View Full Version : Honda Accord (1990 - 2002)
- Compression Ratio
- WHAT ELSE CAN I DO
- DASH LIGHTS OUT
- camber kits?
- are tune-up's worth it?
- help with engine and maintenance
- Most affordable place to get Magnaflow for 5th Gen?
- swapping rotors
- 1997 Honda Accord SRS Module
- technical-timing issue-
- DARK CLOCK AND TEMPERATURE CONTROL LIGHTS, '98.
- help gas
- help
- Cat-Back Confusion
- What is the interval to change a timing belt on a 98 v6 accord
- suspension problem after installation
- '91 Lx taking in water
- this sucks gAss
- finally found a pic
- Pistons?
- Need help with wheel bearing part number.
- civic dash AC >button cover< easy question
- No longer Accord :\
- Removing the deck of a 92 accord
- Quick Help Please - Pictures Inside
- 95' accord h22a baseline dyno run
- Fuel injector cleaners
- accord to acura CL front end conversion.
- Rim size
- Blinking D4 light
- Airbags
- Has anyone heard of this or tried it at that?
- 91' Accord with a front end sqweek
- For people with "Battery Stabalizers", question
- What would you do?
- Vibration/Shaking with idle
- finding a door latch
- dash lights dont work
- Belt Under Alternator~~HELP
- will 18's rub?
- 1983 Accord Tranny into an 1985 Accord
- Problems after Battery Disconnected
- *child lock is permenantly????
- Ebay Strut braces
- wiring vtec
- ABS Light Stays On...Wierd...
- Need help on rear lip
- new 17s
- Recommendations for shifter
- 6th Gen Turbo stuff, AEM intake, + more
- check fuel cap light
- 9006 HID Adjustment
- Rear Calliper - Bleeding
- Idle Issues
- HELLLPPPP
- Turn signals dont work on front or rear!! 95 accord V6
- So...Guess Who Won the Race Today?
- oily spark plug?
- Anyone parting out 94-97 accord?!?!
- cv boot...whatelse?
- suspension question..
- exhaust smells like gas and it also spits brown liquid
- F Series Confusion
- Regular Unleaded VS Premium Gas
- Anyone run this setup yet?
- Anyone tell me the book labor rate???
- 94-97 Accord Bumper the same?
- Need valve cover bolt Part number
- 5th Gen Gauge Cluster Lights
- Power Mirrors Accord
- quick blinker light?
- neuspeed spring owners, need you help?
- f22 pull, pull tranny too?
- H22 vs. F22
- WHY DOSE MY RACK N PINION KEEP ON BREAKING?
- ABS light came on in 99 Accord, but there's a problem...
- Spring and Shocks for 02 Accord Coupe? Exhaust Question Also
- Check Engine Light on OBD II accord
- idle control valve
- Map Sensors Accord/Prelude
- Fully Built Turbo'd f23a1 or H Swap
- Whats the other name
- voltage spike 2000 LX need ICU info
- Cams
- leaking brakes
- Overwhelmed with the exhaust gasket choices.
- Spring Question
- please help!! how do i fix the code p1457 (evap)? 98 v6 accord
- 2000 Accord Coupe EX AT I4 - Mod ?'s
- is there a way to find if dealer worked on the car via VIN?
- Is it worth it?
- Got no heat...
- Heater Core Problem ?
- Crank Pulley bolt
- Oil Pressure light Blinking
- 99' Accord gas guzzler...Need HELP!
- 92 honda accord What is the easiest way to take out the brake rotor????
- HELP! 94-95 Accord Air bag sensers?
- O2 sensor brand question
- Couldnt get shifter to move (automatic)
- PLEASE HELP !!! SUSPENSION PROBLEMS!!!!
- help me, help me please
- Timing Belt
- WHAT TRANNY FITS A f23a1 ??
- 01 Accord Turbo and having problem
- ask-a-technician: slipping transmission, 88 LX-1
- Hood dampers for 2002 accord coupe v6
- evap code and catalyst code,, P1457 and P0420
- Timing Belt repl 90 Accord
- Picture of shifter assembly for a 00 accord? Helms?
- no power steering
- iPod Interface vs. Aux Input Converter
- noises when i turn on the engine.
- Rev limiter
- maintenance indicator
- MSD/Mallory?
- help maintaince problem....
- my car shakes; help
- 2000 Accord V6 Check Engine Code?
- Estimate for repair.
- What do Euro R's make on the dyno?
- New poster needs topic placement guidance
- 98 accord Need Help on what to do..........................
- Vibration when braking?
- NOx emmissions HELP PLEASE!!
- ebay products??
- Electrical problems causing not to shift
- ULEV VTEC?
- No Start
- Power Steering Hard at Idle
- Its a bad day for wiseco!!
- Front motor mount with turbo?
- Idiot tax (it's story time)
- any signs of an alternator going out?
- 99 Accord ex radio security code
- 1992 accord
- 94 Accord start problems... with a twist
- PnP worht it?
- timing belt replacement
- Tokico HP/Illumina......
- send me info
- Car Engine Compartment too hot
- need help!
- 5 lug conversion on 91 accord 4 dr
- turboing a f23 ?
- DIY Clutch Anyone?
- 3rd gear slightly grinds when going in.
- Small accident/Minor Problems
- Car Insurance Comparsion Site
- 93 Accord EX wagon with automatic transmission issues
- 2000 Accord SE transmission
- A/c replacement parts...
- Accord suspension system question
- 1996 Honda accord air bag compatibility
- '03 Accord - Is this a common problem?
- Clutch pedal ?
- Exhaust question
- Requires Maintenance Light, 91 Accord
- Wirering Diagram Accord 95
- Replaced headlights but fitting problem
- Will the oil pan off a f22 fit an h22
- where can i find yellow head light bulbs
- ECU question
- 92 slush box problem help!
- resurrecting 90 accord ex 2.2 motor
- worst weekend everrrrrr
- Brake Pedal Float
- Fails emissions test
- 7th gen 4cyl turbo or s/c question. Anyone done it?
- Need Help finding a Diagram.
- ATTN: 6th gen V6 owners.
- Whats the craziest thign that you have done for your accord?
- Sunroof Rattle
- Power Steering Pump Leaking on my 1997 Accord LX , need some advice. Thanks!
- maintenance Rquired AGAIN?
- k series in a 6th gen
- 96 Honda Accord crankshaft pulley removal
- Help!! burn fuse?? with HU installation
- i need an explination on this ..........
- Opinions needed
- looking for a reasonable priced full coilovers for my 95 accord
- Cold Air Intake Installation?
- Honda Accord 94 Safety concerns
- brake switch clack
- Q about timing belt change parts list and how often should i flush my tranny?
- PROBLEMS!!!!!!!!!!!!!!!!!!!
- ANYONE KNOW GOOD IMPORT SHOP IN JERSEY?
- 1991 Accord Coupe Door Panels
- Nagging Problem with my 1988 Honda Accord
- Radio Codes?
- Factory Alarm 93 Wagon EX
- 7th gen accord
- Car Creeks when taking corners
- Will 90-93 Accord Tranny fit a 5th gen?
- come on, someone has to know this!!!!!!!!!
- brakes - pads and rotors
- remove the radio
- WHats the best way to unseize rusted fittings
- Timing Belt Service for 2001 Honda Accord
- 92 accord
- Hooking up light for oem spoiler
- 20-30 hp out of a 95 accord ex
- 1998-2002 Honda Accord headlights...
- Aftermarket Headlight Bulbs?
- to flush or not to flush
- 91 Accord CEL Code
- weird problem... probably a relay
- cooling fan
- H22 Type S into 6th Gen Accord?
- help me please!!!!!!!!!!
- Cold Air VS Short Ram Air Intake - 95 accord
- will accord trans fit?
- 1999 Accord Tranny Question
- 94 wagon just quits running
- How to check, the check engine light
- Headlight Bulb Question
- Air Conditioning Problem
- heater died
- Accord 95 Electric windows
- 2001 Accord H22 Swap...What Distributor
- F22A4 what else will it fit?
- question about knock sensor and timing retard
- 94 accord ex 4cyl auto
- Code 41 new o2 sensor? New axle job?
- cruise control
- Problem: 96 EX Electric Fans come on ONLY w/the AC and at no other time: Why? Will run hot..
- Low end torque question
- How do I change the Lightbulbs in a 03
- 95 Acdord Ex mods
- Accord smoking
- FAQ: 6th Gen 1998-2002
- anyone can help?
- f22b1 tranny gear ratio
- springs or coilovers?
- starting problem
- Headlights
- AEM dry flow filter for accord
- What else would set off the brake light
- Spoon computer chip
- exhaust/intake
- Accord locked door
- non vtec to vtec
- locked car
- HID question
- where to get Gear box
- 4x100 on a 5th gen?
- car squeaks
- Any ideas for a 1991 Accord LX
- suspension
- 7th gen v6 question
