need help for "2oo2" accord ULVTEC accord (ecu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy frank »</TD></TR><TR><TD CLASS="quote">need a whole wire harness diagram for a 2002 ULEvtec ecu having troubles w/ vafc install.any one know of a web site i can check for</TD></TR></TABLE>
i dont know what the hell your talking bout? ULEVTEC? what is that?
you just need pin diagrams/ or what?
that's filthy frank as know as my "Vtech" master..
actually he's hooking up a vafc in my car..
ULEV
Need: ecu pin out with color coded wires
for 02 SE ULEV accord f23a4
ULEV
I thought 6th gen. I4 Accord engines can't use V-AFC because of the variable VTEC. The V6's are fixed but the I4's are variable for some weird reason. So how did you guys get around it? And is it still variable after you put in the V-AFC?
By the way, you can see the pin layout from your service manual probably.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">what adapter?
mine is hard wired... and it was a shitty experience... I hate wiring bs.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">
can you find me a pin out like this for the stock harness?
the only problem i'm having trouble with is the pressure switch for the map sensor. not sure wich one it is? did not have time to finish the joby job
so if you know off hand what color wire it is, help me out
thanks
thanks
KrakusEK
Dec 29, 2006 12:58 AM
brian2903
Dec 11, 2003 06:24 PM
