View Full Version : Honda Accord (1990 - 2002)
- Really bad MPG
- 94 honda accord ...
- cd7 jdm headlights
- 2002 Accord EX Coupe-Check Engine Light on Error P700 and P740
- 92 external coil accord
- Increasing the compression ratio (CR)
- IAC (Idle Air Control) voltage question...
- h22 euro r turbo problem
- 96 accord coupe 4cyl cams?
- 94 Accord rear brake issues
- oil leak in spark plug hole
- 90 Accord wont start, PLZ HELP!!!!
- engine seems to hiccup at stop lights in drive
- Honda Tech Accord Owners Fantasy Football
- h22 accord electrical problem, no electricity, car wont start
- vss problem after h22 swap....
- what is wrong?
- Home made cold air intake...???
- Changed + Battery Terminal Now it has a hard time starting NEED HELP!
- LED signal light blink TOO fast
- Several dash lights on at once
- 94 Accord: Is the first driveaxle replacement always difficult ???
- Are the Stant Super Stats ok on quality and performance ???
- 1991 Accord dies in second gear.
- Accord Inner and Outer Tie rod ends
- engine acceleration
- Oil leaks ... where is this coming from?
- vin ranges for transmission problem
- ECU code...nothing?
- Still on Trial account
- Turbo Specialties
- Hummy noise concern ?? help
- 99 accord wont go in reverse
- 97 Accord Check Engine Light Jumper
- abs pump needs replacement on 1993 accord
- Gas Mileage Bad- Brake Problem!! 93 accord
- How the Heck do I use this forum
- aem pulleys
- Turn Signal And Marker Lights 93 Accord
- Allignment after install rear SWAY BAR?
- need help with 94 accord 5 speed swap
- f22b1 swap question
- Light Issue
- Another Overcooling Issue
- Distributor question
- replaced thermostat, next day code 16 and 43?? (92 accord)
- what does the burning of a clutch smell like
- gauge lights gone out
- accord with h22 ecu question
- Horn Issues
- still haveing probs
- 99 Accord LX steering wheel jitters or shakes or shimmy's at diffrent speeds need HELP???
- 2002 accord internal engine problems
- forbidden shortshifter
- Code 12 EGR Can't figure this one out
- need helpp please read
- 98 Accord A/C Intermittent Cooling
- 93 Accord DX power issue
- 5 lug conversion
- Troubleshooting Headlight Chime?
- Vacuum lines lost...
- help with diy please
- F22 & f23 intake manifold compatability?
- 96 Honda accord v6 starting issues
- 98 accord lx rims
- Is 194F or 180F the OE temp for the 5th Gen 94 Accord Thermostat ???
- Air box broken- Time for a performance intake?? (PIC)
- Can a low ECT gauge pointer be caused from a previous overheating ?
- Infrared temp shows 180 to 236 F temps on outside of head
- Temp guage indicates overcooling
- Cooling fan not turning on twice while bleeding air -- Helms says it should
- the best short shifter!?
- turbo manifold
- 1995 Ex F22b1 5 speed revs out at 4k
- 1998 honda accord sunroof problem
- f22 wont rev up
- 1995 Accord coupe shreading front tires
- STARNGE starting problem
- This might be a noob question
- Fan Switch Relay
- A/C Light
- Engine type?
- Where To Start???
- 1990 accord lx with h22a1 tach/vtech proublem
- 94 accord lx cuts off
- 97 Accord won't go in gear Manual transmission
- 1990 Accord LX 4cyl coupe
- 2000 Accord SE AT fluid change
- High NO ppm fail on emission test 91 accord
- Brake vibrating while braking on Highway....new ebay rotors?
- 1998 accord performance question
- Need some suggestions. I'm new at working on cars.
- Radiator Fans
- Handbrake Light on when Accelerating
- 6th gen trans swap ecu problem
- f22b1 removal without removing trans
- 95 accord code?
- 97- Power Steering leak fixed
- Front bumper mount brackets disintegrated
- General Question about people who drive through puddles. (Big and Medium)
- f23 intake pics? inside and out?
- 1990 honda accord heater core
- running a 4 or 2 guage power wire
- Power to Starter solenoid missing
- Replace Speed Sensor!!!!
- how to replace cv joints on a 95 accord 4 cylinder
- I have a draw 93 Accord
- starting problem
- how much should i pay, cl rims?
- NWP Accord Project H22 (Need So Cal Help)
- Any idea if the 2000 accord rims will fit a 5th gen accord?
- Distributor mount busted
- 1997 Honda Accord Wheel bearing
- rough idle still
- Cold air or Short ram intake???
- 99 Accord...pulsating in pedal when braking
- 94 Accord Help PLEASE!
- F23 VTEC HEADSWAP ON TO F22A4 BLOCK With some extras!
- Oil change interval
- Is this a starter issue or an ignition issue? Should I tackle it myself?
- problem with corner lights
- POwer steering help!!!!!!!
- 2000 accord coupe fuel pump installation
- Header Problems
- Mixing Manufacturer Wheels
- BOOK RECOMMENDATION WANTED
- Honda Accord Wont Start, No Swapp, Not Main Relay, Not Fuel Pump, STOCK
- RPM jumping between 1k-2k rpm
- Differences between 95 and 97
- Motor Swap...
- low oil presure after engine heats up
- Short Shifter Advice
- Need Help ASAP!!
- Help with purchase of 1993 accord wanted!!!
- WTB: Azect Grill (Mr.TopFuel?)
- 92 Accord Alternator/Battery Headache!
- HELP - Trouble all rear BRAKES LIGHTS out and AUTO TRANS will not go out of Park
- Which service manual's labels are incorrect: The 94 Helms Accord Service Manual, or the 94-97 Haynes
- 98 accord gas pedal jerk
- Whats the best way to remove the side modlings?
- 1997 overheated and fan still runs after engine off
- Want to take racing classes.. but..
- prelude and accord intakes the same?
- 94 accord coolant evaporating
- newbie/belt replacement on '98 accord
- 2001 LX losing oil
- Help Installing Rack Pinion Bellows/Boot 94 Accord
- SEAFOAM?
- 1995 exr v6 question
- 1996 honda accord lx exhaust resonator removal
- VSS
- No spark and no fuel
- 99 accord Change ECU, can I do it by myself??
- Advice on how much to bite off and sequence at one time for my situation
- 97 accord ex clutch
- Window Regulator
- Engine & Steering Shutter Issue
- Car wont go into gear...
- TL-S interior in a 6th gen accord sedan
- Timing belt broke as I was starting my 90 Accord. Are the velves bent?
- 6th generation rebuilt transmission problems.
- Coolant loss and eventual overheating 92 Accord EX
- 02 accord Radiator issues, need help
- Crankshaft Holding tool
- 1995 Accord LX oil pan gasket
- 1995 Accord LX power seat install
- Yikes!!! brakes ohh noez!!
- Charcoal Cannister delete?
- 99 coupe main relay problem, help pls
- question
- 96 accord trunk bedliner removal and installation
- Oil Found all over my spark plugs.. Please help!
- Is there an online PDF Manual for things like changing Clock LED's?
- burning antifreeze
- Removing Gauge Cluster - How To on 94 Accord
- ► Announcement: Honda-Tech Terms of Service
- 2000 Accord EX V6...coolant temp problems, etc.
- 1995 H22 Accord is cutting ouy at 7k
- HIDs in halogen projector
- HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Speedometer stopped speedometering. :(
- Offset
- HELP with A/C
- 2000 accord problem with wipers
- Advice on Performance front axles for 95 accord
- Car jumps when changing gears..
- 96 or 97 honda accord ex
- 99-9 CEL Code for EM1 B16A2
- 94 Accord - Failed CA smog after light mods.
- A/C not blowing cold but compressor is running and free-on level is good??
- '92 Accord- Lighter fuse blown???
- Intentional Open Loop Mode
- 92 Accord Quit This Morning
- NEW SUSPENSION BUILD!!!!
- Anyone running the Treadstone kit?
- California Enthusiasts, Please Respond, Trying to get a Yearly Smog Check
- 1996 Accord V6 getting very poor gas mileage.
- legend 2 piston brake
- Center Console Removal? (2002 Accord lx)
- 94 Accord Wgn stalls while driving, then starts up again.....
- 93 honda accord slop in steering wheel after rack/pinion replacement
- 93 honda accord "SRS" light will not go off
- 98 accord v2 HELP!!
- 91' Trans Problem Park & Neutral = 1st gear
- 1995 Honda Accord EXR - noisy engine
- How light is your 5th gen steering on highway?
- f20b fuel/ lack of it
- timing belt for jdm F20b?
- A/C Evaporator
- f20b in 98 accord
- Engine Code P1166 & P1167 2002 Accord SE/EX
- 1999 Accord w/ 300K miles!
- distributor clicks
- Megan Racing lowering springs
- Anti-Freeze from vent for less than 10 seconds
- No Spark!
- Removing Flywheel bolts, clockwise or counterClockwise ?
- Skunk 2 Lower Arm Bar saga
- Check engine code P1166 and P1167
- 2002 honda accord Maintenance light
- Top Front Shock mount.
- Front brakes locking up
- dimmer lights
- Needs confirmation on alternator issue
- Clicking noise, already changed both axles
- Which distributor do i need?
- E-Brake Light
- H&R and NEUSPEED springs
- Has anyone bought or used these dual color LED turn signals?
- Car sporadically stalls, ignition switch?
- 2002 accord se coupe suspension, headlight issue
- 94-97 ACCORD side skirt removal.....
- During Comp. Test: Haynes Manual Says "Fuel Pump Fuse"?
- need help? does anyone happen to recognize this kit?
- upgrades
- oil in spark plug
- 94 accord tail light disassembly; I need help!
- ck engine light
- head unit
- check engine light comes on
- Oil in Coolant - Please Help!!!
- Radio not turning on/jammed tape
- Groaning noise from engine
- transmission locks up!!! please HELP...
- orange headlight reflector strip removal
- How do I remove the OEM lip for a 94-95 accord?
- 1992 accord OEM front bumper
- Civic 2002 LX Trunk Lid
- water coming from the blower
- 94-97 power folding mirror
