View Full Version : Honda Accord (1990 - 2002)
- Transmissions compatible with my '97 Accord
- Difference between accord tranny?
- CEL: Check EGR
- HALF SHAFT BEARING, 91057-SH3-008
- Fuel pump fuse location
- 92 accord h22a no spark
- Netherlands/Bahamas junkyard
- Accord Euro-R intake manifold on usdm accord lx
- f23 questions
- 91 Accord - sometimes totally dead
- 93 accord broken axle
- How do I cut out the cat converter?
- F20B Swap
- Popped Upper Radiator Hose 95 LX
- Fitment question on CD7 coupe with SiR parts
- 96' Accord soft brakes
- H22A OR H23A
- Motor & Tranny
- 91 cb7 stero removal help
- 98 Accord Auto--wanting to swap in h23 auto
- 2010 So Cal Meet?
- accord CD3 CD4 CD5 CD6 prelude 93-95 shafts
- 1990 Accord, No running Lights/Dash Lights - HELP?
- Removing the Crank Pulley Bolt
- missing link ML001
- 97' Accord misfiring! Need HELP!
- F22B w/ AT swap to H23A w/ MT questions
- Help!!
- 2000 DX hatchback - Help me pimp it on a budget :)
- Stalling at startup.
- 6th gen Eibach sportlines stiff enough for 3 inch drop?
- ECU Swap
- 94 Accord EX JDM Foglights?
- Oil pressure Car bogs @ 5k rpms help newbie w/ b18c1
- Any Acura techs in the house
- Power locks, windows, mirrors conversion 94 accord
- 97 ex sedan
- Accord wont go into first and 2nd gear.
- 98 accord coupe upgrades??
- DIFFERENCE between 0BD1 F22 AND OBD2 F22
- 1993 ACCORD< NO BREAKS LIGHTS<< NEED HELP NO BREAKD LIGHT
- f20b swap into 93 accord
- computer problems 91 with vtec swap
- 98 Accord Intermittently Shuts Off
- 92 Accord Issue with bogging at high Rpm's
- To Boost, Or Not To Boost?
- 1996 accord h22a4 swap getting p1457 and p0136 codes...HELP!!
- 98 V6 accord dies while driving
- Changed Timing Belt Now Have Revving Noise
- accord brake pad quetion
- 2000 Accord V6 Starts then dies, or doesn't start
- oil on sparkplugs?! NEED HELP!
- catback, muffler choices, Accord CB7
- F23 to h22a for an accord
- VIDEO: 1996 Honda Accord Airbag Removal and Install
- Wierd Noise When Turning...
- Modded lights
- NEW ALTERNATOR DIED AFTER 10MNTHS
- Is this excessive blowby ? Video included
- Rough idle after new spark plugs installed
- im tryin to see some sick 98 to 02 accord pics
- Is a manual steering rack swap possible?
- New knocks after work
- Trans sometimes doesnt engage/disengage when driving. clutch?
- Starting Problem
- Need help removing a bolt...
- ABS not flashing
- Looking for a little help on self-tuning/engine management for 94 LX.
- 00 Accord LX Won't start
- Rear engine mount changed and now weird vibration
- Exceeding load capacity on Accord
- 92 accord
- Please Help! severe oil leak 2 mechanics no answers!
- Engine Knock trouble.
- twin loop exhaust.
- Want to buy 2001-2002 Honda Accord
- Need help with my cluster(speedometer) on my 96 accord
- HELP car won't start
- 98 Accord Bulbs/Wedges??
- Which port on motor (F23A1) for oil pressure sensor?
- ksport vs d2 coilovers
- 95 accord ex idle issue
- need brake help!
- 97 accord 4 vtech rev problems
- Airbag removal - 2002 4d Accord
- Smoke from Steering Column and Speedometer Works Intermittently
- 95 Accord valve cover gasket
- GMB Water Pump for Honda Accord 1994 EX F22B1
- Electrical Issue
- Increased THUMPING (Driver Side)
- 90 accord ex 2.2 Auto ? about power drainage?
- timing belt walking off
- Installng New MC and Calipers - Flush or Drain?
- Window + lock problem
- 93 LX won't crank. Main relay & starter?
- Two issues: Temp guage and door locks
- Gearshift position indicator question
- head bolt torque specs 1995 Accord LX 4 cyl.
- Installing Cam & Crank Seals, Hard?
- 93 Accord EX stock header or aftermarket?
- 99 b7xa transmission rebuild questions
- Question about if my engine is the original or not?
- lowering my accord. NEED HELP
- Need help from you F series guys
- CD5 Cluster Diagram anyone?
- idle surge after throttle body replacement?
- Is my mechanic trying to pull a fast one on me?
- 98-02 Accord Headlight Output/Cut Off
- Swap or not? F22B2 94 Accord
- Swapping 2003 Accord Tranny for 04/05. Possible?
- DIY for replacing lights for climate control/clock/etc
- What kind of suspension to buy
- 2000 accord - door won't open!
- VSS Replacement
- Brake Pad Shims?
- 91 / 99 accord
- disabling panic mode question
- 93 accord lx low temp thermostat
- ???lip kits???
- Rear disc brakes
- 1990 ACCORD FUEL FILTER - GAS LINE
- problem entering code on radio
- replace cylinder head bolts ?
- rpm wire?
- EG project... for a noob
- Transmission failing '00 Accord LX...suggestions??
- exhaust silencer?
- starting and accelerating problem
- Still surging, but odd
- Heater hose
- 1990 Accord Power door locks
- Green Immobilizer Key Keeps Blinking....
- h23-22 swap 95 accord lx
- 91 Accord S-light on but No codes
- Fastest 1/4 mile Street Accord
- Synthetic Tranny Oil
- JDM Integra front end on '94 Accord EX???
- anyone know how to fix short to power in drivers side airbag???
- f22/f23 turbo IC piping question
- 96 accord ex not revving past 4500 on Drive
- 90 Accord Coupe EX 2.2 Automatic ? about transmission Computer
- F23 tuned to OBD1 running rough @ low RPM's, what to look for?
- VERY high idle when clutch in, surges when clutch is out
- cylinder head ?
- 1992 Honda Accord LX (manual transmission)
- four lug acura tl type s rims
- 92 Accord LX (4cyl 5sp) issues. Engine and Brakes
- Injectors
- will this work?
- 1992 Accord Air Conditioning
- 2001 honda accord ex 02 sensor
- H22 and F22 thermostat interchangeable?
- help help help!!!!!
- mil code 9 trouble
- help please? 90 honda accord problem.
- 96 accord mpg...
- How do you remove the brake line cover under a 1998 accord?
- CALLING ALL H22 CB7'S!!!
- how easy is this?
- Window Regulator
- what size is the washer from 5th Gen fuel filter
- Brake light failure sensor...
- 2000 accord v6 p1399 and 6 other codes
- CD5-7 with 18/19 inch rims
- Need Help
- A non typical idle problem
- 90-93 Accord 2/4 door Windshield interchange CB7
- H22 Swap Ecu Help!!!
- 92 accord lx overheating issue
- Leaking fluid??
- wanna boost my f22!!!!
- 97 Accord humming/whirling noise
- 93 Honda Accord Flickering Oil light?!
- CLUSTER GAUGE QUESTION PLEASE HELP
- How check timing belt setup
- Wipers and Headlight problems
- 2002 F23A1 misfire/head swap
- 97 Lx shuts off while driving
- Please someone have the answer
- F20b in 96 accord lx
- Help with replacing battery components
- k20A Type R Engine swap for my 94 Accord
- 98 accord Guage cluster does not like up?
- 1996 accord starting problem
- 99 ACCORD AUTO TRANS
- Resistor box?????
- exhuast question
- 93 accord p\s squel while turning
- Does anyone know what year accord this fog light bracket is from?
- accord fuel pump
- H22 swap question
- oil pan trouble
- Anyone live in Portland, TN and good with Honda transmissions?
- 00 accord maxa replacing with mcja?
- Engine Idle Problems
- 90 accord /92 integra crossover advice needed
- V6 ACCORD POWER STEERING NOISE
- accord guys.
- Mileage meter stopped working
- Jdm H22a Auto Swap (Ecu & Tcu Help)
- HELP!
- Aftermarket Throttle-body to support Cruise Control?
- shift linkage?
- 90 harmonic balancer/crank pully bolt size?
- coilover sleeve hieght uneven
- Totalled my Car last Night! few question.
- 2000 Accord spark plugs, plug wires, ignition parts
- 1998 Accord V6, New Exhaust.
- Swap completed - Now tail Lamp warning light
- New to Honda-tech
- 1997 Accord won't start
- Help with some info
- Vtec head on f22b2
- honda accord 98
- Are all Stock Honda Map Sensors the same?
- AC not blowing at all
- F23A1 into a 90-93 accord?
- Help - Identify this melted part... :/
- 1998 accord sedan 1/4 times
- need help
- Original rebuild vs Used distributor - different in performance
- need help asap with G
- Goin in on an F22..
- 1996 CD7 Accord
- What do you Accord owners think?
- 5 speed shift cable for 90 accord need help please????
- 92 accord overheating
- Valve question
- 94 accord cruise control?
- Rear window question?
- Type-v Sony head unit stalk link help needed
- Increasing HP
- how much
- F22b1 head swap
- Embarrassed to ask but struggling to replace my clock
- Stuck Throttle Cable?
- What could this be in the engine bay? (Pic included)
- Temperature Gauge on Red - 1993 Accord
- Temperature Gauge on Red - 2003 Accord
- SRS light on
- 92 accord swap??
- 90 Accord Coupe EX 2.2 Auto? about bumper & Grill?
- dash lighting wtf
- Will 91 EX Injectors fit 94 LX?
- Question about interchangeable parts between 94 accord and 96,97 accord
- Restarting a sitting car
- 90 Accord stalls
- Lowering a 92 accord help!!!
- Swap done, car starts - CEL on, Help please
- Accord does not start
