View Full Version : Honda Accord (1990 - 2002)
- ok to switch 4-1 to 4-2-1?
- serious problems--need help
- lots of little lights wont work
- ABS/Brake Problems - Tried Searching
- ok this is original but first time for me.. im planing on doing h22 swap onmy 90 accord..
- where do i buy the parts?????
- shaking, vibrating during idle.
- Question? Timing belt cause so much damage
- stock speaker size
- Did Honda make 5 spd. Wagon '94-97?
- Coilover Question
- What method to loosen up stuck piston rings?
- IN NEED OF HELP
- Buying used Sportlines?
- 84 accord wants to stall / die hot or cold
- PLEASE HELP!! DID YOUR H22A PASS SMOG???
- Installing a switch to disable passenger airbags? ('99 LX)
- 2001 Accord grinds in 3rd
- Best clutch for a 94 Accord 2 dr
- need help with lights
- Iridium spark plug gas mileage
- Question on new purchase 96 Accord EX
- my distributor I think???
- what do i do about a map sensor? h22a into 94 lx?
- For 6th Gen: Apex WS or Tein Basic Coilovers?
- What Lugs Needed?
- 6th gen accord, f22 to h22
- 2000 Accord V6 : What struts to get with my tanabe springs?
- b18a swap
- 85 Honda Accord Hatchback fuel pump question
- OEM FOG LIGHTS
- Special question about the body stuff..
- $5 to the one who solves problem
- Accord 96 lock actuator
- 6th gen timing belt
- tien coilover vs. ground control coilover w/koni shocks?
- shift points
- Do sunroof visors work?
- I need help with a H22 swap please
- I help with a H22 swap please
- '91 Accord EX interior
- rear camber kit
- 03 Rough Idle-Characteristic of Vehicle?
- 2002 Accord side air bag light ?'s
- Anyone have experience with INTRAX Sway Bars on 1996 ACCORD ?
- fuel injection cleaner
- Antifreeze, when to change?
- :Antifreeze,when to change.
- When to change timing belts?
- What engine fits 91 accord?
- Check Eng light remains solid when jumper is in diag connector 93" accord
- Autozone Ignition coil question 93 Accord
- Bosch ignitor versus OEM 93" Accord
- Help.. No spark/nostart 93' Accord
- 02 accord CD/tape/Radio stopped working after collision repair
- Help on installation of STR KING CAM GEARS for h22a CD5
- Installation of VAFC for my H22 CD5
- What size rims and tires for 02 coupe
- 2000 accord shakes when braking
- front koni sport 90-97 brand new
- automatic transmision codes
- How easy is to remove the engine?
- Tire Size For 17's
- What type of short shifter for a 98 accord coupe
- How low is too low?
- 98-00 leather seat comparison
- idle really bad
- New cam gears
- does anyone know about F20B motor ???
- rattling at the cat
- Good tires
- Ebay Cold Air Intake
- EX-V6 Compression? YR2000
- what does cel code 17 mean?
- Good replacement (economical) rims for 4thgen?
- Gen5 Clutch Problem: Help
- light on in dashboard even when closed
- moderator, help?
- Where to find Haynes and/or Chilton manual
- what parts to use with f22b dohc?
- 88 Accord carb. motor swap (HOW TO)
- 1987 Acord runs great except
- Timing Belt
- 90Accord no parking or tail lights....HELP!
- PLEASE!! help me some info...
- rear cargo cover for wagon
- which transmission will fit my accord?
- Well specs on my ride and a question.
- How often should I change gas filter?
- How often should I change fuel in transmission?
- Why lamp "maint required" may light?
- HELP no power going to ECU!!!
- question: h23 tranny on f22b1 ??
- programming 03 accord keys
- YOUR THOUGHTS ???
- Need list of ECU codes for 1988 LXi
- 97 Accord 4 door; System Install Instructions?
- oil in throttle body...help.
- F-Series Headers?
- cylinder dimensions
- AEM V2 Intake Really Work?
- 1993 Accord EX AT tranny problem
- Homemade Turbo F22?
- Swapping A6 and A11 ecu pinouts for H22 swap.
- 97 2dr 5spd Accord --- Need Tuning and Interior Advice
- 94 Accord any body
- Battery Wires????
- 1992 Accord thermostat location + RAD question
- Whats a good set of Sway bars for 1996 Accord ?
- Replacing a timing belt in a 1990 Accord Ex
- gas gauge and bumper
- newbie here about coilover conversion kit.....
- Anybody know the OEM spring rate for the 90-93?
- Just bought an '04 accord... do I have side airbags?
- Big idle problem
- 95 Integra Seats in a 92 Accord
- Axles binding due to pressure and starting to click?
- Will a h22a header fit on a f22a engine?
- Calling out accord wagons-- looking for info before shopping for one...help?
- Clutch Problem??
- Service manual?
- Sprint gold line..Any good?
- Accord with H22a will it pass smog???
- IMF/IAT Combo sensor question - 2003 Honda Accord EX V4 2.4L Auto Sedan
- info on 96 ex accord???
- Just pulled CEL #67 from my wife's accord
- 92-96 HONDA PRELUDE JDM F22B DOHC ENGINE
- looking for rsx-s exhaust sound clip
- Thanks for the info!
- Could someone help me find some specs for this engine? F22B4
- adding vtec to a f22b2
- 1998 accord lighting problem
- H22 CL with many mods
- Some suggestions for my suspension ...
- h22 tranny vs f22 tranny
- is this to fast for bolt ons?
- Koni sports
- H22 swap
- Timing belt by dealer
- oem accord shocks
- 5 Lug?
- Rear camber kit for 97 accord
- how much can i lower a 03 accord on 18's
- Painting impact guard
- Any Help for coolant leak into oil on 4 cyl Accord engine
- 94 accord LX antenna
- throttle body
- 1988 Honda Accord body kits
- Holy cow did BG44K make a difference in the idle...
- Turbo 1988 LX
- ok ok doing the h22
- stock motor on the 1989 Honda Accord LX
- Ok, I have a question on O2 sensors.
- seats and steering wheel replacement
- car seat troubles
- HID on accord
- 91 accord auto tranny stuck
- Lost steerio code!!
- Disconnecting connectors?????
- tach point 7th gen
- Newbie has knock in 91
- SE vs. EX Products ?
- windshield wipers not working
- Accord 97
- Anyone change their accord from obd2-obd1?
- A little help for me
- Will 94 and above seats fit in a 93 accord??
- Whats the best way to flush radiator and block on 1996 Accord
- VSS Speed Sensor
- 2000 h22a4 in a 96 accord HELP!
- False alarms on 2000 Accord
- Painting Front Lip?
- Any pics of 86 accord with fogs?
- anyways.......anyhow?
- PROKIT vs S TECH anyone have experience w/ them on stock struts?
- how to check 99 accord CEL?
- b20b swap
- Stock Presure Plate PSI?
- suspension blunder...
- New purchase
- suspension question: whats a bump rubber , noise protection sheet, Rubber spring protector
- easiest way to change front bumper cover?
- best performance header for 94 honda accord LX?
- Fixing up a 96 Accord
- H22/H23 transmissions. Which one is better?
- 2003 Accord LX 4dr opinions
- cd-player detachable face interchangable?
- OT: Springs meant for a V6??
- haynes vs. chiltons
- Where is the fuel pump relay on my 87 accord dx?
- car rasied it self by itself??
- 1/4 mile times for h22 in 4th gen car
- 03 Accord Shocks/Springs
- SEATTLE GUYS: My Girlfriend lives in SEA and needs a quality mechanic. Someone who won't rip her o
- anybody ever ride on stock springs / aftermarket shocks?
- Wiper Thingy?
- Mounts needed or H22 into 91 Accord
- few questions on 91 accord
- Extremly strong headbolt?
- 91 Accord LX Spark Plug Oil Leak
- my lowering plans
- checking code on 98 accord
- cheap 4g Accord Parts in Portland, OR
- Oil in my intake manifold! help!
- Lowering Q
- Accord Newbie
- quick question about paint
- headlight bulb problem
- *** HELP *** EBC Brakes - Green Stuff Road/Sport
- when should i replace o2 sensor? have 100k on 1994 accord LX auto
- Effects of retarded ignition timing
- Diagram for an 02 accord
- Brand new to Hondas,engine swap question(simple)
- modding an 01 4 cylinder accord coupe, evo2 vs. skunk2
- Distributor wiring harness 4thgen
- intake manifold vacuum location?
- Spark Plug
- need some help here
- Wiring through firewall on 6th gen ???
- planning mild build..i'm dumb so need help
- stripped screw in the ditributor
- power steering
- 1988 ECU location?
- h22 head on f22?
- spring question
- 89' MOTOR CONVERSION
- Disconnect o2 sensor -> better performance?
- maintenance question
- Speedometer help...
- 91 accord wagon
- Charge for work on Technical Service Bulletins
- H22 ignition/starter/fuel? Don't know...
- HELP!!! please respond ASAP!
- 99 Honda Accord clutch master cylinder
- new to this forum.
- master cylinder upgrades and fitment
- Question? *someone answer pls.*
- h22a swaps
- SPC camber kit issues
- Bolt size question; help!
- check engine code 67 and 90?
- need help 98-99 accord check light...
- Leak+Sqeeking+Whats wrong?
- Low Speed shudder
- good idea?
- neuspeed race springs with tokico shocks
- Brake Pads
- 93 accord radio code
- stock tire that came with the 6th gen
- accord suspension question
