94 Accord major oil leak
Old Jun 18, 2003 | 09:49 PM
peekaych's Avatar
Default 94 Accord major oil leak
Hi all,
Hope someone can help me out here. 2 weeks' ago I took the car for oil change. Last Thursday the ignition switch went out, had it tolled to the shop. Took 3 days and they replaced it.
Took the car back yesterday. On the way home from work today, the oil light blinked. After I got home, I was very shock to see the entire bottom at the driver's side was covered with oil, some even got to the doors. Check the oil stick and there was no oil left. Checked the oil pan and bolts, everything looks fine. The oil seems to be leaking from the left side of the engine (may be the crankshaft?).
Any suggestions?
Thanks - Peekay
Old Jun 18, 2003 | 10:59 PM
D114's Avatar
Default Re: 94 Accord major oil leak (peekaych)
Did you get the recall on the oil seal on the car?
sounds like it went bad.
Old Jun 18, 2003 | 11:05 PM
RUBZERK's Avatar
Default Re: 94 Accord major oil leak (D114)
How do i find out any recalls on my 4th gen?
Old Jun 18, 2003 | 11:14 PM
peekaych's Avatar
Nop! Do you know when it expires?
From the research I have done on the web, it sure sounds like a seal problem. Anyone knows how much it costs to fix at the dealer for a problem like this?
Thanks all...
Old Jun 18, 2003 | 11:56 PM
RH accord's Avatar
Default Re: 94 Accord major oil leak (RUBZERK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">How do i find out any recalls on my 4th gen?</TD></TR></TABLE>
you could call or visit the honda dealler
Old Jun 19, 2003 | 03:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peekaych &raquo;</TD></TR><TR><TD CLASS="quote">Nop! Do you know when it expires?
Thanks all...</TD></TR></TABLE>
The balancer seal product update expired i january. It should cost roughly the same as having the t-belt replaced. (Which it will need because it is soaked with oil.)
Old Jun 19, 2003 | 05:10 PM
mwkirchner's Avatar
Default Re: 94 Accord major oil leak (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
The balancer seal product update expired i january. It should cost roughly the same as having the t-belt replaced. (Which it will need because it is soaked with oil.)</TD></TR></TABLE>
This is correct. The recall has indeed expired. The problem that you mentioned in the original post is surely this. When it blows out it will indeed dump all kinds of oil out on the driver's side of the car. You will need the new seal and the retainer and both belts. No way around it.
Old Jun 20, 2003 | 04:15 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
make sure you change all belts the same time with all 3 seals...will save you monet in the long run, and you won't have to worry about that for maybe another 50,000 miles...:-)
LandHard
Oct 21, 2009 10:50 AM
cstone
Oct 2, 2009 03:22 PM
sailor_55
Nov 4, 2007 09:14 PM
soundFX
Jan 7, 2007 05:53 PM
Nizzy
Jan 13, 2003 06:51 AM
