View Full Version : Honda Accord (1990 - 2002)
- Question about lowering a 96 accord
- f22a1 and f22b2 intake manifolds interchangeable?
- factory turbocharge ?
- Any 92-93 accord sedan owners?
- Popping noise after release throttle
- h22 swap checklist.....help me out
- Drag 4 Turbo pictures
- pix from USGP of Accord concept coupe
- Axle Boot
- driver window wont go up on my 5th gen
- pic request of clutch pedal bracket
- H22a Eagle Rods
- turboed f22a6
- o2 wires for 1996 LX
- Stick with 15" or upgrade to 17"?
- what kind of gas should i put in my 95 accord lx
- Headlight opinions
- Brackets and Sliders for SRD's
- '82 engine swap
- (4G) Removing the Rear seat - how?
- jdm h22 into 93 accord
- best exhaust for jdm h22 in accord
- H23 Mods, Possible F22 as well?
- Golden Eagle cam gears
- crankshaft sprocket/gear
- CKP sensor for 1997 accord se
- Cheap Turbo?
- Anyone have the wiring schematic for the 92-93 Accprd factory fog light switch?
- ot: thinkin of upgrading rotors
- 90 accord went crazy!
- Resistor box
- 94-97 Accord EX parts for sale!!!!
- JDM 5th gen lude steering wheel....
- drive light is blinking
- what's the best?
- another intake question...
- What is a a good street car?
- diff between disc and drum brake
- fuel pump relay location 1988 LX
- I NEED WIRING HELP
- Power window problem
- Will this Intake Fit?
- Question regarding locks on '99 LX
- seals
- Mirrors
- V6 Brakes On To 4cyl?
- Check engine light on, Losing power at 4k RPM; light off, powerkill @5250
- broke a wheel stud
- who has a f22 turboed with pics?
- when changing the OIL filter, do we have to do this ?
- quick tire question!
- quick answer please...About how to check cel
- Just got a 2000 V6 Coupe, lets the mods begin! :D
- I got white smoke comming out my exhuast ..
- H22 this...H22 that..
- having trouble with back struts
- Replaced Speed sensor, transmission not working.
- 91 and 93 Accord
- 2000 ECM into 2002 Accord...
- Mahor Problem here
- weird noise when motor starts
- service mode on 6th gen?
- 2003 Accord coupe questions.....
- 5th gen accord h22 fuel pump Q's
- engine weights
- accord 1/4 mile time
- h22 swap
- Who has a drum-disc conversion?
- Getting rid of the SRS light on --
- What motor(s) to watch out for....
- Camshaft Question
- newbie here, please help
- can it be done? sohc vtec head on sohc f22a1 block?
- 2003 Accord Coupe Turbo
- h22 swap question
- 97 Accord Ex Coupe 2.2L VTEC Intake question
- Built H22A Intake for a CD6
- '01 V6 Accord Rear Engine Mount
- Power Steering?
- f22 price?
- 6Th Gen Question
- H22A In 98 Coupe, Help!
- h22 swap question
- 89 Accord swap???
- Sound Advice for everyone...It may happen to you
- Is my blower dead? Help!
- how do u remove the window molding?
- can anyone answer my question
- ticking noise
- AEM LOOKING FOR VEHICLE
- Some 03 Accord Engine Q's...
- accord wheel fitment with other manufactures
- why were v6 accord automatic
- D4 LIGHT BLINKING 94 ACCORD
- quick question on chassis code for 5th gen what are all the codes to what car
- How hard is it to install 1992 Accord Distributor?
- 86 Accord 2.0 INFO
- need help reading plugs - nitrous
- walbro 255hp intank pump install on an 02 Accord Ex
- o2 sensor question
- Can someone tell me how to replace the blower motor resistor pack?
- Where can i find a whole underdash-through-firewall wiring harness???? need asap
- FI question: obd0 + 450cc DSM???
- speedometer problem
- cam and crank sproket
- Valve adjustment recently done, weird sound now...
- Power Antenna questions
- AC/Heater Fan only works on positions 3&4 - what gives?
- Changing Antifreeze?
- any pitfall when it comes to installing crank and camshaft oil seals?
- which spark plugs wires for jdm h22a? USDM didn't fit!
- Need Help on H22A/Accord Set up ..
- planning accord h22 swap have just a couple questions.
- accord 2003 recall
- Shock rebuilders.....
- Cleaning injectors on 4th gen
- anyone shoot nitrous through their f22?
- 7th-gen Honda Accord Performance Parts and Accessories
- Can I put a 94/95 front bumper on a 96/97 ?
- Noob here i have a few general accord and h22 questions
- is it possible..
- spark plug wire not plugged in..
- benefits
- speaker question 01 accord
- Headers
- Suspension Question and Requests
- Acceleration Issue on an Accord 2001 LX i4
- Timing belt changed but loud squeaking noise?
- Used car pricing question....
- 1997 EX (4 door) front license plate bracket?
- Euro R h22 cam grinds...
- 2003 accord power windows
- what you guys think about "DIY" home alignment?
- 91 accord auto tranny problem
- quick voltage question
- 2001 accord tranny question
- Need suggestion: Head light bulb dies, want to replace it with something brighter
- bad input shaft bearing?
- How to change rear rotors?
- Clear headlights problem
- 1999 v6 to manual swap
- Fuel system upgrades f22b1
- how do i remove the rear shocks for a 90-93 accord?
- ecu map layout
- Question about Honda Service manual?
- lowering a 2001 accord, help please
- SFP accord manni problems???
- AEM EMS or Hondata
- INSTALLING GAUGES PLZ HELP
- Headunit upgrade
- rear speakers dont work help please car smells
- Venom V-400 Group buy!!! 25% more power cheap
- bad battery or a short in the system?
- F22A1 to F22A swap problem!!!HELP
- Cross-drilled rotors for stock wheel size???
- 87 Octane okay for F22?
- Can u use the accord tranny with an h22 motor?
- Fuel Filter 91 Accord
- New representing from Russia and some questions
- hondata???
- building a turbo set-up
- battery light
- tire brand
- Bought a new accord, need some accessories
- Turbo Accord Injector Question
- 97 special edition
- flywheel
- i need advice
- 04 accord, bad alignment from Day 1.
- sites that have parts for accord...
- how do u take off 2000 accord clusteR??
- Rear brakes on 1990 EX all messed up...
- 1990' ex-r.. Maintenance requirements! total restorage!?
- Idling Question
- oil around plugs.
- Tires on the wrong way!
- No start condition for 1992 Accord
- How to find and adjust the Cold Idle control valve?
- Turbo manifold for a f22b1?
- no spark in engine.....
- Help! Took dizzy off and can't put it back on because...
- 6th gen antenna location needed
- my cars leaking alot of gas under passngerside rear..
- New to accords, 3rd or 4th gen better for autoX?
- accord brakes and legend brakes???
- accord doesn't start
- momo hub part #
- blue badge
- 92 accord 2 door
- when does vtec kick in?
- Which tranny to get
- HP Springs & Struts
- N/A means ?
- 93 Accord Code 12 EGR Problem question.
- Correct Valve Lash for 4th Gen?
- muffler
- how long for a new clutch to wear in?
- strippped spark plug hole -- can I fix it with the head on???
- accord classifieds?
- F22a1 to a6
- Tinting a '99 sedan, a do it yourself job?
- More power
- Front Bumper 4th gen
- fuel filter, worth it?
- Hi, Help plz
- Anyone knows who does H22 swaps in NYC? n/t
- possible fuel problem!!!!HELP!!
- HEADER GASKET PROBLEM
- who knows the outcome of tubocharging a 01 accord ex 4cylinder
- Wheel stuck!!!
- trouble starting, clutch sensor?
- V6 accord auto trans question
- If your shifter is feeling sluggish.... please read...
- Legend caliper upgrade for 94-97, does anyone have this setup?
- very loose steering wheel
- anyone ever heard of a 98 accord headlight coversion on a 94 accord??
- engine troubles, please help
- power door lock problems
- Will a 96 Accord v6 Tranny Fit a 98 Accord V6?
- fuel gauge in 1998 Accord V6
- check engine light keeps blinking
- Ranting Abiut bad service from Tire Craft in Canada
- the best of
- Any such thing as true JDM 6th gen??
- f/s 94 accord
- GM block in accord.
- spoiler
- Cheap Power
- 94 H22 Accord owners.. header question
- 98 accord transmission removal
- time for a timing belt.. Would you get a water pump?
- 225/35/18 fit on 6th gen accord?
- Drag gen 2 kit for 4th gen accord.......
- where to fill up ATF ?
- Timing Belt
- 97 having problem shifting out of park
- Jerky Transmission
- Just installed axles, have a question...
- jdm headlights
- hello fellas, newby here.
- newb. question to help a friend. please help him
- f22a head swaps
- Key Stuck (really bad) 4th Gen
- Intro/Engine info
- Looking for suspension help!
- DRL kits.....
- Crackling noise????
- know 95 accord lip?
- Chicago Area Accord meet - sunday sept 21
