1990 acccord ex wheel bearing replacement?/ stuck on heat
is there a DIY guide anywhere? anyone know any info on this? also, something broke inside and now its always stuck on heat... is it hard to rip apart the dash?
umm...
1) take knuckle/hub assembly to machine shop
2) machine shop presses out old bearing and presses in new bearing
3) you pay the machine shop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC »</TD></TR><TR><TD CLASS="quote">umm...
3) you pay the machine shop</TD></TR></TABLE>
yup only way to do it!!!
you can do it yourself if you can find long 10x1.25mm bolts.
remove wheel
remove axle nut
loosen the 4 bolts that go thru the hub
remove brake caliper
pop the knuckle off the tie rod, lower and upper ball joints
take the knuckle off the car
undo 4 bolts holding hte bearing to the knuckle
tap the bearing+rotor+hub out by tapping the 4 bolts w/ a hammer
now put the long 10x1.25mm bolts in thru the back of the bearing and turn the rotor til the bolts press on the rotor. It will press the rotor+hub off the bearing. Turn each one little by little, going criss cross til you push the hub off the bearing.
However, be sure you have broken the 4 bolts that go thru the rotor to the hub loosen before you removed everything off the car. They are really hard to remove after taking everything off.
to get the hub on a new bearing... you can ghetto it and pound it down w/ a hammer, or u can take it to a shop to have them press it.
remove wheel
remove axle nut
phrenzykEG6
May 5, 2010 04:20 PM
