PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 [316] 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. need help with F22A1 leaking coolant
  2. cleaning headlight lense
  3. Angel Eyes
  4. Where to buy a Turn signal lamp for a 94 EX 4 door
  5. got a noise, can't figure it out
  6. Automatic Shift-Lever 2000 Accord
  7. Can mixing Rubbing Alchohol with gas be used to pass smog?
  8. coilover installations
  9. what ecu to use?
  10. would a 2.50 fit with 2.00 piping on a 5th gen accord
  11. 99 Accord Auto - Headers?
  12. gsr aem intake on 91 accord
  13. 2003 accord hands free cell setup?
  14. steering wheel cover accord 95 ex v6 question
  15. 17's or 18's on a 97 Accord
  16. Did an oil change, my oil doesnt look right!
  17. Accord Spring Confusion
  18. h22 into 96 lx accord wiring Q?
  19. Silverstars?
  20. Whats a good drop for a 97 accord on 18's
  21. Door stuck, need honda TSB to get open help?
  22. Accords capable of running 11's??
  23. Radio codes
  24. 88 dx Swap, any suggestions.
  25. Car won't start or turn over.. please help
  26. SPC is a good brand
  27. My 95 accord.
  28. 2002 accord lx idea
  29. MERRY CHRISTMAS EVERYONE! :-P
  30. door wont open
  31. Please post problems with 3rd / 4th gen or anything relevant
  32. poly-urethane bushings?
  33. Quick Suspention Question??
  34. '04 accord headlight bulb
  35. F22 crank pulley issues
  36. 2000 Accord ECU Pin out Diagram
  37. help on paint code for 97 accord se
  38. Changing front brake pads on a 92 Accord
  39. help!!! head light unit..
  40. Small problem with my 98 accord LX 5 speed 4 cylinder
  41. does cross drilled rotors affect the brake pad wear?
  42. I've done the search and I still need help
  43. 1999 accord dies...please HELP!
  44. trouble, please help if u can
  45. Cold Air Intake
  46. SPC Camber Kit for 6th Gen Accords
  47. H22 SWAP 95 ACCORD EX...Did Search: Results 0
  48. Help with door panel
  49. bumper fitment
  50. Quick Question - Jackson Racing Supercharger for 2.3L Accords?
  51. 91 accord problems heater wont work
  52. H22 Type-S pistons in F22 VTEC motor?
  53. Finally got Tein SS
  54. Street-legal headlights
  55. replaced transmission on accord
  56. Help me fix my grandma's Accord!
  57. Fork and Control Arm bolt
  58. Clutch went out in 96 accord?
  59. Help! Wheels JDM please
  60. ps question
  61. obd1 or obd0
  62. 6th gen auto -- stalling
  63. rim & tire size ????
  64. 1991 Accord F22A engine replacement with F20A engine..
  65. Honda Rebuilt Trannies? Worth it??
  66. Two Questions: Just had the valves adjusted at the dealership...
  67. h22?
  68. ground control coilover on the accord
  69. swap or start from scratch
  70. Exhaust
  71. Kosei Wheels
  72. bumpers
  73. Any 4TH Gen Accords w/ rims ??
  74. 5th gear - missing?
  75. ITR Recaro's into a '97 coupe?
  76. coilover install trouble
  77. H-22 swap
  78. coilovers
  79. which side does the car pull to if pressure is low in one tire?
  80. Master Cylinder Noises, Help!!!
  81. Accord mastercylinder size?
  82. does aftermarket taillights affect the tail light sensor?
  83. Tranny sucks
  84. 95 honda accord ex
  85. OT: How to Maxi-Min your new [Accord] Purchase - (in the TSX Forum)
  86. How do I remove my 1994 Accord bumper signals???????
  87. How many miles will an accord altinator last?
  88. Really wierd problem
  89. quick question, 91 stock Accord...does it have eld?
  90. IMMOBILIZER HELP WITH 97 PRELUDE SWAP INTO 97 accord!
  91. 99 v6 coupe "check" light
  92. Replace side view mirror?
  93. Labor cost
  94. h22 tranny problems
  95. anyone witha v6 accord in the crew.
  96. jdm headlight question...
  97. blank oem key
  98. Greddy Evo
  99. accord swap for H22 (what intake will fit the best)
  100. What kind of oil should I use?
  101. 90 accord lx tranny
  102. 98 Accord Starter Relay Location?
  103. how do you drain ps fluid?
  104. Accord Owners! Generations of ACCORD model...
  105. Thinking about swap f20B vs h22A
  106. NEED HELP: CEL code 6
  107. bore on the f22
  108. ALIGNMENT SPECS FOR A LOWERED ACCORD??
  109. 2003 AV6 Maintenance Required Light
  110. Swap Question?
  111. Tuning Questions?
  112. front brake rotors?
  113. Has anyone swapped their auto accord to manual? Added a prelude swap?
  114. oem fog lights
  115. won't shift from park to drive help
  116. Lug pattern?
  117. 2 intakes
  118. clutch
  119. Universal Mufflers
  120. 1998 Accord V-6 Alternator issues/questions
  121. What tranny will bolt onto the f20B JDM SiR accord engine?
  122. tail light malfuntion
  123. Burning Oil
  124. electrical shutdown
  125. Is my girlfriend imagining the noise?
  126. Problem after timing belt, balancer belt, and water pump change?
  127. What is softlines
  128. Power steering pump making noise!! Why so early?
  129. Tranny problems?
  130. 94 speedometer not working
  131. Replacing suspension bushings?
  132. auto to manual conversion
  133. 2000 Accord Suspension
  134. CLICKING SOUND ?????
  135. 2003 4cyl Engine
  136. just wondering-->clutch
  137. What suspension setup is better?
  138. Does insurance cover H22 Accord?
  139. accord egnition swich ?????
  140. disable trunk latch? good safety measure?
  141. 86-89 accord
  142. 4th Gen Accord with H22 and Euro R intake manifold; which cold air will fit poperly
  143. Any one ever replace front crossmember? '92 LX
  144. Tune up on 88 Accord LXi
  145. 94 Ex' Gauge Problem (Need Help)
  146. Lowering a 2000 accord sedan with new coil springs
  147. JDM climate control for CB7
  148. LX accord to h22...questions about EX problems
  149. taking out motor
  150. V6 into 4cyc SWAP
  151. which engine?
  152. URGENT question bout camber kits
  153. driving in snow?
  154. i need help lowering my 6th gen accord
  155. how much can i drop my car and still have it functional to load?
  156. Accord ex 4c Catastrophic Failures
  157. 2004 ex manuals, whats best
  158. 91-93 Accord plug gap ?
  159. driver side scratching sound
  160. need help with the programing vafc on 6th gen V6.
  161. Missing hose on fuel injection???(pics)
  162. 90 accord when i hit the brakes the gauge cluster lights up when car is off.....help me out
  163. VTEC IN MY 94 ACCORD?
  164. DIY accord camber washer trick question
  165. switch for fog lights
  166. AEM cold air Intake question for 90-93 Accords!
  167. Need Help Installing Tranny Cooler
  168. Help For Euro Accord
  169. New Colour
  170. 5th Gen Headlights suck!
  171. balance shaft question
  172. 5th gen eletric problem
  173. lsd accord trannys
  174. what is the engine code for a 89 LXi ??
  175. License Plate Lights out...checked fuses/bulbs WHAT NEXT?
  176. Drums grinding?
  177. alignment and steering.
  178. quick stupid question for all you accord guys...
  179. h22a honda accord lsd tranny question
  180. finally dynoed my car again with video......
  181. need help installing vafc
  182. 17x7.5 with 45 offset
  183. ::OT:: greddy 4-2-1 headers
  184. 90-93 trannys
  185. Automatic Tranny Fluid Change
  186. ERRATIC IDLE PROBLEM WITH H22 1992 ACCORD
  187. r the rear accord wheels
  188. 6th gen accord springs/shocks
  189. h22a 1996 accord
  190. Will a dc sports exhaust
  191. h22 tranny
  192. 94-95 ex sudden oil loss
  193. OEM Lip Kit???
  194. engine stuter when you step on the gas hard
  195. Struts/Shocks
  196. whats the deal wiht the rust on the driver side back
  197. ABS problem
  198. Hayame strut bar
  199. accord auto shift control bulbs burned...
  200. interchangable??
  201. 94-97 Accord, 5 speed, 4 Cyl...
  202. Anyone use Eibach Sportlines?
  203. Location of VSS on 95 accord ex coupe?
  204. Differences in Accord Coupe, 1998 - 2002 ?
  205. '88 LXI 5 Speed Conversion
  206. door panels
  207. my 01 accord is making a scraching sound when turning left
  208. 87 carb trans vs 88 FI trans.
  209. Anyone use GC Coilovers+Konis?
  210. How hard is it to change a timing belt of an Accord 2.3L 1999?
  211. Turbo a non turbo
  212. 90accord lx, idle goes up and down when cold only in drive4
  213. my accord idles horribly.....
  214. -------quick clips of my turbocharged accord from the inside-------
  215. Need used 5 speed Tranny for 88 accord
  216. Rough idle and IACV?
  217. speedometer
  218. New Spark Plugs
  219. fuel strainer
  220. 96 accord air conditioning illumination
  221. HELP!
  222. FREE parts for R&D
  223. Need Help Choosing Tires
  224. opitional cd player?
  225. Speedometer problem
  226. tranny kicks into neutral
  227. 1990 Accord, heater/blower Fan works intermintently
  228. accord is it transmision problem
  229. Fuel Filter
  230. Need Help Choosing Tires
  231. Is OBD1 P72 Gs-r ecu safe and better to run with stock H22?
  232. Engine Replacement
  233. Accord Corner Lights
  234. pcv
  235. ignition/alarm problem? (car won't start)
  236. Accord garage sale
  237. I got a clunking coming from my car...
  238. APEX VAFC help with programing
  239. swapping steering wheel for prelude steering wheel?
  240. 15" Wheels on a '04 EX V6
  241. Prelude Si Wheels on 5th gen Accord... wheel spacers?
  242. Transmission problems?!!!
  243. guage cluster questions
  244. Replacing clock light
  245. Steering Problem
  246. lights blinking fast after hit n run
  247. 200 HP please?
  248. BACK GLASS SHATTERED
  249. Mobil 1 question...
  250. cold air intake install on a 97 accord ex
