View Full Version : Honda Accord (1990 - 2002)
- Timing Belt and "Check Engine" light
- car doesnt like to start when its hot outside
- airbox hoses and sensors - 90 dx
- tranny all messed up
- ac not getting cold as quick.
- need help, fuel gauge is acting up.
- Car shuts off while driving 99 accord dx
- Water pump question
- a lil help please
- Sidemarker install on a 6gen
- brake upgrade
- My car is falling apart, and I leave september 6th... wish it would last.
- questions about a 92' EX
- Accord 90 ex 2dr A/C
- timing belt?
- RPMs while breaking and coming to a stop...
- new 90 Accord - questions
- Mysterious "suspension" arm on 97 Accord...?
- EGR CEL
- Loss of heatshield - F23
- Please Help: Won't Start -- Very Bizarre Problem
- Stock H22 I/H/E dyno day (videos inside)
- Strange Squeak when I turn wheels
- Bumer Light Bulb removal!!
- AC Problem
- Ball Joint HELP ASAP!!
- Odd problem with tire wear.
- Temp. needle climbing when AC is on
- THe wierdest sh** ever
- Megan Racing Exhaust
- head light conversion
- 95 Accord LX smog test?
- f22 question
- Prelude Throttle Body
- wheel question
- 2000 Accord Modified (Pics & Questions)
- Lower Rear Tie Bar, any experiences? Noticeble improvement?
- my driver's side window doesnt move nemore...
- Emergency brake light during hard turn?
- 98 v6 tranmission prices
- 93 auto-help with connecting transmission lines to radiator
- Distributor ICM wiring
- vafc2 help
- 97 accord battery light on
- 97 accord shifter problem help
- need help
- Question about led and resistors
- 92 accord w/rebuilt TCM D4 /light on at startup
- Audio Code?
- what kind of engine do i have?
- Seat question on a 94 accord
- aftermarket fuel mileage gauge?
- What brakes to upgrade to for 6th gen I4?
- need to locate speed sensor on 94 5spd LX
- How do you turn off the Maintenance light on a 2002 Accord??
- no clue swap
- No spark
- 91 accord question
- HELPP!!! ACCORD MISFIRE CYLINDER 2?????
- Will Apexi VAFC work on 4 cyl Accords? Apexi says NO!
- FLOOD VEHICLE HELP!
- center console removal help
- Brakes HELP
- 1997 Accord Overheating ** finding empty radiator and overflow
- 98 accord track times/ exaust
- "ebay" lights
- 6th Gen exhaust
- Got a free F22 sitting here, what should I do with it?
- vtec question
- camber kit question
- Bump Strips
- a mount and header alignment
- accord 96-97 neuspeed lowering springs for sale!
- Door Trim
- Transmission flush
- Honda accord V6 2004 question
- Firing order on V6 accord 1999
- full race traction bars 98-02 accords
- A/c compressor not kicking on.
- Window won't go up!
- Transmission Fluid Flush in a 1994 Accord EX?
- TRACTION BARS
- 98 LX Accord looking to turbo
- 98 lx accord ecu diagram
- 05 Tail Lights Replacement
- Is this idea too crazy, or would it work?
- MSD IGNITION QUESTION....HELP
- Grinding noise from R front wheel
- H22A swap driveshafts
- need help!!!!!
- how hard to change heater core?
- 91 honda accord motor in a 94 accord
- Sir Headlights
- SiR-T headlights
- JDM F22 motor?
- SiR-T headlights...where to find them
- help
- Hub Bolts
- h & r race springs
- What belt to use if I remove AC (6gen)?
- 6G Accord Trade 17" rims with your stock rims
- Drive shaft is popping out of ball bearing housing....
- BRAKE CHANGE. 4rotors, pads and speed bleeders..help!!!
- My automatic shifter keeps getting stuck in park,
- 93 Accord EX Transmission Oddities.. help?
- ABS light on my 95 Accord EX
- Automatic Transmission power handling
- no fuel
- shifter light out - 95lx
- Lock for shifter mechanism
- 93 se rotor change
- Flywheel...? ( yes i searched damnit)
- Rotor Over Hub Conversion (Extra Information)
- Whats a good aftermarket clutch thats intended mainly for street use?
- Do I need bumpstops on a 3"+ drop with stock shocks?
- ECU location?
- 97 Accord EX 4 cyl VTEC - P0401?
- 1994 Honda Accord EX
- 1989 Accord LXi cranks but wont start.
- CHANGING MY BREAK SHOES AND ROTARS ON 95 ACCORD
- (searched)Question about turboing 94 accord F22B1 motor
- Transmission Problem.
- 2001 HONDA ACCORD, ECU ISSUE, HELP
- Transmission Jerk Question
- 1990 Accord A/C problem
- H22 head on a H23 block?
- drain plug gaskets: vinyl or copper?
- Oil in the dist. and cap.
- Brake light on the spoiler!! Help
- Dashboards???????????
- 92 Honda Accord Start Problem
- governer questions!!!!
- 98 Accord 4 cyl wouldn't start. Waited 15 minutes then ok
- h22A 94 accord help needed.
- How to fix climate control knob??
- '96 Accord idling low, check engine light on
- Distributor problem, need help ASAP
- jack went into my floor
- distributor order?
- Question for 6th generation Accords (98-02)
- Changing Brake Pads and Rotors
- 2 questions about accord brakes
- 91 Accord Problem
- Wheels for my '00 Accord
- vss question?
- HID Conversion
- 91 honda accord needs $2000 in repair...HELP!
- Eng. diff from honda to acura?
- 1997 Accord SE chassis code?
- Leaking Oil?
- Blacked Out Tail lights
- any carburator question
- headlight problem
- Noise on 2005Accord EX when brake
- 03 accord clutch
- 96 Accord LX - SLOOOOOW - Is there any hope?
- 92 honda accord, some touble starting. No idea what It could be.
- 91 accord bogging and sluggish
- 02 accord vtec problem
- Wiring diagram accord 4dr 1992
- What's compatible? (from 86-89 to 90-97 accord)
- '98 Accord EX V6. Code 70 - Automatic Transmission
- Accord Shocks oem
- Accessories for 1996 Honda Accord
- '98 accord check engine light
- Handling: Custom anti-roll bar? Also, any point adding a rear swaybar to a car with a rear strut bar
- Help!!! My tranny went out
- A/C Leaking?
- How do you know if your on level ground?
- information about doors
- 2002 Honda Accord weird possible transmission problems
- Honda Recall List?
- Motor left smoking... Sad day.
- obd2 ecu engine management question
- brakes locking up
- projectors
- Neuspeed Race Springs on 6th Gen Accord?
- jacked up the car and weird thing happened
- quick tail light question..
- HELP with 88 Carburator
- Distributer Cap O-ring question
- Camber
- ??yr-acura cl sedan=96-97 accord ex sedan
- Check engine reset quick question
- '91 Accord Tranny slip?
- f22 maniold
- f22 turbo
- San Jose people
- help with 92 accord bumpers
- spark plug tourque?
- speed senor on 95 ex
- 5th prelude cluster in 6th gen accord
- Location of Stock tweeters on 94 Accord
- 2000 Accord F23 Performance Mods?
- Valve cover gasket question
- Need Advice 91 Honda Accord LX Auto
- All great things come to an end...
- Check engine light
- Best AfterMarket Suspension
- Power Steering in 88 Accord
- few quick questions about wheel size and tire fitment.
- p28 or p72???
- Trouble with 85 Accord.
- Seafoam!
- Short shifter install
- vafc help???????
- I cant figure out my car, Oil filter is weird, help???!!!
- Removing road paint?
- front bumper
- would these fit
- too much oil?
- motor mounts
- Tires
- Type-S Cams into my 94 h22a in my Accord
- Radiator replacement
- 90' accord A/C conversion help
- SPARK PLUG WIRES
- Whats needed to swap a f23a1 into a 5th gen.
- Need help on installing 9'4 4cyl REAR BEARING & HUB ASSEMBLY
- SMOG CHECKS!!! SMOG CHECKS!!!
- need help- clutch issues
- how easy is it to bend a crank
- Any Other Accord Forum?
- no water in resovoir
- Factory keyless entry on 96 EX
- Alternator/ecu fuse keeps blowing
- Engine Replacement
- HELP!! Car doing freaky shit!!!
- 5th Gen shaking?
- Got the Honda Dealership Stumped Help!!
- 2000 Accord suspension problem
- CB7 headed for 11's... 2point6's All Motor Accord
- 88 Acord 95 civic
- 96 accord fender removal
- 87 Accord will not start after a rain storm
- H22A Accord For Sale- NICE CAR!
- 95 Wagon CEL, where do I check?
- accord junked or sell parts???
- Radio replaced with OEM, steering wheel controls are not working now
- Stock accord exhaust help!!!
- head swap ecu question
- New Clutch
- Rover 620i (F20Z2) when change the cambelt?
- Rover 620i (F20Z2 engine) wich oil?
- How to reset the oil life minder
- Alarm in a 2002 Honda Accord
- h22 clutch for f22a1 (same?)
- What causes SRS light to turn on??
- Blown tranny. Does a prelude tranny fit on a 1998 accord 4cyl with the F23
- new car problems
