 rod length??
  183. IS THIS A FAIR PRICE FOR A 91 DISTRIBUTOR? $700
  184. H22 accord 1/4 question
  185. Questions on a couple of interior parts, bulbs
  186. 5th gen fuel mileage question
  187. tranny swaps and heads
  188. 95 accord noise coming from front end
  189. SEI rear disc conv
  190. OIL ????????????
  191. question???
  192. do they sell the airbag tray for the 94-97 accords
  193. 97 Accord EX Coupe VTEC Tranny
  194. Help!! Oil leaking...
  195. Refund money...what to spend on...
  196. Accord Type R
  197. burning smell, i dont know where its comming from... fills my interior up with burning rubber smell
  198. 2002 accord EX help
  199. A few random Accord questions
  200. Threads
  201. What to do with a 1983 Accord
  202. Does anyone know where i can get a driver side master window switch?
  203. question about honda accords
  204. 91 accord seats
  205. Wondering if the TL-S Catback can be custom modified into a 6th Gen 00 Accord 4CYL?
  206. Fuel pressure regulation ???
  207. Exhaust noise?
  208. Possible Transmission Problems %^&*
  209. 88 accord lxi is bein retarded
  210. Azetc body kit?
  211. anyone want new seats? 90 accord almost giving away!!!
  212. How hard to paint door modlings?
  213. Tranny Problems
  214. thermostat question
  215. Aftermarket actuators & window motors for 4th gen?
  216. accord ecu help!!!
  217. 94-97 JDM black housing h/l
  218. 91 $ door EX Part it out or just sell it?
  219. tranny problems
  220. Coil Overs
  221. steering wheel ?
  222. Help with a 1989 Accord ex-i
  223. Camber Kit Help?
  224. brake lamp
  225. For all you 86-89 (CA4/5) Accord people... This is a must have...
  226. I couldn't go to school this morning
  227. 99 Accord clock light
  228. AEM Big Brake kit.. any comment's!?
  229. f22a6 to ff2b turbo swap, Possible?
  230. tein coils
  231. 04 Accord Tach Wire Color
  232. Tokico Blue for 6th gen ???
  233. ---How to take engine out?----
  234. good investment or bad?
  235. Help! whats that noise!
  236. question about hooking up a zex dry set up into a 98 4 banger
  237. Swap Suggestions?
  238. "maintance required"
  239. removing: sound deadening left-over tar
  240. Coolant Temp Guage Wierdness-
  241. help, need catback 03 Sedan 2.4
  242. will it fit?
  243. F22B1 on a F22B2 motor??
  244. Cluth problem =(
  245. accords
  246. 98 accord pinouts?????????????
  247. H22 HELP
  248. Trouble With 5th Gen Lights
  249. How do I remove the rear seat on a 1994 4 Door Accord EX
  250. Parting out my aftermarket parts
