5lug swap with camber problem!
i recently, did the 5lug swap onto my 5th gen accord! and the best way to describe it is, if u look at my car from the front, u will see both wheels curved inwards, in other words, the camber would be on the outer side of the tires!
the camber now is positive, i was told by someone that camber kits only adjust negative camber? in any case, the same guy told me the only option is to bend some pieces!
so now im here, i thought id ask u brainiacs about this before i start bending things!
any helps much appreciated!
thanx guys! :>
thanx guys! :>
try buying the Prelude radius rods and lower control arms along with the tire rods
we looked at it pretty hard once and you would basically have to swap the whole Prelude front suspension to have it work correctly
Yeah, but I used 95-97 Accord V6/Odyssey knuckles because I knew they would fit.
I said in my first post on this matter that Prelude parts could be used, but you need ALL the Prelude parts.
Compare:
95-97 Accord V6/Odyssey:
97+ Prelude:
The differences are subtle, but they are there.
Compare:
97+ Prelude:
i donno, the thing is, i told those jabroni's that i would have to use the entire front of a prelude, the day i brought my car in to get it done, i see the guy bring in only the knuckle and hub/rotor/caliper...thats all!! fwwwooock, im gonna kick the shiza outta him!!
hehehehe lolz..true that!.....friend! :>
oh well, no biggie, that just means that he'll be responsible for bringing in all those parts! which are....?? mind helping me out, friend? :>
but aren't the v6 ones designed to be at a different angle because of the heavier load exerted on the suspension from the v6. the f22 motor is lighter so there is less load on the shocks. thats just what i think, i may be wrong. it was just a quick common sense response.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by After_Burner »</TD></TR><TR><TD CLASS="quote">cool deal, thaaanx broootha! :>
hows the 5lug goin with u??</TD></TR></TABLE>
Loving it. Have had not a single problem thus far.
well...thats good!
i dont think mine will be a problem much longer!! i had emailed him to demand i get those other parts!! :>
did u read what "brad94accord" wrote above ya?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord »</TD></TR><TR><TD CLASS="quote">but aren't the v6 ones designed to be at a different angle because of the heavier load exerted on the suspension from the v6. the f22 motor is lighter so there is less load on the shocks. thats just what i think, i may be wrong. it was just a quick common sense response.</TD></TR></TABLE>
Nah, the V6 knuckles were IDENTICAL to the I4 knuckles, except having a slightly wider hub/bearing mounting point. Bolted right up, no camber, caster, toe or fitment problems, period.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Martaigne »</TD></TR><TR><TD CLASS="quote">
Nah, the V6 knuckles were IDENTICAL to the I4 knuckles, except having a slightly wider hub/bearing mounting point. Bolted right up, no camber, caster, toe or fitment problems, period.</TD></TR></TABLE>
oh ok cool. i guess i was wrong.
moto44
May 3, 2018 06:49 AM
dohcnotec
Sep 23, 2004 12:41 PM
Then you can't get screwed by any meathead jabroni's.
