View Full Version : Honda Accord (1990 - 2002)
- I dont know how to take the rotor off Please help.........
- Need some info on a clutch asap please.
- Tan Cloth seats for a 95 accord?
- 6th gen trunk light
- FYI - 92 Prelude w/ H22a1 <$3.5k relatively clean - Los Angeles/ OC area
- Where to install Fuel Pressure Gauge on H22?
- Changing a head gasket, some questions...?
- Boosted SOHC Accord Owners
- 5th gen tune up questions
- Need help smogging my 91 Accord
- why does my accord shake?
- upper control arm
- 6th gen timing
- Good muffler or not???
- I'm getting a new suspension but have questions first
- Timing Belt and Valve Adj
- NEED HELP ON PARTS
- i want a new suspension
- anyone looking to buy a h23 turbo manifold
- 4th Gen Accord Headlight Problems.
- gen 3 euro tail lights
- Shaking Steering Wheel (Not Brake Pedal)
- noise from back right side spring
- Valve train Noise on Accord 1.8i non Vtec
- Dimming when I roll down windows.
- F22A1 to F22A6 changes
- trans. repair manual
- I'm getting a Spaco Speed but i have rail questions........
- Rear brake conversion... I did a search
- CTR steering wheel on a 5th gen?
- 1989 Accord To fix or not to fix
- jdm h22 and smog checks
- Need to know what model ECU to get
- Replacing CV boots...?
- Buying a '94 Accord - any problems???
- Anyone have the same prob?
- Re-raped Interior
- bolt pattern
- Frequent stalling month after swap complete... please help!
- ok ive had it with this distributor, im about to part this out...
- Stock 89 Accord motor?
- OT - Honda (Accord) VIN number archive?
- '03 Accord Goodies
- please help my figure this out
- what is needed for the V6/Wagon rotor swap
- what engine to swap into an 86accord?
- JIC suspension
- Adjusting the idle...do you really have to hook up an external tach???
- Tips and tricks: Cleaning the EGR ports???
- Oppenions on the "faze" air/fuel guage at autozone???
- 4th Gen Brake Problem
- 2000 Accord V6 question...
- air/fuel mixture
- engine running hot
- will 6th gen seats fit into 5th gen?
- H22 auto tensiner to manual tensioner install (picture intensive)
- Missing Link...
- Having a problem with my '99 Accord's door lock
- anybody know mod's needed for a euro R manifold onto H22A?
- accord 4ws
- Best Spark Plugs for Accord V6 VTEC
- i need some help, accord giving trouble
- Louder turn signal relay for '03 Accord?
- How to put a cool ram intake on
- Sway Bars
- Looking to buy an accord. Need some help.
- help with brake light
- exhaust temp on a turbo
- 6-29 Richmond Car Meet pictures (56k warning)
- General Consensus on Dynomax Ultra Flo.
- JDM Accord Type-R, Did it have AWD? If so....
- accord club
- is it possible to lower my car and get the same tire wear as stock?
- Road rage!
- Grinding noise comming from flywheel/distributor area ?
- accord brake line question
- Is there such thing as "throttle body cleaner"??
- starting problem
- Weird suspension noise (front)
- 93accord lowering question
- question about fuel induction service
- quick/stupid question about gauge clusters for 00 accord
- 4TH Gen muffler
- 98 accord fuel filter located?
- 93 H22A Auto into 96 Accord??
- oil problems
- Accord did something weird today, help.
- Rotor over hub swap a success on a 5th gen
- Stolen Accord, Pictures of Recovery........
- Turbo in an Auto Accord
- My fuel pump install experience 94 accord ex
- Speed Signal Wire Location
- camber question for 03 accord lowered 2 inches
- HELP Coolant problem
- New PSPEC short shift kits are finally out!
- When can i post in the classified section?
- Where did everyone buy there ...
- electrical problems
- help on removing factory front grill
- full 5th gen interior into 4th gen??possible??
- What should I do next?
- LED Scanner 2
- Anyone had trouble with 98 accord v6 auto trannys?
- Pics of finished 98 accord JDM h22a swap
- which air filter?
- Help! axle splines stuck to hub
- automatic tranny manual
- Positive side of external coil on 6th gen
- Cracked CV boots
- Acura 2.2 & 2.3 CL - whats the gearing like in those things?
- Bolt pattern for 99 Accord LX
- Prelude cluster in accord?
- skunk 2 cams
- junk yard?
- Turbo from a Volvo
- Input on size of Tranny Cooler, going along with a FMIC..
- Tach on 2000 accord...electronic problem? Need help.
- Thorttle Body Ported...?
- Led scanner
- new clutch going out after 400 miles?
- coil over question
- CD5-6 Parts
- help, I threw a code on my 6th gen. what could have happened?
- Help 89 accord dx .. what to look for ?
- change speaker
- 99 Accord Remote Wire?
- Super quick ???? Accord bolt pattern
- 91 accord transmission
- 2000 V6 Coupe CAI and Exhaust?
- need help removing 94 LX headers + Alternator...
- brembo rotor install , how do i do it???
- changing A/C compressor clutch '94 Accord
- HELP!!! ABS not working on '93 Accord EX
- Accessory sites?
- Fuel Tank
- what chip to get
- Exhaust size?
- Accords has done it again. *link*
- Windshield Wipers go on when I turn on the headlights
- Distributor....
- should I do a swap?
- Prelude 97+ vs. Accord 98+ Clutch Assemblies
- tech question for the turbo accords out there, this one should be OK with the thread nazis :)
- Denso vs. NGK
- brakes sqeaking
- Antenna stuck
- Intakes?
- Got a 2000 accord, looking for sway bars any info appreciated.
- Rims on 97 Accord??
- Stock not Vtec....
- what type of suspension
- i need some 4th gen help
- parting out a 1990 accord EX Sedan
- Anybody know where I can find...
- ecu code 80 need help?
- stock 97 accord LX auto vs. stock 99 audi 1.8T who wins?
- Recaro question for 5th gen Accords
- camber problem?
- opinons: people who own TANABE SUSTEC PRO SS
- radio code??
- 14" wheels on Accord EX?
- New rims and transmission?
- APEXi vafc question
- would a walbro 255lph pump be okay on my h22a accord?
- 99 Accord EX, Throwing Code 22, Cause and Effect Question
- Quiet Exhaust
- What does this mean F23A1 or F23A4
- Power steering pump
- 94-97 Accord visors
- Timing Belt
- I need help
- my brakes are trying to kill me
- For those interested in ARP head studs.....
- 92-96 lude seats into 95 coupe accord help?
- check engine light
- Hesitation
- Water leak! Need help!
- ngk nitrous plugs -94 lx
- Squeling from driver-side wheel/brakes?
- ? About fuel
- This girl need help... :P
- Rattling noise with acceleration, especially uphills.
- Rotor swap
- Mounting plate off to the side on a 5g?
- AEM cold air intake voiding any warranty?
- Need to know what to torque the Factory rear upper control arms to on 5th gen.
- intake fitment
- Just bought Zex kit today....
- Max Horsepower?
- H22 problem maybe msd related
- A tribute to indestructable f22b2................
- where to get lip kit for 95 accord ???
- 95 accord 4 and 6 cyl same body style?
- Any cheap way to make an 92 accord lx any faster or quicker?
- Loose Steering on 92 accord lx sedan?
- Will a 92 style EX strut bar and/or muffler bolt onto a 92 LX?
- Drivers side corner taillight for 92 Accord lx sedan?
- Unofficial AC Thread
- Calling out all Auto Accords Torque Convertor Upgrade
- Faint squeaking from tranny, disappears with light clutch press
- need an 5-22a
- Expert Help on Drag turbo please ..........
- Opinion on This Accord and Help Needed in Buying
- Tire Sizes on 93 LX (18x7.5)
- car code number?
- Can a 94 Accord EX motor fit into a 1990 Accord?
- speed limiter in '92 accordlx
- 96 Accord ECU wiring diagram needed
- Power antenna mast
- car doesn't start in the morning
- h22a rods into a f22b2???
- Removing the 2 cats on 03 accord? opinions?
- oil leak location
- A/C broken?
- Help! Power Window
- Power Door Lock Buzz
- tokico coil overs
- external coil
- Need help with 91 Accord
- Suspension ?'s.
- Help! MSD Coil for 92 Accord EX. Need help wiring it up!
- Swap or rebuild existing f22?
- Car stalls unless AC is on...
- Aftermarket Steering Wheel Tech question!
- Fuel gauge
- installing a subwoofer 98 accord
- f'ed up paint and a/c no good on 91 accord lx
- lower ball joint replacement
- help me plz
- 6gen brake lights problem
- Rotors
- struts
- strut tower brace
- f22 turbo manifold wanted
- Intercooler installation on 6th gen coupe
- H22 with F22A tranny?
- 90 Accord MPG
- troubleshooting guide
- Where to get an engine.
- Broken headlight switch...
- exhaust hangs uneven, help!!!
- h23vtec in a 90 accord
- which ngk plugs for 2000 accord ex?
- How much to install clutch master cyl, and slave cyl?
- '93 Accord EX won't start and my ad to sell the car started today!
- Custom Stock Headlights
- 98 accord v6
- Jumper plug for 98 accord
- Hot weather start poroblem
- P0B ECU Question
