View Full Version : Honda Accord (1990 - 2002)
- Timing Belt Question (96 Accord LX)
- Rough Shifting Transmission
- NOOB....what kind of suspension is best for my 02 accord (4 cyl. coupe)
- Install Factory Tweeters in a 96 Accord LX????
- Front Spraker Removal
- Schedule maintenance
- Trouble starting...then something unexpected...
- Dangerous vandalizm to an accord!
- Perks from having a fast Accord
- FPR Problems
- How are sportmax rims??????????? HElp
- How to attach w-type lip??
- Quiet mufflers?????
- Start problem with 86 Accord
- DAMM BRAKE BOOSTER
- Should I FLUSH or just change tranny fluid at this time?-2003 Accord EX with 50K miles, AUTO tranny
- Water leaking from rear and front AC vents (2003 Accord EX). What could be causing this?
- 92-96 Prelude Suspension fit 90-93 Accord?
- need help with under carriage
- why do i feel dumb asking this (valave question)?.........
- Custom piping soon to be done, what size?
- Need Honda Accord 98 driver side mirror
- will these springs fit
- Searched, asking about a 50-75 shot in a h22 Accord.
- apology
- Can i get better gas mileage
- Can someone help me with this minor body mod?
- intake or universal cone k&n filter??
- howdy !! im new
- 92 Honda Accord Overheating
- Tranny problem, request info.
- Nitro Box...does it work??
- Axel nutx on my 94 accord
- more tranny fluid questions
- maximum rpm going into gear
- how hard is it to take out the back seats of my honda accord
- vibration damper bolt reverse thread?
- what clutch would you buy for a honda accord
- Not leaving for USMC yet, so working on installing gauges.
- CEL 81????
- H22 in a 88 accord
- Catback...
- SPEEDBUMP > dropped accord
- a question about a swap
- Injen Intake Question :: 2004 Accord
- Help! My engine is over idleing.
- 1994 Accord Electric Fan Troubles
- my accord is running rich what should i do
- 94 accord starter problem
- help my accord will not start
- SRS light
- Exhast
- power steering
- shaved door handles
- Halo Headlights
- Eibach Coilovers
- lsd for a honda accord
- 95 Accord VS 98 CL... Same car?
- A Few Questions on Converting Back to Normal
- stup!d or will it actually work?
- Please help......only one radiator fan working
- car shake at Idle and under 1000 RPM...
- h22a type s swap to 96 lx accord tranny/axle fit probem
- Door lock sticking..
- Retrofitting HID question ...
- JDM accord cluster
- honda accord CAM
- 96 accord: car won't start
- Radio/ Clock resets
- I need an IACV For f23 to run Uberdata
- 92 honda accord lx shaking problem...
- Door Jam
- wheel locks
- 89 accord head trouble?
- Upgrades for a 2004 Accord
- Boosted Auto
- Need Advice: Symptoms of a Dying or Problematic Alternator?
- DIY On Headlight Removal? '02 Accord 2 Door
- Creaking when i turn my wheel
- s-2000 head
- powersteering bracket for 95 h22
- how many miles is a stock 4th gen clutch good for?...
- Do any of you have the SRS light on your dash all the time?
- Head Package
- HARD shifting
- 1996 accord question?
- h22 swap into 6th GENS (how much did u pay?)
- HELP with '02 Accord Headlight bulb (not bright)
- wagon rotors = coupe rotors?
- How do i become a "normal user"
- cams?
- Help me h22a4
- new owner with problems need help
- Best place to buy an 01 Accord bumper cover?
- 96 accord: power door lock on front passenger door does not work
- 94 lx to ex vtec
- What engine mods can I do on a 91 accord?
- Accord Type S.
- replacing headlight bulb
- wtb accord vtec engine
- Towing with 2003 accord 4Cyl (need experienced help)
- nitrous on automatic 6th gen
- Transmission? Please help!
- m3 mirror install questions
- compression test results... after n2o and boost.
- need perfermance help, 99 lx 4 cyl.
- '87 LX Accord won't start.
- cruise control issue
- TL-s, Eibach, Comptech, or ST, What am I looking for??
- what does a hydrolic clutch offer that a cable doesn't?
- Im Placing a H22 in my Acura cl i need some help though
- Audio Q for accord owners (tv)
- Old school Tranny Swap 87 carb to 89 PGM-FI
- Accords Thats Real Old Skool pics only
- honda rotors and pads? v6 accord 98
- 92 Accord need help! ! ! ! !
- speed sensor woes
- 98 Accord-blown alt again!
- Need anything for your 94-97 accord??
- 92 Accord Hesitation Problem 3 Dealers Unable to Diagnose
- Is my car worth saving?
- h22 In an accord?
- '98 Accord LX speedometer problem and power lock not working.
- 6th gen secondary o2 sensor and o2 simulator
- Accord 1997 intermittent air conditioning
- 03 Radio
- Error Code P-E-O
- What can I add
- Accord owners in CT please help.
- Removing door panel on 96 accord?
- wtf - 4 bolts in rotor
- '97 Accord DC header leaking?
- Bought Coilovers! How to install?
- ecu codes for 89 accord lxi
- 89 accord motor swap
- this is a very stupid question about an accord
- 94 EX AT leak. dont know where the leak
- 91 accord dx no-start
- i'm a newb, i have a question
- 04 Accord Upgrades ***I NEED YOUR SUGGESTIONS***
- Friggin' back seats won't unlock...
- Oil for 2.4 in Europe
- !! 1995 Accord EX INTAKE INSTALL !!
- need picture/scan from manual of altenator bracket 90 accord asap !
- '88 Accord check battery light
- where to find emblem
- 05 ex v6 homelink please help
- ** newbie warning ** Q: will prelude or del sol seats fit in my 96 accord?
- DVD player in an ’05 (or ’06) Accord EX?
- Sterling silver Honda necklace on ebay
- F22B1 head assembly
- transmission conversion
- 2004 Accord Window Tinting % - Suggestions Needed
- 91 LX Starting Issues, Wierd Ones
- i have an accord 2001 v6
- My 95LX redlines at 4k!! WTF?!!?
- Few Questions
- 94 Accord stalls when A/C on and not driving
- 2004 Accord Headlight changing
- Is this a good deal?
- Self Test
- Idle Speed Problem
- Can't shift out of PARK when applying the brakes... need help!
- grease fittings
- which do u prefer
- Overheating, Check Engine, Smoking From 94 Accord EX
- Burning oil, did my homework and still clueless.
- Lug Nuts for new rims, help!
- Sir Headlight Wiring
- where is the best place to get a h22
- Car is still shaking!!!!
- adjusting idle- need help ASAP
- Question: 2000 Accord Air Conditioning Filter - where is it???
- K & N air filters - do they really work???
- 94 LX Accord overheating
- help!!!
- Engine Problem
- Transmission - Please advise?
- Pricing on a full H22a swap?
- Removing front bumper help!
- Only 5th Gen Speed V6 Accord In Canada
- Changing Transmission Fluid
- need help plz
- running full Synthetic on a turbo car(searched,Nothin)
- Motor Mounts -definitive answers
- Engine swap
- Qs about timing belt and rotors/brakes
- whats the point of D3?
- 1991 Accord Check engine coming on but not all the time!
- PLZ help me
- need some help
- Has anyone heard of anyone having success with TheForce...Not StarWars
- ITR Headlamps
- Need some specs
- is it probable to have dirty ICV, but no CEL??
- Transmission Choice Ls
- I need a new shifter
- Shop inquiry
- 90 accord ex paint int
- Light problem
- converting my civic to 4X114
- need help for the FNG
- check engine lamp on
- Omnipower Coilovers - Collar Replacement... who's done it?
- Window regulator cable for accord 96
- 92 accord steering/rack&pinion issue.
- 1992 accord --difficult starts and motor mount replacements
- exhaust
- Just got my car back, sucking down oil!!! HELP!
- factory spoiler`
- 2002 Integra Steering wheel
- Is Pspec still around?
- accord h22a swap
- oil in spark plug tub
- NGK Sparks and wires; Iridiums or regular?
- A/C Questions in a 97 accord!
- vibration in front end
- TSC & Check Engine light issue
- tdc
- 97 accord running hot
- Eibach springs trouble- 02 Accord
- 98 accord camshaft upgrade4 door 4 cyl auto
- h22A ECU question MT block with AT tranny
- need siren
- Random squeaking noise, front passenger side
- remove abs in 95 accord?
- Muffler
- Can I run this size tire?a 4th gen accord
- Newbie questions ..
- 1988 IDLE PROBLEMS
- 1996 accord dashboard removal
- stupid question can't figure it out
- f22 help
- auto h22a swap
- oil preasure gauge
- 1986 Accord Help pleaseeeeeeeee
- Superglue on car paint.
- i scuffed up my back bumper
- Center Clock light
- CB7 lip question
- 96 Accord LX - Noisy Blower Motor
- Self Diagnostic
- 80 shot on mostly stock F23
- Trip odometer ??
- Muffler Inlet?
- ABS idiot light comes on...96 accord EX
- Transmission clank
- CEL Code 0452 Please read (Not the gas cap)
- 91 5-speed winding noise...
- need a flexplate
