View Full Version : Honda Accord (1990 - 2002)
- a creaking sound when i turn
- Stupid Quetsion? Yes. Will amber corners for 90-91 4dr fit a 90-91 2dr?
- h22 pistons in accord
- part out 93 accord
- 99 accord gauge cluster problem
- b18, h22/h23, or f22
- 92 Accord, no spark
- New muffler... now the car hesitates when WOT!
- Accord 94 with H22A swap - SMOG Issue
- where are the rear sturt towers??
- Jumpstart=Runs Fine, then turn off and can't turn back on!!!
- accord gas tank fitment
- Head....Meet Mr. Spark Plug
- Does the Window regulator have any gears?
- Car dies while ideling...
- Noobie to Accord Forums, 93 Accord guru wanted!!!! PLEASE READ!
- Fuel Filter Help....
- junkyards near san diego
- Loud screeching when reversing
- Accord '93 Master Cylinder
- alternater ac belt question please help
- wierd noise/friction
- poa chipping???
- Looking for Grey/black leather interior
- bottem end
- accord 1990 ex
- quick ?
- coolant fans issues
- question about swaapin an h22
- How to Install Tweeters inside 05 Accord LX
- Aftermarket Steering Wheel
- #CD SQUAD INVITE
- I'm not an Accord guy: speedometer question. (works intermittently)
- Auto Trans Fluid
- 92 accord starting issue (no Spark)
- 5 lug conversion on a 6th gen
- What is this? JDM LSD Transmission?
- Honda Accord fogs
- Jdm parts
- How many gears in 6th gen auto?
- We need the help of HT. Mythbusters plane treadmill
- 94 accord wont crank at all! Please help!!!!
- tsx strut bar compatible with accord?
- accord service manual download link..??
- Underdrive Pulley Installation
- 1999 Accord LX 4 Cyl.. Knock Sensor Wire Color on ECU Side?
- 96 accord lx: determining if needs new timing belt.
- Subframe questions???
- 97 accord squeling noise
- any civic/integra parts fit accords???
- does anyone knows who makes these 19in rims ( would be going on a 5th gen accord )
- Overheating issues
- has anyone used a chery bomb muffler ??
- WHo makes Chrome rock strips for door bottoms
- Radiator cap pressure for 96 accord.
- Hesitation / Stalling
- 4th gen aftermarket bumper
- Accord Coupe 6ēgen Engine Swap.
- suspension knocking.
- car shutting off ... electric?
- Spark Plug Question about 2 step colder Plug
- Need a new Seal For my AC lines
- 95 Accord what type of mileage?
- Front end shimmy/pulsation during braking
- Map Light?
- is it easy installing am AEM SRI on a 94 honda accord ex?
- O2 Sensor Question
- Parts needed to install fog lights on 2007 EX-L
- good aftermarket parts
- 96 accord lx sluggish acceleration up to 60mph
- 94 Accord EX, What Else Could I Do Performance Wise???
- 6 gen parking brake problem
- 100 miles for 1/2 tank? 98 accord EX V6
- help with head
- 98 Accord V6 doesn't shift smoothly.
- '93 Accord Control Arm Problem
- distributor help
- f20b ecu
- Coolant temp issues. Overheating on the highway.
- Anybody have the instructions on how to install 96-97 OEM fogs?
- help h22a engine will not turn over(start) 94 accord
- my f22 build
- are these interchangable parts between accord years? i need an expert. THX
- 94-97 Accord DX/LX/EX wiring Question
- how to tweeters install for 99' accord
- Test Drive Checklist
- 1996 HONDA ACCORD EX OVERHEATING
- F23 Build Parts List Guidance
- Door stuck
- clutch master cylinder ?
- moon roof seal
- Place to download 1994-1997 Service Manual in PDF?
- what to build f22 or f23
- Timing troubles
- 91 Accord Starting issues
- will this front bumper fit a 4dr?
- Sedan Accord catbacks... who make a good QUIET one?
- 94 Accord short shifter ?s.
- 5 lug swap
- i need some suspension advice on a 4dr 6th gen
- turbo cb7
- accord swap?
- "Brake Lamp" light went on???? is that meaning a problem????
- where can i find a hole in the fireall
- White smoke and sputtering, maybe bad HG?
- 1994 accord LX has problems
- Choppy power steering
- Salt or something like salt in oil inlet
- will Ledgend engine fit in an accord?
- WHATS WRONG WITH MY ACCORD I NEED HELP PLEASE!!!!
- '95 Accord a/c charge ?
- 94 Accord LX Oil Leak!!
- Why Am I Hard Starting?
- WTB: 2000 accord front lip (seattle)
- How hard is H23 swap (engine only) into 96 Accord?
- Exhaust System
- Rattles!
- Brake Lamp problem
- Why wont my ABS light in my 97 Honda Accord Ex go out?
- '95 Accord a/c recharge issue
- Where can I find aftermarket bushings?
- projector headlights 6th gen
- 1998 Lx Accord Swap questions?
- car shakes
- H23 Swap Question(s) ...
- What parts on A ledgend fit on an accord
- h22 redline help!
- 2002 Accord Injectors?
- carbon fiber trunk
- rotors?
- transmission fluid leak
- 1st gen accord
- WTB : 00 Accord Axles
- jdm h22 tranny f/s
- injector size ?
- Getting Funny clinking after brake job on '93 Accord
- wats wrong wit it??????
- Obd2 engine > obd1 ecu
- gay ignition shit
- F22A4 head bolt thread repair
- Eletric Problem
- f23 in 96 lx???
- 99 Accord V6 shuts off while driving
- High amp Alternator
- Car Problems [Need to step on gas to start car]
- How to cure indecisive automatic transmission?
- Accord 1991 Cruise Control Module Connections
- Car in gear and rpms just shoot up, car goes no where!!! help!!!
- '06 Accord aftermarket alarm
- F20B auto vs. manual
- 1989 manual transaxle diagram
- Lights dim under stereo/window use?
- small oil leak
- Help: I can not start my car on hot days
- Air conditioner blows hot air, burning belt odor
- emergency brake
- torque converter
- Pulled Torque converter clutch code
- How to do a valve adjustment on a 97 ex 4cyl
- if i swap out my h22b for a h22a in my 96 accord
- CB7 will NOT start........
- Quick Question on 94-95 Accords
- replace just brake pads or rotors and pads
- cylinder head
- whats speed the ABS actives?
- Fix or Buy a Used Tranny?
- B-series + Cvcc + fab work = sleeper
- 01 Mod Advice Needed..
- h22 accord shift link help please
- Bad smell cming from vent when set to recirc and air cond. is off
- Idle problem with 1998 Accord
- How are you guys rotating the crank pulley for TDC?
- 94 ACCORD STEERING WHEEEL VIBRATING-PULLING HARD TO THE LEFT SLOWLY GETTING WORSE NOISY
- Changed valve cover gaskets and spark plugs = blue smoke out exhaust?
- Water pump serial number, timing belt (95 EX)
- coolant disappearing
- fluid questions
- the right cold air intake
- tune up help for 94 accord
- Radio antenna...
- Replacing fuel release cable in 2003 accord
- Exhuast on 94 h22 Accord
- 94 Accord Electrical Problem-Please help, Honda dealership cannot help me!
- SRS light on all the time, '02 accord EX V6
- More SRS problems
- 300 miles to a full tank?
- h22 swap idle problem
- What is this noise coming from under my hood?
- help find window relay
- 98 accord immobilizer problem
- Pass window won't go up after I was stupid and cut a wire I was unsure about.
- radio code 2002 honda accord
- Brake Line Disaster
- odd noise from fuel tank
- timeing belt
- 90 Accord Right Headlight Damaged
- Please Help! 90 EX squealing noise
- Accord 2006 rattling noise?? HELP???
- '95 Accord a/c
- Diehard accord enthusiast questioning the car he adored for so long
- V6 Accord Reliability
- Trasmission Slipping Need Help Please
- Cam lobes???
- good idea to go to synthetic if my car is "using" oil.
- Whats your gas mileage? for 94-97 accords only
- Transmission swap Auto to a Manual 95 accord
- Pin stripe removal tips
- 90 accord start up problem
- A Couple Questions
- 4th gen Axle/Driveshaft install??
- Replace battery
- Selling my accord, What import should i get.
- acceleration problem
- will a 90-93 balancer belt fit 97 ex 4cyl?
- prelude h22 mounts in 97 accord
- A/C Problem again
- 2006 accord V6
- Best fog lights on 94-97
- I can only get about 300 miles outta full tank!?
- Strut bars, sway bars, front, rear, upper, lower.....who has them all?
- CAr is over heating
- Gas light?
- Battery 'light' on...
- oil light problem?
- aftermarket keyless entry question
- Removing P/S ... Closed Loop ...
- 05 accord oem fog light question......
- SRS Light on in my 2002 Honda Accord, Can anyone help?
- need serious help!!!!
- Audio Security System
- Acura seats in a '95 - Maybe Legend or TL
- Squeeling noise? 04dr 4cyl Auto
- 94 accord ele (no gages no windows)
- HELP!!! My Accord is not starting.
- PGMFI help
- Forged pistons/rods
- LOOKING FOR JDM H22A TYPE R PISTON and RINGS PART NUMBER
- Cracked Fuel Pump
- 99 acc v6 timing belt ?'s
- 02 power door locks wiring diagram
- 94 Accord tires, mechanic = ripping me off
- Where can one buy a 96-97 OEM foglight kit?
- Best projector headlights for 5th gen?
- is this accord worth it?
- All 6th and 7th Gen TSBs
- Mugen rear spoiler on a CD chassis
- h22 swap help
- I have a bubble on the rear tire of my accord....
- Qusetion on raditor cooling fan?
- bleeding brake problem??
