View Full Version : Honda Accord (1990 - 2002)
- Turbo Timer
- car when at idle drops to almost zero and when slowing down cuts off
- question about door handles
- door locks
- Changing manual Trans Fluid 2005 Accord
- boosting my accord
- 6th generation sedan suspension
- 99 Accord stalling after startup
- 1986 honda accord w/ carb. won't pass smog C.O. at 2000 rpm.
- need help with idle problem on 97 honda accord
- has anyone changed the ignition switch on an 01 accord
- exaust
- Has anyone done a Gastank on a 98-02 Accord?
- Anyone changed an ignition coil on an 01 accord v6?
- 86 honda accord smog failed C.O. really high at 2000rpm.
- accord radio code
- accord coilspring
- 1991 accord seat belt retractor
- NEED HELP 94 Honda accord overheating
- My f22b1 Build
- Why does my car shake, not a simple wheel balancing issue....
- Biggest size wheels on 89 accord
- Strange engine or eletrical problem? And an A/C question
- strange start up routine
- R1 Racing Rim Quality???
- h23
- SPEED LIMITER
- need help!! a/c problem
- 6th gen auto to manual (specific question)
- Won't rev over 5500 RPM - normal ??
- Do you have to remove the front motor mount to remove header?
- Will Civic ICM fit Accord Distributor?
- Short shifter: PSPEC vs Forbidden comparison
- 96 accord with obd2 h22 swap distributor help ???
- check engine light indacator
- Axle shaft stuck in wheel hub trying to replace front rotors
- dash buttons
- jdm bumper lenses
- spark plug wires
- engine swap V.S. turbo
- A/C not cold
- Transmission "jerky" when shifting
- Header downpipe bolts...
- Fuel Gauge Light always on...
- TURBO!
- RPM SHIFTIN
- speed limit breaker...any idea!!!
- check the concept accord coupe
- rear control arm?
- any tips for a K24A?
- CD mounts interchangeable w/ 92-96 Prelude mounts?
- H22 in an Accord 2000 ex 4dr
- h23 swap funny idle
- Fog Lights
- Auto to Manual conversion....plus engine swap
- New axle, still clicking?
- Best option for F22B2 and H23A intake
- 91 accord with an f22...what exhaust can i use?
- weird problem adjusting valves on H22A
- Can someone with an EX CD chassis help?
- where to buy turbo
- Honda Accord Gasline Replacement
- Need help on repair honda accord seat
- F22 DOHC parts
- Running rough on idle and before 3k
- Looking to purchase a used Accord.. Need advice and Info..
- H22A SWAP PROBLEM
- A/C Compressor Clutch Relay
- egr lift valve
- CEL on 1997 Honda Accord LX
- 2007 Accord Coupe Rear Lip Spoiler
- widest tire width on stock accord 6 spoke rims
- Transmission Fluid Leaked!
- ABS modulator problem need help!!
- Radiator fans and a/c
- f20b engine...
- Need some help installing Cam! Please!
- skeptical about h22a swap, opinions please!!!!
- Exhaust leak?
- Got the car working (auto to manual swap) - weird problems though!
- My 95 accord needs your help
- IDLE PROBLEM
- 95 honda accord ex towing capacity?
- 1991 Honda Accord EXR Help Please
- Wheel bearings going out, rear
- H22 Swap
- carbon fiber trunk for a 94???
- 95 accord v6 engine
- ACCORD 1991 GUID BOOK
- 94 lx, code 41
- 99 OEM CD Player
- Radiator fan problems
- Liquid Gasket for F22A Rebuild: Preferences?
- Transmission removal
- Need help removing bolts from rotors
- lip kit company? 98 accord
- 1994 Accord check engine code 41
- need some help with the tires......
- EGR Valve
- 02 accord, air conditioner not working
- Engine Swap 5th Gen...
- INSTALLING A DIGITAL TACH....HELP
- 2003 Accord "Break" indicator light stays lit????? Help
- HELP! PLEASE! 90 accord radiator problems!
- Suspension Thread (contains Pictures and Specs)
- 1999 Accord shaking
- lsd in a f22 tranny? possible?
- overheating problem
- Hayame Coilovers?
- F manual transmission
- What do I need to swap a h22a
- Auto to manual conversion
- My air condition is finally stopped working !
- automatic shifting
- valve spring questions
- 99 accord front bumper for 2/4dr, the same??
- questions about exhaust rattle...if anyone wants to tackle it....
- LIP KIT
- quick question about 97 accord turn signal light
- Help! 1998 Honda Accord LX Not Starting
- how to fix the panel lights?
- HELP TO GET THE RADIO CODE ACCORD 1993
- A-Arms
- new guy-questions about rough idle
- Transmission question
- 86 accord tranny problems
- BODY KIT!
- 2002 auto trans into a 1998 accord
- wierd code being thrown need help
- 88 Accord trouble
- mileage has stoped working
- Transmission 92 Accord
- Turbo h22 help
- 93 accord trans
- 98 accord shifting problems
- Transmission swap
- Distributor Problem. Need help.
- 99 Accord LX - loud creaking noise
- How to fix a 97 dash panel lights?
- CV boots cracked, what else can i replace while im in there?
- 2007 accord LX ipod adapter.
- 97 honda accord blinkers stop working
- my tail lights are on acid.
- chrome trim on my whip...
- Cleaning EGR port
- 2000 honda accord (timing belt) help
- Looking to do 5 lug swap
- how to remove inner tie rod on a 94 accord
- Tokico HP's with Tein S. Tech springs?
- remove 36mm axle nut on a 94 accord
- MANUAL SWAP!
- antenna removal ... lost parking lights
- Replacing cat with test pipe on 97 F22b2 - gains/sound changes?
- 97 Honda Accord NO Compression Help???
- SUSPENSION/WHEEL SIZE QUESTION....NEED HELP PLZ
- 98 Accord dying at idle, tachometer jumping/jerking while driving
- Brake Problem
- Which is better?
- TURBO!
- Got my Forbidden shifter
- 92 accord turbo f22b1
- h23 trans mated to f23 engine
- 88 Trans Problem
- Can't get keys reprogrammed! ECU/auto to manual swap problem!
- Park doesn't work anymore!~92 Honda Accord LX
- Need help!!oil light on my 90 Accord?
- belt issues??
- 92 Accord DX Rough Running / Hesitation when warm
- how to change fuel filter
- ebay strut bar? or name brand? tight on money. same w/ pulley
- 97 Honda Accord Coupe wont crank wait 15 /20 then does crank Help?
- no power to my center console wtf...!?!?
- Water Mistory
- ECU Codes
- car slow to start
- Good Suspension Upgrade
- 02 sensor I suppose?
- Just did a compression test
- EVAP Code??
- 1996 Honda Accord LX, cranks but no start.....
- 05 honda accord wiring diagram
- 90 Accord Distributor
- Dust cover for clutch/flywheel? 6th gen.
- sleeved h22
- 1999 accord ex help
- Headliner replacement technique?
- 1999 Security System Malfunction
- MY SPEEDOMETER IS NOT WORKING!!!!!! HOW TO FIX???
- Pulling cel codes on 91 honda accord lx
- Acceleration Problems
- ABS Light question
- EGR valve situo.
- Heater Blower - 93 Accord EX
- Head porting in Richmond Va
- Turbo install
- j32 6spd on a j30????
- New member looking for some cheap upgrades
- Sprayed engine -WON"T START
- Can't get a/c blower out
- Apexi SAFC
- 95 accord idles up and down
- Differences between the Coupe and the Sedan other than the obvious
- What accord's body kits is this?
- accord 98-00 drum to disk break conversion!
- im looking for a transmission
- 96 accord....start problems
- Is this normal? (city mpg)
- skunk 2 intake
- TCS light switch
- accord dash lights went out
- h22 swap
- h22 swap into 93 accord
- Hard to Start and dies most of the time when driven
- Replaced headgasket, car sounds strange (loud).
- 1995 Accord Brake Shimmy/Shake after Changing Rotors and Pads.
- K20 Crank
- Code clearing question
- CD5: just fixed the light for Drive,but now.....
- Flowmaster 60 Series Delta Flow?
- My complete cb7 progress thread, from na to n2o, to turbo
- Increase off the line power
- check engine code
- clock light?
- maintenance minder?
- skunk 2 adjustables? or save up for the good stuff?
- Brake and Gear Problem
- Prelude rear seat covers in CD5?
- Is Dot4 brake fluid better than dot5 for street applications?
- Suspension sounds?
- Front end noise
- engine code
- 91 Accord Auto Trans.
- f23a jge head with over sized valves, jge racing intake, and jge 58mm tb bore
- o2 simulators....
- '07 - check gas cap
- what size wheel speacers did you guys use for your 96spec itr's?
- 90 Accord LX engine question
- '88 Accord LXi (Ongoing) Hot/Warm Starting Problem
- Idling rev and drop
- How to Install a 93 Accord Bodykit????
- 2007 Accord
- Type of 91 Accord Radiator Cap
- 2003 EX Sedan Wheel offset?
- 97 LED tail lights?
- Help please. '97 honda accord - high idle, rough when shifting down.
- ACCORD NO SHIFT PROBLEM
- How do I put my Accord into storage for 10 months?
- Ac lgihts on dash panel are out----96 Accord LX---Help PLZ!
- Innovative Mounts
