View Full Version : Honda Accord (1990 - 2002)
- OBD codes P1166 P1167 - O2 sensor
- 1995 Accord EX - Transmission Question
- automatic Transmission problem,
- pink wire on p13 ecu
- Gas mileage V6 tips advice?
- Compression Test: Help me verify
- engine revs
- In need of suspension torque specs for an axle change.
- 1994 honda Accord/ H22A LSD F/S
- my car doesnt start when gas is low. think this is a good idea or do you think im retarded?
- help on 92 f22a6 i think its in safe mode
- WTF! Ads are now stickied?
- 99 accord lx manual transmission breather
- A/C removal....now what
- 1999 Accord EX frequently stalls
- Brake light on my dash
- Will this 96-97 FRONT CROSS MEMBER BAR fit 94 EX???
- When filling up, pump clicks as if full...
- 2001 Accord V6, Slight sudden shift from first to second gear
- what happend to my oil!?!?!
- Brake Master Cylinder Replacement
- Benefits of body kits and lowering.
- Brake bleeder screw cap
- throttle position sensor help
- Engine Replacement...Crank no start
- Car Surges At Idle during cold temps.... help please
- 90 accord rough idle in gear and rough take off
- Bad slave cylinder?
- New parts, same problem v. fuel pump/relay/etc.
- 94 Accord suspension upgrade
- Advice please !
- Anyone run NGK G-powers?
- problems w/ h22 swap....axle related
- Replacing auto tranny.. what years will work?
- IAVC,FITV,TB HOSES HELP!!!
- Favorite front lip for a 94 accord
- F22a block and f22b2 head
- SRS unit
- 2000 accord fan will not turn on
- 96 accord overheats only on incline
- 01 accord TCS lock-up
- vtec help
- No air coming out of '96 Accord defrost vents...
- Body Parts
- p0108 map sensor high voltage
- Automatic Transmission Gear Position Switch Problem???
- Runnel channel replacement
- What is this thing on the transmission???
- 90 honda accord jerks very bad when put in reverse or when gear changes
- Setting Timing on 95 LX
- Completely Stripped Head Bolt
- 2 problems (oil pump and trans.) with engine swap. PLEASE HELP!!!
- Parking brake light comes on on Hard turns? Just need a adjustment?
- squeaking shocks
- 92 accord VS 95 accord
- intermitent no start, ecu?
- 95 LX single cam non vtec oil pan gasket
- 1994 EX randomly will not start
- Non vtec to vtec head swap-yes the FAQ was read and was searched.
- 1990 Accord Drunk Disable
- Engine Check Code Need help understanding it HELP PLEASE!
- Transmission/drive axle? oil leak
- 1990 honda accord ex wont start
- 96 EX overheating...turn on the heater, it gets worse and overheats more!!! wtf?
- How do I replace a 92 Accord Washer Resercoir?
- h22 m2b4 lsd tranny 5th gear
- Caliper slider pins?
- Please Help. 2002 Accord CD/Tape Deck Not Powering On
- trying to convert f22a6 motor to run with f22b2 distributor
- adjustable/ rising rate fuel pressure regulators
- Timing Belt Maintenance - Other items to do
- phantom grip?
- Ebay clutch advice...good/bad?
- new h22 swap and engine keeps shutting off
- jdm coil over springs
- 97 accord cylinder head on ls for ms/vtec conversion?
- strut bar interchangeability
- CEL Question
- '96 Accord auto locks unlocking on their own...
- F22A cam gear the same as F22b1?
- AN sizes and Vacuum system help
- 2002 auto hard shift
- accord issue.
- 96 accord performance questions.
- 95 accord ex
- 1993 Fuel Filter Replacement
- obd2 to obd1
- timeing belt
- I have an off topic question...sorry!
- 94 honda accord acting a little goofy and i need help
- how can you tell if head gasket still ok?
- springs switched?
- h22a swap knock and IAB sensor with a chipped p28?
- 1991 rear defroster switch
- Tuning to delete a code
- 94 ex wierd passenger turn signal problem
- high rpm noise
- axle or wheel bearings
- right rear door stuck
- spark plug wires 98 coupe
- 96 Accord electircal problems......AGAIN 96 accord
- What size tire does the 2002 Accord Ex?
- Question re: transmission fluid leak
- Differences between door lock actuators 2 dr vs 4dr
- What year is the BEST for the Accord?
- How do I fix this ignition issue
- advancing timing on OBD2 accords
- How to set clock in a Honda Accord
- speedo problem
- 94 honda accord won't start right
- What is this hole?
- what year is my engine?
- Awesome deal on rods I hope??? please comment
- Thought you guys might find this video cool..
- 99 Honda Accord NIGHTMARE!
- 92 EX: Integrated Control Unit (ICU) and several symptoms that are not 100% consistent
- honda accord question.
- 1996 Accord v6 - EX water pump
- Catback quality
- Is this normal???
- Single Cam valve adjustment
- 02 Accord SE 4 cycl. Automatic Transmission replacement
- 99accord doesnt start occasionally, thoughts?
- Phantom Tick - '94 Accord EX
- vtec controller
- OBDII ECU on engine older than 1996?
- whats different from OBD1 and OBD2 f22b engines???
- Oil pump replacement questions
- 94 Accord 4cyl. Intermittent no crank no start.
- crank question
- glass headlights for a 1994 ex???
- wifes 98 accord hub
- Turning Signals dont work...
- 1997 Honda Accord ~ White Smoke Seeping from Hood and Passenger Wheel Well
- Maint. Rqrd. Light
- 3 accords
- Clutch Master cylinder rebuild kit? 93 Accord
- website for accords
- Dash Lights Out...Help!!
- Koni Yellow Rear Adjustment
- 2000 Accord EX engine shaking!
- Speedometer does work, removed cluster, need to know where to solder
- 95' honda accord ex w/vtec harsh shifts on automatic
- 1996 Accord LX... rear oxygen sensor.. which is better??
- s light keep flashing, help please
- 1994 Accord EX engine question...
- Yellow light just came on
- 95 Accord Shudder Under Acceleration
- Car feels slow like brakes are draggin or a/c is on.
- Clutch Ignition Wiring Question
- Shielding heat from oil pan and gasket question...
- Blue Smoke on Startup
- over heating problem
- JDM replacement engine problems! please help!
- hoses missing from intake manifold?
- what part is this?!
- 91' Accord All don't work> Dome light, Intermediate wipers, Rear defroster, Running lights< An
- Install new driver side mirror unit
- 90-93 Integra Seats in a CB7 Accord?
- 1990 accord not turning over barely clicking
- Car Revs to 5k and Falls on its Face?
- 4x100 on 1997 Accord?
- sport mode light on
- Dashboard lights flash for several seconds when ignitionion key turned on; HELP.
- Rattling sound when rapidly accelerating
- Headlight locking ring?
- rough idle?
- Verfiy the Bulliten for two check engine lights
- help with a wierd noise wen accord turns on?
- break lights stuck on
- bad oil psi gauge? oil leak?
- Built h22
- 6th gen catback question
- new suspension, need advice
- Power door locks dont work on 1990 Honda Accord EX
- My timing belt story
- '97 LX, looking for some upgrade ideas.
- AEM fuel rail question?
- Front Suspension Uneven...
- 2000 f23vtec head bolt tourque specs?????
- my 93 accord wont start!!
- 94 ex brake rear brake pins stuck
- accord rear disk brakes
- 95 Accord V6 start up hum sound?
- looking for exhaust
- 1998 Honda Accord front driver side outer door handle replacement.
- Unable to Lock back left door of a Honda Accord 2002
- Drive Axle Nut torque?
- 1990 accord help
- 95 accord exhaust question?
- 98 Accord LX power window issue
- car not starting right and then after running just shuts off
- px0-3 tranny code whats it mean?
- Does anyone know where to get a Honda Accord 2001 Dx Bronze Rim?
- clutch and clutch adjustment
- 1992 Accord Visor Vanity Light Bulb
- H23 Countershaft Nut Torque Spec
- brake upgrade and rotor over hub conversion possible on 94-97 accord?
- 01 accord new motor not running right?
- which arp head studs to get
- what weight (oil) is everyone using?
- The best bolt ons??
- H22A may on honda accord 1995 coupe if not Help pliz !
- occasional grind when in 2nd
- 98 odyssey tranny question???
- Horsepower on a 95 accord ex vtec?
- HELP!! Im buying a exhuast system for my 94 ex
- Turbo Kits for 90-93?
- 98 6cyl magnaflow cat-back --> 00 4cyl ??
- electric load detector problem
- 2001 Accord V6 Code P1298, P0135 & P0141
- How remove the front suspension lower control arm ball joint
- hesitation and low idle
- Swap h23 for an h22
- Replaced motor now I have problems
- skunk 2 springs
- Possible Transmission Dying 02 Honda Accord SE
- 91 accord tranny ecm problem (i think)
- Need HELP!!!! on tranny fluid change
- 96 Accord 5 speed only shifts into two gears wtf help!
- 1995 2.2 Head Gasket
- Stalls when accelerator is depressed
- 1993 Accord won't start correctly.
- VTEC PROBLEM!!
- 98 ACCORD TRANSMISSION
- Problem in Throttle body area
- 94 accord help??
- HELP PLEZ !!!!!!!!
- Brake pads wear more on the inside than on the outside of rotor?
- Transmission installation help(AUTO) I can't get it flush
- window regulator replacement question
- Bisimoto level 2 camshaft?
- Main Fuel Pump Relay
- 96 accord looking for lowering springs or coil overs
- starting problems 93 accord
- where can I find a picture of my passenger side mount 98LX?
- Sedan v. Wagon
- Selling OEM steering wheel and suspensions
- Accords vs Preludes
- Stock ride height
- car died while driving, cranks but wont start
- Transmission Problem!
- stuttering and backfire from within intake
- SUSPENSIONMAX! Need help and advice for camber problem!
- steering wheel spline??????
- F22A build vs H22A swap information - My own research
- Interior door handle 90-93 2dr? Nobody makes them?
- 98 cranks but wont start
- H22A1 Vtec into 1991 Accord non-Vtec
- Slave Cylinder, replacement suggestions.
