View Full Version : Honda Accord (1990 - 2002)
- A/C question on 94 Accord LX
- can someone tell me the paint code...
- im a NEWBIE! got a question about KONI YELLOWS/NEUSPEED (yes ive searched)
- suspension clearance ..need advice
- AT downshift problem
- Will a 90 accord disturbutor internals work for a jbm 92 prelude motor
- I need help no spark h22a 90 accord
- Stock exhaust resonator effective?
- 6th gen owners with bagged suspension...please look here i need help
- Questions..what is fuel fliter, fuel rail and FPR??
- ob2 sensor placement
- Potholes bubbling tires.
- GROUND CONTROL COILOVERS WITH KYB GR-2 HELP!!!!!!!!!!
- How much would it cost to fix my front axle?
- Bent Valves...ok to drive?
- i need help about my accord starting
- Yes, I know its been asked many of times, but....
- 96 Accord CEL problem... engine running lean..can anyone help?
- 97 lx accord, mod it?
- My filter is wet everytime it rains.
- cb7 weight?
- sqeeking sound
- Where to get a H22
- Speedometer Problem
- transmission oil
- strut bars
- My H22A4 in my Accord redlines at a weak 6000 rpm. What the #*$^( is the deal?!!?!
- Which coilovers does the Apexi Spanner Wrench work on? N1 and/or WS?
- window problems
- Please help!!!!!!!!!!!!!
- I just purchased a 2001 ex with leather, f23 vtec 5 speed custom paint.
- Need help removing dash trim around gauge cluster on 97 accord
- I want this one to last
- My NOx crazy '87 Accord finally passed smog...
- Quick question about H-T
- The time has come f22a1+snail or h22
- Spoiler brake light installation
- is this too much?
- Junkyard: 3 accord rear disc!!!
- Does anybody need help with brake rotors/pads? Here is the solution.....??
- Idle Drops when fan comes on
- Noises and very bouncy suspension after install
- newbie here: request:03- 04 EX or LX sedan black with black or gun metal wheels
- Navigation system the same as the TSX?
- Accord Oil Leak
- Airbag removed, SRS light
- Noisy Door Locks
- sport overdrive
- 18 wheels rubbing engine wall fender....solution?
- Condenser recall
- Power window
- 4th Generation question
- Cost of a sending unit for a 94 Accord EX-R
- Brake rotor even-torque question 94-97
- Honda 2003 CD Display Trouble
- need help converting 4x114.3 to 4x100
- h22
- Is there a risk with short ram intakes?
- Anyone want: 11.1" brakes and rear disc off a 4th gen wagon???
- 90 accord failed brakes?
- Are different brand of synthetic motor oil different?
- confirming actual milage
- obd2 to obd1 conversion, is it worth it?
- Fuel Gauge Sending Unit on 5th gen.....
- I THINK MY TRANNY JUST WENT? OMG, HELP
- 1992 Accord Computer
- v2 intake results
- Acura CL cam into Accord
- SRS light stays on all time.
- is it necessary to removal the tie rod when swaping axle?
- Power window kit
- Q: Who makes a quality aftermarket driveaxle?
- Head rebuild
- WTB: 92-96 Prelude Shift Lever!!!!!!!
- The keys for better zex
- Anyone do a heater core swap?
- What to look for in a 3rd gen Accord
- how much whp/psi can f22 stock sleeves hold.
- CVS Valve bad? Code P1457
- Where can i get a spring compressor?
- 2004 Coupe EX vs LX
- 89 accord lxi
- 93 A.T harsh shifting problem ?????
- Its about time
- At WOT, car seems to hesitate above 4k rpm 92 Accord
- Help! A/C produces steam
- 5th gen projector retrofit write up, anyone know of any?
- what kind of camber kit should i buy
- does any one have KYB GR2 on their accord?
- Looking for 97 Accord Parts
- what intercooler to use with 91 lx,
- 93 accord axle/tranny removal
- question i have a f22b2 head with 55k
- Door lock on my Accord makes a loud annoying noise.
- TCS System in my 03 accord coupe
- throttle body rotor?
- 1988 Accord LX AC nit turning on
- GC w/ KYB AGX Bouncy as hell
- HELP! Accord Makes noise when accelerating
- short shift install?????????
- 01' ex v6 coupe....what kind of VTEC
- ** !Immobile Accord! ** Easiest way to get @ clutch MC
- HELP! Broken flex joint
- How to remove bumper stickers?!
- TPS questions, checking voltage?
- Problem Starting '90 Accord & Soft Breaks... Rookie, please help.
- transmission
- 89 intermitent starts
- TCU question
- Radiator fan not working while car is on- well it works sometimes- need advice
- What's up with the two methods of doing the axles?
- 2004 Honda Accord V6 aftermarket valvetrain ?'s...
- Changing an oil pan gasket on a 97 EX sedan?
- tranny still sliping
- help me fast...about back struts bolts honda accord 97...
- Some strut difficulty
- Basic tuneup, need some brands.
- Flashing Maintenance Required Light - 2000 accord
- Maintenace Light - Yellow
- 92' Accord - Timer Control Unit ... for cooling fans
- D4 Light Blinks and Car Will Not Start. Anyone had this problem?
- holding rotor still to removal axle nut
- F22 Bottom end and H22 Head
- H22 w/LSD Shopping list for swap needed!!!!!
- OBD code for 99 Accord EX...trying to pass emissions test.
- Question about Door/Trunk Ajar & Brake Light Indicator...
- >>>>>> yellow to red what dose it mean <<<<<<
- Help power window off track on 5th gen.
- 2003 Accord front bumper cover
- What's that pretty big gen 3 (90-93 right?) accord forum again?
- 98 Accord wheel question
- Did I get screwed?
- Q: CV Driveaxles - OEM or other brands?
- Right brake light doesn't work
- Looking for some help with my accord...
- Radio "audio" doesn't work - need advice
- Some Shots Of My Car From Today (link To App\Cosmetic)
- AC and Idle Problems
- ABS light is on
- Best oil to use
- 5th gen accord tires question..!
- 94 Exhaust system question
- Problems
- 90 Accord LX grinding...
- sport overdrive
- Noisy Door Locks
- Car won't start
- can sum1 please help me get obd1 ecu pinouts
- Diagram for a 1989 Accord Carb
- tranny issues
- Tuned AFC gains?
- Best settings on KYB AGX's
- Need step by step instructions to convert 91 Accords A/C to R-132a
- Help me, I want to Adjust my Valves :) Accord 97 2.2
- cooling fan
- 96 Accord Ex - Front door and component speakers
- idle problem
- obd question on motor swap.
- 90 Accord H22 fuel problems
- NOISE UNDER HOOD
- just got new Alpine head unit, wants to dim and blink at high volumes
- what's the best aftermarket atx filter/cooler?
- turbo for 7th gen I4
- Hey, Dad just bought an 04 Accord!
- 95 accord muffler
- Power Loss, Need Help Please
- Harness bar and body kit for 03 coupe
- MOMO Evo seat installation help
- Why Honda's are so bad on Transmissions?
- Any cheap website that sells OEM Accord parts
- fog lights?
- 91 accord blower motor replacement
- Need help with installing headlight bulbs on accord 96 .
- location of the main relay on a 4th gen accord
- do you want to see da cleanest accord around?
- Passenger side tie rod dust boot leak
- 1998 cruise control problem 2dr 4cyl
- IS CHANGING THE RADIATOR ON A 91 ACCORD HARD?
- driver side window only comes down 1/3 of the way
- Ecu reset?
- Brakes!!!!
- spining f23 crank to 8k....will it be ok?
- f22 crank w/55 mm mains?
- A/C fluid-90 accord ex
- replacing 93 accord front rotor... please HELP!
- new to me Accord...give some INPUT here
- starter relay ~ 4th gen
- 90 Accord torque specs
- i need ecu pin outs 94 obd1 poa accord
- Dummy lights came on all of a sudden!! Help needed.
- auto h22a problems?
- Solutions to rubbing rear suspension
- Street legal light bulbs?
- best exhaust system to by ?
- stainless steel exhaust headers - help please?
- 1998 accord 5 speed transmission
- The new Accord Wagon (Tourer)
- strange noise...
- 5th Gen Accord Manual Tranny
- Installing Reverse Gauges for 96 Accord
- Prob w/ '87 Accord w/ salvaged head
- ? about lude seats into a 90 accord
- 90 accord stuck in 1st gear!!!!!!
- Strange creaking noise when braking
- h22 accord problems keep getting map sensor cel pls read
- 01 Accord making scraping/scraching sound
- Help - 5th gen radio
- need ur advice
- Anyone Done a 6thgen Clutch?
- SRS light help!!
- obd2 h22a---->accord?
- 2000 accord lx auto problem
- Tire PSI *HELP!!*
- window control arm
- Tranny Swap
- Car Stalling/Fuel Filter
- FS 92 accord
- Problem with Euro R tranny
- Does anyone know a good tracking system?
- Need curb weights of 90-93 accords, all models...
- Tire sizes
- big bolt/nut in an accord?
- what is the easiest way to replace the fuel filter
- Timing belt and seal.
- wires for lights
- Injector ticking??...need input
- Feedback Carburetor Help - Excessive NOx
- Hissing/Whistling noise while driving/but not frequent on 2001 Honda Accord
- Starting Problem
- what size piping on exhaust???
- what price should i ask for the 04 accord ex, or accord ex v6
- swapping an obdII H22 into 99 accord
- Need help with ABS light
- Avg Weight Figures
- New User ~ Where to buy parts???
- Is 35 too thin??
- anyone install the Center CROSSMEMBER? (rack n' pinon)
- 96 vtec F22b1 swap into a 90 accord NEED HELP!!!!
- someone help me...please!!
- Batter Light?
- how do u find bhp from whp or whp to bhp
- Oil in the radiator?
- koni red shocks have adjustable perch like the yellows?
- Speed sensor on 90 dx
- Problem with auto accord H22
- Auto vs Manny
- 01' accord, suspension question
- electrical problems
- HELP! Accord wont start!
- Removing a front end bumper?
