View Full Version : Honda Accord (1990 - 2002)
- 87 dx [idle problem]
- Need Help IDing Drivetrain Noise
- Nothing is blowing out of my vents when I try to heat or a/c
- Idles drops when coasting to stop.
- H&R Cup Kit??????
- Couple of questions about my recently purchased 92 accord
- Blown Shock?? Please help me diagnose HUGE PICS
- Where is the Brake Master Cylinder Bleeder on a 1994 ex?
- What locations should I use for jacking up my '02 Accord?
- 92 Burning oil at start up
- ULEV or W/O ULEV
- 98 Accord Timing Belt work - how to remove front crank pulley
- fan speeds won't work?
- how hard is it to do a h22 swap in a 88 accord?
- Anyone else having water leaks coming through their front windshields?
- does anyone know if 98-02 accord rear rotors are the same as 94-97's??
- I NEED HELP ON A 2005 ACCORD ASAP!!!!!!!
- transmission bolts
- Paint peeling on green Hondas...WTF??
- Help- Error Code P1607
- 95' Accord EX w/ 95' Prelude H23 Swap ...
- Engine Bogs after running through water!
- Poor gas mileage 2007 Accord EX
- need to know what order the spark plug wires go on a 90 accord
- 88 honda accord new engine..
- 5th Gen Airbags ?
- Code P1381, need some help.
- I need your help please
- HELP..... accord radio prob no code prompt
- compatibility questions about f20B
- another noob asking about idle......
- IS there a kit to put a B16 in my 2000 accord
- what to do if enigine uses oil , f22b in a my 96 accord
- 1999 ex start up problem
- Accord rear Speaker mount sizes
- Stock spring availbility....
- 93 Accord dosent move
- ANYONE KNOW HOW TO REMOVE HEADLIGHTS ON 94 ACCORD EX
- Anyone know about bodywork and paint?
- transmission G4 light?
- speakers
- does anyone know if the 7 ground wire set really make more hp for your engine?
- does anyone know if a voltage stabilizer really make your car save gas?
- EX ecu in LX
- WANT STRONGER MOTOR MOUNTs?
- dashbord
- new accord owner with a few?s about swaping parts from a 98 to my 94
- car won't start after swap
- temperature gauge
- sohc/dohc vtec solenoid?
- Engine miss
- 92-96 prelude rotors same as 5th gen?? anyone!!!!
- aftermarket header w/ stock exhaust (temporarily)
- PLEASE HELP!..Idle on 94 accord vtec
- How-To: Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1
- Trying to swap 96 h23 in my 91 accord what i need?
- This is a stupid but...
- 5 stud hub on an accord
- Speed limit governor on a 90 accord 2.2 liter
- 94 - 97 accord bumper fitment???
- code 92
- H22 Swap question!!!! ASAP!!!
- 1990 Honda Accord getting a code 43
- side markers
- changing timing belt???
- Timing belt tensioner question
- Do i need another ECU
- seatbelt chime... off?
- Cruise Control problem on a 94' Accord
- 2007 Accord LX factory alarm
- 1999 accord interior questions.
- Does anyone recommend Bosch Starters?
- 6th gen accord auto tans problems
- obdII ecu questions
- Cars not running so well
- tranny slipping can someone help?
- No camber kit needed? True or False?
- Flashing Oil Sensor Light - Help Please!
- 1991 2.2l ex 4 door rims...?
- ceramic brakes
- OEM Honda parts?? Not look alike, not fits like, but genuine HONDA parts
- just got a 94 accord lx! wanna trick it out! any ideas?
- ex header on lx and head
- blinkers and cruise controll
- 98-02 OEM Fog light kit install help
- How do you reprogram a keyless entry remote? 1997 Honda Accord Special Edition.
- WTB: OEM HONDA ACCORD 2001 FRONT BUMPER
- Quirky power door lock issue...
- what to look at for accords
- Engine Stopped while Driving, Now won't start
- 94 honda accord lx
- help !!! Radio code
- 87 accord motor swap question
- 93 rear drums
- 1995 Accord - odometer not working
- 91 Accord Fast Idle
- SiR headlights
- 96 lx exhaust
- auto to manual swap time
- 91 Accord 5pd F22A1 engine+trans into 87 LXI 5 spd ?
- "Loose" noise in rear after replacing all struts...
- What ecu to use
- Timing belt replacement. Just look...
- possible transmission problem?
- Will a MOMO hub off Civic/Integra work on CB7 accord?
- wire colors for keyless entry
- Replacing a Fender...
- speaker connection help !!!!!!!! help
- PROJECTORS/HIDs/BOTH(95 ACCORD)
- stripping and priming
- F23A1 SOHC VTEC 2.3L head... can it be used on F22 blocks???
- brake upgrade with stock rims
- Really weird problem. HELP!!
- refrigerant question
- Head Temp
- 98 Honda Accord - Fuel System error help
- H22>F22
- Engine shutting off while driving
- '97 Accord Headlight trouble
- Tranny/Motor problem
- 99 Honda Accord-Slow Accelleration-Transmission, Clutch or What?
- engine info?
- code 3 check engine (yes i check the search)
- 06 or 07 TL Side Mirrors on 02 Honda Accord
- AC Won't Take A Charge
- egr flow code with a twist..
- Best place to mount the HID ballasts in 5th gen?
- 1991 ex 4 door slight performance upgrades?
- WTB: 98 up Accord stock donuts 4x114 socal
- 1990 Honda Accord EX 2.2 Liter
- CD5 rotors pads and wheel bearings?
- Hit curb at 30mph, messed up right suspension. any idea what?
- 98 Accord Auto Tranny Trouble
- Need HELP with a part QUICK!!!!!
- 2003-2006 lowering springs
- bad grinding noise
- ? about 1990 Honda Accord Parts
- help: check engine light
- DIY, Timing belt for 6th gen accords???
- wheel spacing/offset/concentric ring
- Newer F22 swap?...6th gen -to- 4th gen
- problem with my 94 accord need some help
- Surge2....
- 90 accord cracked head, what other year/model head will fit?
- will 94 Accord bumper fit a 96 Accord?
- 99 Accord Clock
- 6th gen deck into 5th gen
- oxygen sensor for accord
- Door won't open...? Help!
- driving a 2003 accord ex
- Radiator Leak
- F22 TURBO
- CAR STOPPING PROBLEM- PLZ HELP
- Need help finding the plastic cover where oem foglights would go.
- Carbon Shield
- Check Engine Light
- accord with 195/60/15 bald tires, will 205/55/15 fit on them?????
- 98 Accord sedan brake lights out __not bulbs, not switch?? where is brake fuse?
- whats good im lookin for a whip
- Need some advise on a used Accord
- Quesiton about Oil
- Battery Drain
- auto to 5spd question
- Hey guys, got a question about swapping out for a leather interior...
- Not really a question
- some engine questions
- Mod chips on eBay.
- '88 Accord LXi: Oil Pan Plug Failure
- 94 accord starts but dies instantly after.
- rear taillight replacment???
- new 2003 accord? remote key, CD INOP?
- Car leaking oil suddenly, need some help, thanks
- will 2006/2007 17" V6 wheels fit my 99 V6 ?
- lowest offset that a 94-97 accord can run?
- help on window?
- How do you adjust the headlight beam on 2003-2006 Accord?
- 1999 Accord randomly cuts out
- apexi ws2
- CD5: transmission problem? experts help.
- Will a 95 accord front bumber fit onto a 96 body?
- Digital Instrument Cluster
- Wheel locks? Help
- headers
- Fog light fitment---2000 accord coupe
- Tune Up @ 270 000km
- Where is the plug to check for the CEL?
- 93 Accord EX-R Cam Seals Busted Contemplating H22a Swap
- Oil in my plugs on 92
- 92 automatic tranny help
- 98-00 Fog Wiring v. 01-02 Fog Wirings (6th gen)
- Wheel Flew OFF
- 98LX (4-cyl), no cluster lights, starts then dies
- Quick Question about oxygen sensor
- jack damaged the bottom of my car
- 2001 Accord Front Bumper
- help rhd cb7 steering wheel fitment
- cf3 cf4 cf5 conversion possible on a cd7???
- tightening upper front strut bar?
- Startup troubles
- 90 Accord hard to start
- my 89 accord build/restoration thread
- 4th gen prelude rear rotors the same as 5th accord rear rotors
- Really Bad Clicking Noise
- header questions
- Interest in ESP's 90-93 CB7 Honda Accord Motor Mount Kit and 94-97 CD Honda Accord Motor Mount Kit
- Oi leak
- adjustable cam gear
- Any differences between transmissions?
- How to stop trunk rattling
- 96 LX lock problem
- 06 coupe front-lip?
- emergency brake light question
- any place to get the harness-side of distributor plugs?
- K24A4 Need help.. Thank you.
- Suspension (Shocks)
- Hood/wiper problem
- Antenna Question
- 1988 Accord DX intake?
- powersteering maint.?
- ground control and koni warranty?
- leaks?
- 94-97 JDM Accord Sidemarker Help
- Del Sol seats in a accord
- Suspension/wheel setup
- How do you lock the 5th gen steering wheel?
- how hard to swap this bad boy
- aftermarket headers
- oil in distributor cap
- Radio
- Coolant Sensors Clarification
- 2000 honda accord suspension
- weird electrical discharging sound under hood!
- Is it difficult to change the balance belt and timing belt tensioner myself?
- engine swap
- Warped head on 99 accord
- Front window damaged
- 89 Honda Accord DX 2dr hatch
- CD accord sir emblem location?
- H22 head rebuild
- dizzy
- difference btwn ex and R lip ??? 94 accord
- Help - drivers side window on 1995 Accord EX
- '97 Accord brakes HELP!
- carbon fiber hood.
- Now, i def have an electrical problem...
- Accord stalls before 2K
- Removing Wiper Arm.
- Exhaust for my h22a...
- Ignition Wire
- info on Harness Bar and C-piller bar for 94-97 Accord
