PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 [229] 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. What did I do ?????
  2. Accord HFP/good deal?
  3. New Suspension
  4. does 6th gen accord stock cd player play burned CDs?
  5. what will work from an f22 to an h22a?
  6. Rattling in engine bay at idle 04 LX
  7. 1995 Accord EX 4dr - transmission light question
  8. quick question about 97 headlights
  9. Taking the ECU out
  10. Quaife Vs OBX
  11. cold air intake?
  12. vtech
  13. Argh wtf is wrong with my car? 1991 Accord LX
  14. new car, fresh start
  15. 2010 Honda Accord
  16. 91 and 93 Ignition............!!!
  17. My "check engine" code is seventeen. (17)
  18. alternator
  19. 99 accord v6 transmission question
  20. my 99 accord remote?
  21. Fuse Accord 95
  22. IACV cleaning
  23. 94 Accord LX Problems?
  24. MAIN RELAY ----- HOW TO FIX IT..
  25. O2 Sensors ~ Noob ???
  26. 6th gen OBD1 swap
  27. 97 CD5 Cd Player Problems
  28. 91 Accord. Fix trans? little more umph...
  29. Cylinder Shims?
  30. Completey new to Honda
  31. hit a deer.
  32. 95 srs light
  33. aem power pulley kit?
  34. No spark issues.... related to timing break???
  35. Sport mode light blinking..
  36. Should I really be feeling vtec this much?
  37. eBay intake...
  38. ABS light on
  39. Where can I find general info on turbo's? Sizes, trim etc...
  40. switchblade keys
  41. I need an Accord Blinker
  42. 91 Accord manual transmission repair
  43. i want a 6 speed take off in a automatic
  44. surfboard fits?
  45. Need rims with rubber - 93 accord - will spend $500
  46. Cant find Radio Fuse on 1998 Accord LX
  47. Do I really need a whole new transmission? (kinda long)
  48. Can someone plz help me post my pics up!
  49. Dont know if this belonges here but Snap-On Ratchet for Sale Life Time Warr.
  50. cam identification help
  51. Right way to replace valve cover gasket/spark plug tube seals?
  52. Switch to Manual Tranny?
  53. Replace these seals during a timing belt change (?)
  54. Stock shock ?
  55. PLZ HELP! Accord stuck in PARK! Need to fix by tonight
  56. Gas tank deformity
  57. Clutch Pedal Feel
  58. Need Wiring information 86 Accord Power Sunroof
  59. 1990 accord ex 43 code
  60. Prelude steering rack in Accord?
  61. f22b long block or f22a vtec
  62. looking for good t3/t4 turbo oil feed an return
  63. Sport light on all the time on my 1991 Honda Accord
  64. 98-02 Honda Accord Type R Mugen Lip Kit
  65. DOHC with Neuspeed 4pt Bar? 4th Gen LOOK
  66. 94 accord EX black window trim
  67. Car Sponsors? Is it worth it?
  68. Automatic Seatbelt question...
  69. JDM F22B=USDM H23A1
  70. factory lip spoiler on 06 accord?
  71. where's the fuel filter located in 2001 accord?
  72. h23 intake manifold on f22a6
  73. trading 04 for 6th gen accord? comments?
  74. Short shift kit
  75. Engine Misfire
  76. smoking 1990 when first cranked up
  77. oh my fing brakes
  78. Help with Power Steering!!!!!!
  79. Cheap Cold Air Intake.
  80. Automatic Shifter Light Bulb Replacement Directions? Any 6th gen help?
  81. Anyone tried 235/45 on stock 17x7 wheels?
  82. Denso or NGK?
  83. prevention question
  84. Clutch Master Cylinder upgrade?!?!
  85. do i have to replace my egr valve...or can it disasemble and be cleaned
  86. 2005 accord fender bender
  87. PSPEC Short Throw Shifter Kit for 6th Gen Accord, what do yall think?
  88. Heater/Cooling system problem and questions..
  89. is it possible to have air in the gas TANK?
  90. race questions???
  91. good idea cleaning with alcohol?
  92. vafc 2 vtec controller ??
  93. Car Accident
  94. Simple question. clock won't light up on a 2000 EX
  95. resetting ecu?
  96. wheel/tire/susp upgrades?
  97. 1991 Honda Accord LX Transmission Problem
  98. Swaping TL Seats?
  99. I am redeemed!!
  100. Accord H22/H23 problem
  101. temperature sensor
  102. Damn windows wont roll back up!!
  103. honda accord 1993 EX
  104. Custom exhaust vs. cat back???
  105. OEM rotors?
  106. accelleration
  107. Accord Turbo Q
  108. 01-02 Honda Accord OEM Bumper
  109. Where Is Radio Fuse Location on 94?
  110. No power to headunit
  111. short-ram squeeky??
  112. Magnaflow exhaust sounds all cars
  113. H22a HEAD SWAP
  114. REAR DISC BRAKE SWAP
  115. Replacement low beam bulb for 2001 Accord V6?
  116. No Tach?! Common Issues with Accord Tachs would be appreciated! Thanks!
  117. Horn location
  118. hot air
  119. F22B1 bottom end/H22 Head
  120. Dash clock
  121. Hear your transmission?
  122. Plug wires
  123. accord lug pattern?
  124. oil filter housing?
  125. '05 Accord Replacement Front Bumper - Aftermarket or OEM?
  126. Loss of gas mileage w/ CAI and other performance questions
  127. repair rear bumber-urethane?? 96 accord ex
  128. 2006 6speed in j30a1?
  129. question on motor swap from a 92 accord to an 89
  130. 4th gen stock front swaybar size?
  131. cambersa
  132. please help quick wiring help any body that know how to web sits
  133. why my 1990 exr drinks gas????
  134. 92 Honda Accord LX Starting/Running Problems
  135. Recall P21
  136. Kill Switches, What is the best place to tap into the harness so it is not so obvious??
  137. im stuck plzzz help
  138. Ridaio Noise Condensor Which One ?
  139. CAI problem
  140. 03 accord 4cyl engine code
  141. I have a major oil leak!!!!!!!!!!!!
  142. Yet another 91 Accord no-start thread. I've searched and tried all the archived stuff, here's my sym
  143. Problems with Drivers Seat
  144. Need HELP PLS! SEARCHED!! didnt find anything THANKS
  145. ABS system problem
  146. Outer boot broke How long can I wait to fix?
  147. can a h22 intake manifold fit on a f22 non- vtec motor
  148. h22 cam install
  149. Is the flywheel/clutch the same ....
  150. i need help fast
  151. Honda bumper cover
  152. Want A New Accord? Cheap?
  153. 96 Accord Double Din?
  154. camber kit for 98 02 accord?
  155. Question about factory XM tuner/antenna and aftermarket radio
  156. D4 light on 94 accord, tranny problems.... HELP
  157. 91 Accord Wagon ???
  158. h22 parts on a f22b1 engine
  159. Clutch Leak ('94 Accord)
  160. 95 accord
  161. 1991 Honda Accord - "S" Light Problem
  162. oil pump or pressure switch
  163. taking the head off of my 89 accord.
  164. cel code 15 (change distruibitor but still have same problem)
  165. Civic Si rims on Accord?
  166. Honda Hoods
  167. '91 Accord Front Speaker Grilles
  168. am i losing my mind?!?!
  169. Euro R Swap Help
  170. where do you add transmission oil
  171. I need AT tranny gear ratios...please.
  172. what motor is in an 88 lx?
  173. Whats the name of the part that the Lower control arms bolt too?
  174. problems with my 02 accord coupe headlights
  175. front bumper signal lights
  176. 98 honda accord 5 speed transmission lx
  177. 92 Accord EX
  178. rust on brand new disc brakes
  179. Fender Fit?
  180. Car still idles up and down. i even cleand the IAC valve and no Vac leak
  181. Transmission question
  182. 93 Accord exr - Auto transmission slipping - Lucas transmission fix?!?!
  183. 92 Accord LX D4 issue!
  184. 2000 accord steering problems
  185. got springs need shocks
  186. best place to get parts...ebay?
  187. problems starting my car....AGAIN!
  188. Automatic transmission fluid change @ 100k?
  189. My exhaust WAV. for those i said i was going to post.
  190. 90 accord dx problems with glove box
  191. Codes 41 and 12
  192. Pulling key out with the car running.
  193. Suspension suggestion.
  194. Power steering rack
  195. Short Shift kit
  196. SHOULD i change my tranny
  197. cant stop!!!
  198. 5th Gen H22 Swap Questions ...
  199. How to guides?
  200. steering wheel lock
  201. What size Optima battery?
  202. clutch oil
  203. 4th Gen Accords - What are you using for extra gauge holders?
  204. 1/4 Mile Times and Set-Up Used
  205. broken left front engine mount- how important to get it fixed...
  206. rear knuckle bolt
  207. No pulley kits for 7th gen accords?
  208. 2.4 03 Accord Intake Recommendation
  209. 90-97 Accord/97 Acura CL Brake question
  210. I wake up to this saturday morning.... need help.
  211. how much for a h22 motor swap into cd6? (labor only)
  212. What would a 2006 Mugen Accord look like?
  213. need help repining 93 accord cluster for 91 accord
  214. Header and cam Question??????
  215. need g22 parts!!
  216. Bushings....
  217. 1990 Accord Starting Problem
  218. Qiuick question about brake job. Plz help
  219. TCS and Check Engine Light 2001 V6
  220. Heat shield
  221. f/s accord ex tranny
  222. Pulley/Suspension question
  223. Wheel Offset...
  224. H22A in CB7 (90-93 accord) who all here has one in their accord?
  225. help with upgrade - legend calipers and 5-lug
  226. Need help ASAP!! 95 Accord Ex clutch bypassing
  227. belt tension?
  228. Will this fit my 93 lx?
  229. About to purchase this dizzy cap and rotor
  230. Switch to synthetic Oil at 86,000 miles??
  231. D4 light
  232. '92 Accord Check Engine Light
  233. wtb 94-95 rear lip preferably black
  234. More torque from a honda? Does that even exist??
  235. >.< Please help!! Rattling Noise on the passenger side wheel? (94 accord)
  236. DOHC conversion
  237. Gauge arms not illuminating although dash background is ??????
  238. What can I do? Neglecting my poor Accord!
  239. Light not working in stock stero system
  240. HELP! PLEASE! NO TURN SIGNAL'S
  241. NEED HELP ASAP NO SPARK
  242. Just TUrned Car on After 2 MOnths it being off have Questions????
  243. Camshaft broke for SECOND TIME!. incredible... help again. please.
  244. wiring harness
  245. proper way to reinstall a dash i mean the whole dash..
  246. Car pulls to the left
  247. Lugnut Pricing..
  248. Recommend a tranny cooler???
  249. 95 LX AC Compressor removal/install
  250. Quick question on 94 accord
