View Full Version : Honda Accord (1990 - 2002)
- another honda wont start
- 92 Accord oil change
- turbo question and size
- 92 accord door handles
- '02 HELP: my engine is roaring after replacement of the timing belt
- Bleeding Brakes Tomorrow
- CEL when coasting on 91 CB?
- having suspension problems
- compression check f22
- Noobish question on exhaust tip and rust prevention
- turbo current engine or rebuild first
- Picture with labled parts if Accord under the hood
- 91accord doing a swap to a h23 5spd driver side axle problem
- h22 accord swap help
- building an f23 non-vtec... need info on head and deck heights.
- Fan runs hours after being driven?
- rough idle when cold
- no fire h22
- Grinding noise from the right wheel (psg side) when turning hard to right
- dead cylinder?
- Replaced battery terminal now hard to start?
- wireharness
- Check engine light
- 205/55/16s and a 2.5" drop?
- Need Help with old A4 Engine
- 01 Accord factory alarm - adding siren?
- Transmission Replacement & No D4 Light
- i dontk now why these got deleted or before, but a few vids of some runs in my acclude
- Valve Tapping or Ticking ?
- Honda 2002 Whistling sound in reverse?
- Broken Bolts
- looking to put a H22 head on my F22 block
- For those who put a shift boot on a 6th gen automatic
- Accord @ 103K miles just finished full tune up..what else
- will a 97 OEM steering wheel fit in a 94?
- 93 accord Automatic with Issues
- Anyone use Pulstar Pulse Plug spark plugs? Are they any good?
- 99 V Tech Accord Gauges Are Messed up Help!!!!
- steelies on a 5th gen accord
- Cluster question
- Acura wheels fit on a 6th gen accord
- Sold my 96 Accord EX today :( Problems I've had with it and my thoughts...
- 01 honda accord motor swop
- 94 accord ex with check engine code 12(EGR)
- Will a 97 prelude shifter cable fit 94 accord?
- how to install m3 mirrors with leds.
- 1993 Accord LX electrical issues.
- 98 accord f23 transmission with LSD??
- Brining my car out for summer question
- 96 Honda Accord has no Spark
- 1992 Honda Accord LX Coupe Won't Start After Compression Test??
- Rough Idle/Vibration with/without A/C on
- putting 94 accord ex engine and tranny into 92 accord lx
- i need vacume diagram
- 1996 Accord with code p0420- cat converter...help
- How important are oem torque specs?
- Accord 96 2.2 engine failure
- turbo motor in 4dr accord?
- 93 4 dr....is it worth it
- 92 accord with h22a1 i need help
- oil leaks
- 94 trans into 90 accord
- 91 accord sedan engine won't rev above 3500 RPM
- H22 crazy
- 1994 Honda Accord EX Second Timing Belt Replacement
- sri hissing noise
- Acura body kit on CB7?
- Non-vtec 96 LX to vtec conversion...
- Top hats from 90 accord fit a 97?
- main relay and starter question
- power windows help
- Front End Rattle
- what happened to my video thread from earlier? is that against a rule, if so, im sorry...
- accord part info
- 1996 honda accord dies while im driving!!!! whats the prob????
- car wont start
- First Honda, 1989 Accord...body panel questions
- timing belt drive pulley removal
- help on trannys
- injector o-rings
- Turn signals and hazards do not work
- Turn Signal wiring help needed
- Accord body question
- f22b wit h22 head
- Electic Motor Accord
- HUGE Problem with Idle!
- Project Car Tuner Magazine issue #5 Cd5 budget build
- How hard would it be to....
- a/c compressor question
- 92 Accord EX Driver Side Lighting
- Slow idle after timing belt change
- Bizzarre heater blower problem
- 99 lx coupe upgrades
- What else do I need to get next?
- F22b Rebuild kit???
- How do i know if my accord comes with a AIRBAG??????
- Just did my rotors...
- No Cabin Filters = ?
- 90 Accord
- lowering springs/ OEM shocks
- accord 95 side marker install help...
- Where is the IAT sensor on a 2001 Accord V6??
- suspension questions
- rpm problems
- SIR Headlights 94-97 Accord
- 97 v6 Strut Bar
- Putting a f22b dohc into my 95 accord lx.
- help timing problem
- Hole in Firewall for wiring?
- my accord is like the ultimate sleeper right now lol (this is a joke thread, it's really not that fa
- QUICK:: accord radiator question
- 89 accord over heating
- 95 Accord DX electrical issue...
- Will the shifter assembly from (92-92)prelude fit accord?
- OEM steering wheel removal and install question
- Speedo freakin!! NEED HELP!!!
- 92 Accord having trouble starting...
- E-Bay "tuned" chips?
- AC Panel Problem
- Can someone explain....
- 1997 accord 2.2 with Code 35 Error
- direct fit Hitch will not fit!
- 94 accord lack of power
- F20B Auto (180HP) vs Manual (200HP)
- After EGR cleaning
- New Exhaust...
- 1996 Accord Auto Kickdown Rev
- difference between muffler and tip?
- Replacing auto tranny shift knob
- Speakers not working, no sign of connection problem
- 94 accord power mirrors stopped working
- 94 4dr accord power door lock problem
- swap shops.
- Tire Width Question
- 96 Accord won't start after sitting up for 4 years.
- help with my v-tec asap
- HELP misfire!!
- Rims for 2002 Accord
- 96 Accord (Coupe) Auto Door Locks, they both lock but do not unlock.
- blower motor...?
- need help and options 90 accord knocking noise
- Possible 1st gear problem
- f22b1 question?...plz help
- 91 wagon headlight issue(not removal)
- 2001 Honda Accord Ex losing Oil quickly
- headlights?
- ABS Starting Noise
- skunk2 cam gear
- Thread Pitch and Valve Stem
- Problem with Power Lock
- need a writeup on f23 tbelt change
- 5th Gen Rotor Change: Do I need a press?
- light alignment problem
- 98 accord, h22 swap, driveshaft problems
- can i use white lithium on..
- Engine and Transmission type
- JDM power folding mirrors question
- Parts - ca't find - would you help ?
- 94-97 Front Bumper Light Question
- 92 Accord no spark
- Forsale: apexi wold sport 2 catback for 94-97 accord
- need serious advice about bent valves...
- 2000 accord/ maint req't
- 94 accord timing belt help
- New Clutch Problems
- Do I need an alignment after....
- DC Sports front strut bar for accord question
- Looking to rebuild a 92' accord lx. Looking for someone with experience to give help with some info
- Interior Color Code Clarification
- WTB 4x114 accord rims
- Check Engine Light Accord V6 4DR 97 model.
- Wheel Specification of Accord 97 V6 ??
- stock radio help
- 98' accord coupe cl-6 swap
- ABS 2-1: How do I fix?
- brake liight trouble on 1991 honda accord
- Plz Bare with me...
- gas prices!!!!!!!!!!!!
- clicking sound when turning
- 90 accord makin noise??
- Prestone DOT3
- My dirty accord.
- Power Steering Gearbox Question
- tranny problem 93 accord ex
- H22 Euro R swap, half shafts too short.. where to get longer half shaft...
- VTEC Question
- I'm a nub, question
- Which Header should I use??
- (94 accord dash board) How do you take this bulb out?
- 1994 honda accord ex. V-tec won't kick in.
- need help will be swapping soon..
- How can I tell what type engine I have?
- Hi there, I'm a new guy.
- vtec hookup?
- 94-97 Accord coupe/sedan euro clear corners for sale
- 94-97 accord euro clear corners for sale
- 95 hard brake lines to the rear?
- cam gearz questions
- Springs/shocks or catback?
- Need help for parts
- H22 Tranny Question
- Help Transmission and Coolant Fluid
- Custom Pedals
- question about f22a4,f22a6
- after market headers for f22 fit f23
- Keep blowing a fuse..
- flip switch
- F22B vtec to F22B non vtec?
- timing of balance shafts 96 Accord 2.2L
- no start
- wierd door locks problem
- Jack point on a 96 Accord?
- aftermarket dsm manifold on f22a
- New guy and car won't start
- Radiator
- HID kits?
- Help! Issues with 4th cylinder?
- Scraping sound??
- Car Wont Start HELP !!!!!
- injector size?????
- CAM GEARS
- weatherstripping
- Oil leak diagnosis, hellos, and pictures to help- :)
- Timing Belt Cover
- Went to change my wheel bearing/hub assembly...
- Some pics Of my Low 95 accord coupe for the photo gallery.
- strut Bars!!
- need help with f22b2
- turn signal is not working on 96 accord lx
- short shifter
- Dropping my 95 Honda Accord EX
- Couple problems...need some suggestions.
- Help! timing belt crisis on 92 accord
- custom exhaust made check engine and maintenance lights come on
- 97 Acord convertor locks and unlocks at highway speed
- 99 EX Accord
- Taillights for 94
- 97 Muffler
- What are some things I can do to boost my car?
- boosted h22 issue
- 1990 honda accord ex transmission problem
- H.U.D. possible?
- CAI filter cleaning. hassle ?
- Need Help ASAP... Car Wont Turn On...
- issue with v-tech
- IDLE ADJUSTMENT
- 94 automatic accord suggestions????????
- best motor for boost???
- help! 98 Accord LX idles low in neutral and it stutters!
