PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 [348] 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. 92 accord crazy RPM tach .. when 1st start car
  2. Blinding headlight...high beam not on! Help!
  3. Whats a good snow tire?
  4. Rods for f23a1
  5. Where to get rare used acura/honda parts?
  6. WIll a 105/80/D13 spare tire from a Geo Metro Fit ??
  7. Surge at idle
  8. Cupped tire sound from front end
  9. Heater Contorl Question
  10. Accord LX V6 Preformance Chips
  11. Give me the facts on these ebay coil-overs
  12. Found a used car, how do these specs look??
  13. low exhaust sound!!! i don't like iT
  14. Engine type, body type, blood type? Newbie needs assist.
  15. HELP ME PLEASE!!! My car is over heating
  16. Clutch master cylinder help?
  17. OT: nice accord website
  18. Oil on plugs on 89 Accord
  19. h22a in 91 ex accord
  20. Wiring for 4th gens
  21. Bought a used '97 accord
  22. Newbie...just wanted to say Hey!
  23. Problems with my 1990 accord ex (shift lock among others)
  24. FL meet
  25. '94 H22 auto tranny in '90 F22 auto accord???
  26. Will a JDM Sir sterring wheel fit?
  27. So thats why my car wouldn't start.
  28. is this a good price for a 94 accord?
  29. h23 swap in a 4th gen - tranny mount question
  30. What is the usual RPM idle in park
  31. Actuator Symptoms
  32. I need help
  33. Cheap Place to get the Accord Antenna
  34. manual/tranny conversion accord owners
  35. Vacuum Leak?
  36. swap the f23 for h22 or do a few things to stock block and spray a lot
  37. aftermarket pistons and valve components for 90 ex
  38. Buster Door Lock
  39. Turbo my 4cyl accord
  40. Question About Dash
  41. Sticking Idle
  42. Brake booster repair cost
  43. HOT! LA AREA: 97 2.2 Acura CL 16" 4x114.3 OEM Alloys w/ Nittos $200
  44. Which tires would fit?
  45. Jackson Raceing superchargers
  46. EX intake manifold onto my 1993 LX?
  47. Question about lug pattern?
  48. Throttle Body Spacers, anyone have any info on them?
  49. tb trick
  50. Where can i find?
  51. Pros/Cons of Resonator Removal
  52. Do the 96-97 and 94-95 Lights
  53. what lips do they make for the accord?
  54. which tire should I get??
  55. which tire size is better???
  56. H22 4gen accord swappers with turbos, what manifold are you using?......
  57. 4th gen (90-93) and 5th gen (94-97) exhaust will they fit?
  58. Rattling under my accord?
  59. Bench bleed on car?
  60. Replacing axles=alignment?
  61. Heating Problem! Help
  62. parts for h22a in an accord
  63. supercharger or turbo?
  64. Friend's NXed 2001 Accord
  65. performance for a 91 accord lx
  66. '90 Accord - How to change clutch fluid
  67. help please
  68. Axles
  69. buying a used accord! Where! Help!
  70. Tough Windows!
  71. OT: Whos accord is this for sale?
  72. Who here had 300+ from a f22b1 turbo'd?
  73. Immobilizer Problems...
  74. what fluid comes out the transmission housing breather tube?
  75. My Problems.............
  76. manuals
  77. Overheating issues...
  78. jdm h22a vs. jdm h22a type-s
  79. f22 build up
  80. Center Console/Ebrake console "swap" for 4th gen......
  81. about spark plugs
  82. "Sport shift"??
  83. anyone sell a turbo kit a few months ago?
  84. timing belt
  85. OT: Who are you?
  86. Underdrive pulley questions
  87. anybody got a carfax account?
  88. soon to go turbo. Any feedback 4 me?
  89. Guys with MT experience, whats your usuall stop at a red light procedure?
  90. Online OEM parts catalog
  91. tires
  92. New Blood
  93. 205/40/17 kumho tires
  94. I think i Have a SHORTAGE...helpppp!
  95. Got some goodies this weekend........
  96. Lowering spring and shocks or coil-overs?????
  97. jdm h22a swap
  98. Cylinder Position Sensor Malfunction ??? Code 9
  99. Is this a broken TPS?
  100. Noisy exhaust
  101. Timing belt, water pump and gaskets: $1,100 from a Dealer?
  102. What does a flywheel do?
  103. transmission help, needed
  104. 1990 Accord 3-point seatbelt conversion?
  105. OT: Video from The Columbus H-T Meet
  106. ............Everyone please read PART 2!
  107. I'm selling the Accord
  108. Timing and Fuel Problems in 99 Accord w/ F-Max kit
  109. Does this happen to your 5th Gen?
  110. what engine is in the euro accord r?
  111. car dies at low rpms
  112. turbo manifold/gasket leakage..?
  113. What is the biggest HORSE POWER turbo, I can put on a '91 Accord EX 5sp 2.2L?
  114. car gets no spark when air temp is below 40.
  115. At what RPM is the water pump more efficient?
  116. how do i change signal lights?????
  117. OverHeat problem.....WON'T GO AWAY!!!! Help
  118. Rims
  119. is it ok for the auto tranny from D4 to D3 to slow down on the highway?
  120. Shifting faster with an auto
  121. ATTN!!! so cal peeps! MUST READ
  122. 1992 Accord - Replacing fuel filter
  123. Interior light. "Headlight's on" Warning Sound. Int. Windshield Wipers. All not working
  124. Anyone lower a 5th gen with H&R or Neuspeed sports??
  125. Timing Belts, Valves, Timing, Idle and other various problems
  126. Specs on the F20B DOHC VTEC
  127. Where is Kteller8?
  128. are both O2 sensors interchangeablt?
  129. What parts are swappable from a 1g legend to a 4g accord?
  130. Stiff Throttle
  131. Air in system driving me loco!
  132. 80 lbs of torque at the lugnuts!?!?!?!?!
  133. Accord clutch kits.
  134. How do I take out my stock Head unit ...1992 Honda Accord??? NEED HELP ASAP
  135. Wrong axles?
  136. Squeal at start up
  137. "Wrapped Accord"
  138. burning white smoke
  139. oil in my valves!!
  140. replacing window unit
  141. My beater Keep on drain out of battery
  142. 95 Accord EX ABS light
  143. EX-V6 6 speed...(heads up for the accord crew!!)
  144. In the market for sway bars f/r for 95 accord. Any recommendations?
  145. My Brakes are smoking...
  146. what flywheel are you using?
  147. Wheel theft in NYC, please help!
  148. would a accord 96-97 rear upper strut bar fit on a 95 accord model?
  149. 93 stereo, Kenwood cd changer
  150. need help with 94' Accord ignition
  151. 1995 accord wagon
  152. Vacuum lines off throttle body/intake manifold
  153. how the hell do you get the cruise control panel off the steering wheel?
  154. the shiftlock for the brake and trans
  155. Bolt pattern of 92 Accord????
  156. CEL code 9
  157. Help w/ RS*R springs???
  158. Injector Plug Question
  159. Help on ECU reprogramming.
  160. Dark Grey Smoke right after start up....
  161. 98 V6 Accord Coupe .... need help
  162. SSSHHHing sound....
  163. 93 Engine differences between EX and LX, ECU change?
  164. need help, blowing blue smoke
  165. Car wont start under cold conditions
  166. Header installation price range
  167. CEL code 90
  168. accord manny tranny vs accord auto tranny
  169. trouble with sunroof
  170. Advice needed; interior fabric unraveled from door panel
  171. Factory Radio Code on a 6th Gen Accord
  172. Need tech Help with H22 accord. Car is not starting.....
  173. How reliable are the older Accords?
  174. OT: accord 00 cd player to my 90 legend(sorry Nick)
  175. Energy Suspension: What did it do for you"
  176. LONG ISLAND , NEW YORK cruise night this saturday...check it out..
  177. Tein HA or Koni Yellow/Neuspeed Race?
  178. water pump
  179. manuals for accord
  180. How difficult would it be to replace the front main seal
  181. stock engine or not????
  182. model hx??
  183. Problem with h22a cel
  184. 00 coupe offset
  185. loss of power when accelerating
  186. Why does my 93 accord 5spd take so long to drop in RPMs?
  187. Would seats from a 3rd, 4th, 6th or 7th GEN bolt right into a 5th GEN?
  188. an accord wit h22 1/4 mile times???
  189. www.discounttiredirect.com says 17's can fit 235/40 on an accord, will they?
  190. Questions on installing poly-erethane bushing kit
  191. What ECU is your hybrid accord running.
  192. KYB G2 shocks
  193. Could a moderator please move this thread to the apporiate forum?
  194. post your ride
  195. The best way in removing the High Pressure PS hose ?
  196. F/S: 1991 accord EX high miles, many parts replaced, and MODS
  197. Accord ECU reprogramming
  198. Spark plug questions
  199. wait a bloody minute....throttle body observation
  200. how long do I have to be a trial user???????
  201. 88 Accord Lx-I Engine swap
  202. Open door alarm
  203. RotaryBzzz's Tricks to Make Your Accord Pass Smog Checks
  204. newest accord 1/4 mile?
  205. Power window prob.
  206. what clutch/pressure plate are you guys using?
  207. Question you guys got to answer?
  208. Buying rebuilt tranny's?
  209. alternator problem
  210. why cant I.....
  211. My exhaust?
  212. F23 Turbos
  213. 93 Accord Failed emissions....question
  214. engine problem
  215. 90 Accord H22 Tranny Mount (yep, tried search)
  216. What are H22 Accords (94-97) going for?
  217. need help finding a tranny
  218. which OPTIMA batteries
  219. My Old 5th Gen Accord
  220. WTB: 5th Gen EX rims
  221. need help 97 lk accord cam install
  222. Future Reference
  223. ground wire for accord 92
  224. 92 Accord - Front Axle Replacement
  225. 92 Accord - Timing Belt Change...Tips?
  226. Neuspeed front strut bar from 93....anyone interested?
  227. JDM Headlights: Rewire H4 to both high and low beams
  228. help with v6 caliper & rotor upgrade...
  229. 1993 "Small Light" Fuse problem
  230. Rubber bushings
  231. Too much oil in a motor
  232. collectiveracing.net
  233. 97 Accord SE cooling fans question.
  234. Main Relay
  235. How good are KYB GR2 gas shocks?
  236. Would ITR or CIVIC streering wheel fit on ACCORD?
  237. Where can I get........
  238. anybody know of any good shops to get hybrid engine work done
  239. new member
  240. What would cause the Timing belt to slip off top gear?
  241. 90 accord lx going wacky, help
  242. bilstein hd or kyb agx on sportlines
  243. Whats up HT
  244. Honda Tech Nashville meet
  245. Blitz exhuast
  246. fellow HTer's I need your help.
  247. Big James
  248. 4g boost
  249. What Site Could I Go To 4 Wheel Hub Bearings For Honda Accord 90?
  250. H22A sohc?
