View Full Version : Honda Accord (1990 - 2002)
- afc vtec 2 controller?
- Washer stuck inside spark plug
- f20b
- Replacing exhaust system on '95 Accord LX
- 91 accord,crank, no start, no fuel...
- 1988 Accord (Carb) No Spark
- h22 in a 94-97 coupe accord
- Offset and width of stock '98 Accord 15" wheels??
- tubo, for 1998 ex?
- Wheel fitment issues
- Starting problem, Won't start easy since engine swap!!!
- Question
- Air Intake
- 94 accord idle issue
- Catalytic Efficiency CEL
- 95 LX-LIGHTS OUT
- Tail lights out, Odometer lights off-WHAT FUSES?!
- help!!!! on real jdm accord coupe badge for 1994 accord
- dropping
- transmission fluid help!!!!!!!!
- CEL code 70 Automatic Transmission malfunction with the automatic transmission controls
- Auto transmission problem
- Cold Air VS Short Ram Intake
- Coolant leak... heater core???
- HPF Accord
- H&R Sport Springs
- COPS SUCK!!!!
- How do i install a cold air intake on a 1990 Honda accord?
- 5th Gen V6 accord w/ 5spd
- Light bulbs..?
- 1993 Accord EX-R Performance
- light doesn't work... pelase help
- White Smoke after T-belt/Water Pump Change...not present before?
- 89 Accord SE-I
- Timing belt question
- 89 Accord DX. High Idle.
- drims help
- ps leak
- help with swap
- f22 swap
- WTB: 1990-93 Accord black interior
- rusty hondas
- power steering fluid cap missing
- head & intake manifold compatibility question
- exhaust rattle
- MAF sensor? intake options
- replace accord alternator, relieve tension?
- accord misfireing
- camber kit
- Accord 1990 locks key
- Window problem ( not the motor or anything related)
- buddy club vtec controller???
- What type of Remote starter is it?
- Quick question 2000 Prelude susp. on 91 Accord
- IGN TIMING
- Bilinking 3rd brake light
- GOT MY CAR BACK!!!!!
- Question regarding engine immobilizer
- Pic Request: Gunmetal 96-97 h22 accord coupe
- Replacing Brake Booster in '91 Accord
- CV Joint Question - 98 Honda Accord
- No trunk release... STUCK! 89 Accord damn it what do I do???!!!
- need help on how to verify if japanese plates are real deal
- Spark plug question
- Car Speakers/stereo
- 2003 accord wiring troubles
- My exaust was spitting something out..
- Sensor
- Honda Accord for sale
- Another Honda stolen
- rear brake pads wearing quickly on 2000 Accord
- stupid newb ? help plz
- different sized tires
- No power up top after tranny swap!?!
- broken cam shaft
- 1999 Accord EX....Stalling Problems
- 94 honda accord with loud squeaking sound from passenger front tire while turning?
- Anyone know the procedure for breakin in new pads and rotors (step by step)
- headers for F22B2
- swaybar links help
- Proportion Valve Leaking - 88 accord LXi - pics
- Do I Need Catalyic Converter????
- help me tune up my 2001 accord 4cyl
- Help with upper A arm
- I almost got jacked and stabbed...
- Accord 5th gen EX flex pipe, motor swap issue....
- Custom 4th gen Accord LED side markers
- overheating update! solved!
- F22 vtec engine weight
- Looking for High Idle control valve
- Accord Sunroof Block off..
- Radiator Question, tried searching, server is unavailable
- best place to buy accord parts
- Squeaky noise when turn.. need help.
- Correct way of checking ATF level
- New Clutch for 2000 Accord
- Steering wheel alignment.....HELP!
- Advice on repainting these scratches on a '97 LX?
- 97 Accord front bumper
- 94/97 accord with a idle way off
- Quick injector question.
- 5-6th gen spring similarities
- interior question; accord 01 coupe and 2000+ acura cl-s
- 94 accord cuts out between 2nd/3rd shift ???
- Where to buy a low milage F22?
- Honda Accord Brakes
- would anyone be interested in a full set of stock grey seats for a 94 4-dr?
- 94-97 Accord Fog Light Question
- 1990 accord going Nuts!
- 93 accord EX no start when below +39 degrees F
- need help trying to find some rims for my buddy's accord 98 BAY AREA
- ACCORD FOG ??
- Bleed brakes... What the deal????
- Stalling Problems! Any suggestions?
- 1990 ACCORD EX for sale
- 98 Accord LX Check Engine Light
- better engine f20b or h22
- how to gain access to rear suspension
- New Accord owner! a few starter questions
- F22 block w/ H22 head
- I need the dash off and the short fixed!!!
- 2000 Accord scraping noise when turning left
- starter bad?
- Daytime Running Lights on the '06
- Painted 6th gen headlights?
- power window problem
- places, how-to's, websites... help!
- Need some help with replacing axles
- How hard and how much to retrofit a OEM NAV?
- Spark plug seals won't come off F22B... suggestions?
- Need to find a good shop in LAorSoCal
- ECM replaced
- TIMING BELT
- help with brake conversion
- 2006 accord paint color code/name?
- need help car wont rev past 5000rmp
- 01 Accord Wheel stud help
- Very annoying noise....
- just installed new corner light bulbs and blinkers dont work, but emergency flashers do
- Lock doors when car is on
- possessed 91 EX!
- HID retrofits?
- Electrical problem - short?
- Newbie to Honda Tech \ Need Help
- tein installation help!!!!
- Sport Light Blicking
- LED's
- emergency brake handle goes up too high and wont hold the car in place
- 92 Accord wheel studs: Sheared one off...
- piaa lights
- 05 nav works but audio wont play
- 02 Accord... How to make the horn not beep with keyless entry?
- 94 Accord - transmission problems
- Do I need a kit?
- Replacing dashboard light?
- ARGGGH!!! Stoopid drum brakes
- Idle air control
- 1998 Honda Accord V6 Door Locks Problems
- Online Supplier Reccommendations
- Falken RT-615 - Yay or nay?
- Parting out 95 accord lx auto
- with a greddy turbo boost and turbo timer how much boost can a v-teched accord handle?
- check engine light
- New shifter boot for a 1997 Accord.
- Interchangeable Shift Levers? AT
- 2000 accord brake pads shim question
- stuck at 120mph
- prokit or sportline
- STEERING NOISE IN ENGINE COMPARTMENT
- need ecu
- car won't start
- 2000 Accord SRS
- Cheap Catalyic Converter
- Any one need Parts from Accord
- How to remove the cupholders on 7th gen accord?
- Largest lip available for a 94-97 accord??
- Mixing oil with the water
- 98 Sohc vtec into a 5th gen..
- J30A1 to 7th gen Accord V6 engine and tranny.
- Painting Valve Cover?
- overheatin honda!!
- anyone want to sell f22b2 parts. mostly turbo stuff?
- GET MY H22A! MOVIN!
- for those 5th gens with oem installed foglights?
- Frucking hit and run driver!
- dsm turbo manifold on accord will it fit?
- Will my1994 honda lx accord motor fit a 89 accord ?
- engine
- starting engine in cold.. precations, tip?
- Brake rotors on a 1997 Accord.
- upgrading brakes
- quick splash guard question
- 1999 accord steeringwheel hub
- Slow out of the gates....
- driving lights question 04 accord...and long crank at start?
- E.C.U
- where i can get cheap ground contol?
- '00 Accord Needs New Alternator...
- tires for 2003 accord
- 88 accord. when cold, does not idle, wants to die....
- day time running light
- 92 Engine into 91 EX
- Oxygen Sensor
- suspension question
- p13 ECU and a VTEC Solenoid question.
- I am about loose it guys, help please
- Door Indicator Stay On
- Attaching a how-to
- catback for 95 accord
- mufflers and ebay
- 94 Accord EX Leaking Oil
- problem shifting from park to drive
- Clear Corner and Bumper Lights
- ***** F/S 2000 Accord EX V6 Coupe *****
- 88 accord. replaced PCV valve, but still idles bad. wants to die....
- 99' Honda Accord 2dr, Tech Questions...
- How can I reduce the trunk rattle from my subs in my 6th gen
- How do I...
- 2000 Honda Accord SE Fuel Tank Sensor
- Blinkers Don't Work
- 94-97 short shifter Q
- prelude lx vin decoder?
- Whats the difference between LX & EX?
- Is my rotor safe?
- Spring rates and torque settings
- injectors/ECU
- 95 Accord - Cant Get Stock Corner Lights Off - Please help
- 94 Accord Coupe Door Panel removing instru.
- radio code
- V6 Accord tranny problems
- Coil Overs
- 4TH Gen. 5spd
- trying to find a part
- Engine Swaps?
- ex wheels
- 1995 honda accord antenna
- Steering Wheel Noise
- radio is dead
- F22 Boosting Question
- what is vtec excatually?
- short shifter
- GAS LEAKING (PLEASE HELP)
- Has anyone replaced a distributor bearing on an F22A1?
- High Carb Diet?
- blower motor-1993 honda accord ex
- Quick Fuse Question
- 98-99 accord v6 pcm?
- Power Door Lock Problem 98 Accord
- Rims size
