View Full Version : Honda Accord (1990 - 2002)
- good rear upper strut tie bar for 4th gen?
- installing CAI on my f22
- Power steering hum
- 5-Speed Fluid change
- battery tie down ?
- Neuspeed Upper Strut Bar Question....
- anybody interested in local area only
- Looking at a 1993 Accord tonight--Any comments or suggestions
- Problem: Mothers 96 EX auto won't start.....
- RESEARCH: 92-95 Prelude Airflow Meter into Accord for Easy HP?
- H22 Throttle body on F22?
- have you guys seen the TURBO accord on ebay?!?!
- Question on how to get more power out of my 93 EX Accord
- bad pic of car sitting in park lot
- Brake booster?
- JDM Headlights
- ZEX on my accord
- Complete Wheel Wieght List (lbs.) - (see X-overs for accord)
- 30K Maintanence questions
- Bearings
- I got scammed on my car I think....look and see if you can help me get back
- 2003 Accord Coupe Opinions
- What's up with 99 Accord Engine Malfunction Light at 48K
- Tow in Tow Out ?????? and tranny fluid for standard ?????
- used car advice needed: 97 accord
- fuel system cleaner
- FYI - GB for 2-1/4" Cat Back Exhaust
- 94-97 motor mount inserts
- Any help on front camber kit noise 93 accord
- NorCal 5th Gen Accord ownerz
- Accord in progress
- 92 Accord Wagon Idle/jumping problem?
- Need help with 1990 Accord door latch assembly
- OT: HPI Accord
- Short Shifter?
- Difficulty with mounting foglamps on '90-'91 Accord?
- stock accord ex motor specs?
- IMSA - Factory Backed Racing Accord
- Accord Cruise/Meet in VA
- will borrin the intake man. and new throttle body run too lean?
- another brake question
- Who Has Prelude Si Rims?
- Are TenzoR racing seats any good? (pic inside)
- My Suspension...any advice?
- Honda brake pads vs. Aftermarket?
- H&R Sport VS. Eiback ProKit ?
- Has Anyone done a Accord Euro Type-R conversion?
- Spoon magnetic drain bolts question.
- 98 Accord V6
- fuel additives
- apexi safc
- 6th gen I4-->heat generated after installing heater?
- Need help with tranny?
- egr
- 02AccordCoupe owner from Cali (visit my website!)
- fog lights
- 96 accord 95 h22... advice needed
- Strange noises coming from engine bay?
- WTB: Stock 94 Accord ex exhaust for my 2dr
- how often have u changed, or have u ever changed ur intake filter?
- h22 swap?
- Help
- Power Steering causes crazy idle!?!
- Looking for stock parts
- Need brake pads and rotors for 99 Accord
- Question...
- OT: Yay its my B-DAY
- Built F22s
- auto accord tranny has mind of its own
- dual exhaust on a 95 accord; is it worth it, and will i feel the difference instead of just hearing
- Squeaky sound from new springs
- ***H22 in 92 ACCORD..HELP NEEDED***
- bypass an install of knock sensor
- Phantom Grip LSD
- Any Downs of removing the FIV?
- Quicker steering ratio for Accord?
- for those with f22b dohc swaps
- Slight ticking noise from my motor
- haynes manual
- What series motor came in an '85-'86 Accord?
- idling
- powdercoating rims
- h22a in 96 accord
- whats the site for OEM honda parts?
- apexi auto timer 02 sensor wire
- 2003 Accord Coupe
- H22 Headbolts same as F22?
- Fuel Filter Replacement
- Whats a good selling price?
- brake fluid leak and wierd whisle
- Tampa, FL
- Can you adjust the fuel pressure from the factory?
- Li'l HELP for a Newbie??? TIA
- remote starters
- Eibach Prokit and Dealership won't do alignment!?!?!?!?!?!!??
- customizing accord
- Interior accessories
- Pics
- how do i?
- idle not steady - and more...
- Need some Idle help!
- What would you think it would take to make a killer suspension setup?
- 92 Accord Starting Problem
- carburetor
- cheap parts online store
- Where can I find info...
- Sprint Lowering Springs
- new to honda-tech just wanted to say hello
- Engine mods with future swap in mind
- got exhaust! installing.......
- Squeaking sound from distributor
- Burning Smell of Plastic and Clutch
- just got a 97 accord plz help!
- Basic Mod Suggestions
- 6th gen headlight\electrical problem. HELP!
- This car makes a really wierd grinding sound when driving and making turns... please help with info
- sh swap in accord
- LA Area: Sell me your 15" stock accord 4-lug alloys. Or just one of them
- navigation system in 2003 accord
- New driver side mirror
- Help! '86 honda in need of some genius!
- '99 Accord LX 5-Spd, what can I do to make it sportier?
- pics of my new toys (bored)
- ok well.
- F22A6-F22B2 interchangable? What are the differences?
- I am going to be getting a Honda soon... Civic VS. Accord; ideas, help?
- engine swap...
- ATTN: MD VA DC H-T'ers.... Meet on Oct. 19th...!!!!!!!!!
- apex'i n1 catback for accord
- 6th generation header
- where to get rebuild kits??
- How do I check codes in a 1991 accord lx??
- hammerhead Carbon Fiber hoods anyone????? not 56k friendly!!!!!!
- V6, whp, 1/4 mile
- Help me analyze my 1/4 time
- need some interior
- Replace gas level mechanism
- who else drag races there accord
- accord suspension
- wiring a tach in a 90 accord which wire for rpm?
- flipflop trunk?
- stripping down totaled 94 accord ex 5spd
- Help!!! Car overheating
- i need info?
- V-AFC Wiring Diagram for 1995 Accord EX 4-Cyl
- Fuel filter change
- Noobie (sorta) with pics of my car
- What else do i need???
- Mysterious "check engine" code 3 situation. Please help!!!
- High oil consumption but no obvious signs.........?
- NEW Accord Euro R as in brand new!!
- Toe, Camber, all these jibberish.....
- i bought a car & desperatrly need specs!!!!
- how to take 100lbs that you cant see
- engine light - power loss
- spare a second to give your opinion please, accord 02 coupe
- 97 accord and 98+ accord!!!
- Tuner Showoff Oct 26th in ATL for charity!
- Once again, i've encountered the mysteries of the Check Engine Light.
- n Popping noise???
- Lowering Kit
- Cheaper than Group buy? (brake pads)
- Exhaust piping diameter
- Blitz NuroSpec Exhuast?
- How you think of this????
- suspension?
- Help the search challenged
- Front shimmy and shudder when breaking
- Need help car wont start
- good news!
- slave cylinder and clutch master cylinder question?
- in-need of strut info
- Do you have info to help me????
- SuperCharger for the 3.0 Accord
- will 19" rims fit on an accord?
- the ultimate exhaust poll!!!
- Did search, but want more info on H23 in 96 Accord
- Clutch/high idle
- weight reduction - stage 1
- Front EX-R Lip Spoiler Needed
- I got a new car!!!!!! Screw Wallstreet and your failing economy
- I want more power!
- sway bar for 98 V6??
- Frozen, Dragging Brakes
- whats the voltage supposed to be when engine is off?
- Clock light doesn't work
- can someone make sense of this Koni shock info?
- 5zigen fireball
- S/T sway bars
- tranny problems, help!
- What do ya'll think about these wheels for my car..
- something is killing my battery when the engine is off?
- Legend brake swap
- H22A parts
- Are 4th Gen heater controls a problem ?
- Accord Meet in VA Oct 19th
- transmission problems
- Walbro pump for Civics/Tegs fit a 6th Gen Accord?
- Auto to Manual swap on '96 Accord
- hate tha chrome
- OEM catalytic converter with o2 sensor
- camber kit information
- 1/4 mile times on NX
- 96 accord 4dr LX rear swaybar install
- Vacuum tube labeled 8 off the Intake manifold
- JDM 4th Gen Accords?
- H22A Engine Oil Question
- 6th gen coupe 5 speed owners from LA area holla.
- Too Hard or go for it
- Engine Malfunction Code 14?
- need help check engine light on and maintenence light?????
- stear me in the right direction
- Anyone in the "Close to bronx area" willing to have a meet?
- Toronto memebers, Lets try this again......
- Tenzo Type C / Racing Hart C2
- 12.2 " 4 piston upgrade ready for the 4th and 5th Gen Accords
- bogging problem
- Please help...Brake lights out on 93 Accord...tried everything
- Attention Toronto, On, Canada Members * October 17th Meet "ROLL CALL"!!!!
- AV6/wagon brake swap - bracket problem resolved
- maint and specs on f22b twin cam
- 95 f22b1 distributor.. tec or hitachi
- high mileage turbo...
- Vtec head on F22a
- engine work on 94 accord
- which clutch exedy or act
- front mount intercooler for 6th gen for sale
- Drop Spindles!!!
- Installing Indiglo Guages
- Anyone looking for some HID lighting?
- timming belt?
- major service?
- piston rods, are they worth the money to put in??
- 6th Gen Bumpers
- Help, My brakes squeak then a grinding noise
- ABS light
- H22 swap heater problem
- help, look at pic, dirty fog, is it easy to clean?
- Radio
- Classifieds "suck" for 4th gen Accord users..parts needed...plz help!
- Interchanging headers...(I searched...)
- Valve cover nut size on a F22B1 ?
- exhaust
- Front End Vibration
- Heat Wrap to Wrap the Custom CAI in what to use?
- window switch
- uh oh, car has no oil in it.. lol
- Anyone wants a complete DSM turbo setup? For $5?
- ideas...
- CEL..how to check it?(v6)
