Diffrent between 4-2-1 and 4-1
Old Jun 10, 2003 | 12:05 PM
CaMiKaZi's Avatar
Default Diffrent between 4-2-1 and 4-1
Of course am looking to get a header but what is the diffrent between 4-2-1 and 4-1 and which is better?
Old Jun 10, 2003 | 12:24 PM
Nick M's Avatar
Default Re: Diffrent between 4-2-1 and 4-1 (CaMiKaZi)
in most mainstream headers, DC sports etc a 4-2-1 is designed to give better midrange punch and a 4-1 is supposed to flow better on the top end
but you can configure either design to have either powerband characteristic
Old Jun 10, 2003 | 12:28 PM
btlfed1's Avatar
Default Re: Diffrent between 4-2-1 and 4-1 (Nick M)
depends on what you are looking for a 4-2-1 header will give you good bottom end power but not top and the 4-1 is the opposite. You still get decent bottom end on a 4-1 depending on what else you have done to your engine but has a better top end.
Old Jun 10, 2003 | 12:31 PM
Sleeping4drLS's Avatar
Default Re: Diffrent between 4-2-1 and 4-1 (btlfed1)
Like the two said earlier, 4-2-1 is good for mid-range power while a 4-1 seems to find horsepower much higher in the rev-band. It all depends on your style of driving... If you like to spend all day near redline, then you'll probably benefit from a 4 to 1... If you drive on the street and are sick of not having "enough" power in the midrange, then 4-2-1 is probably better for you.
Old Jun 10, 2003 | 12:45 PM
Nick M's Avatar
Default Re: Diffrent between 4-2-1 and 4-1 (Sleeping4drLS)
guys.....
where the best gains are delivered in a header are dependant on alot more things than just how the merges are designed! i just said that lol
its an incorrect stereotype that all 4-2-1 headers are better in the midrange than a 4-1
you can build a 4-2-1 to out perform a 4-1 on the top end and u can build a 4-1 to outperform a 4-2-1 in the midrange
you need to look at the specs, the primary lengths and size etc etc etc
Old Jun 10, 2003 | 12:52 PM
urbanlegend21's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">guys.....
exactly............... the long and short of it is that design creates power
btlfed1's Avatar
I was just basing it off them by themselves. There are a lot of factors that you have to look at but if you have the same manufacturer with the 2 different types of headers those are the results you will get
Old Jun 10, 2003 | 04:08 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btlfed1 &raquo;</TD></TR><TR><TD CLASS="quote">depends on what you are looking for a 4-2-1 header will give you good bottom end power but not top and the 4-1 is the opposite. You still get decent bottom end on a 4-1 depending on what else you have done to your engine but has a better top end.</TD></TR></TABLE>
there is no such thing as making power in the low end with any engine, nevermind a 4cyl
to make big horsepower requires lots of air, whether that is from NA high revving or forcing it in with a turbo or sc
Old Jun 10, 2003 | 04:14 PM
New User
also remember things like heat, flow, and deflection
teh faster the exhaust flows the better, the smoother the transition from 2 to 4 pipes or 4 to 1 pipes is the hotter the exhaust stays and the better it flows meaning less resistance to the enigine
if I could have an online class about this it would make much more sense
if you can smooth out the exhaust floww and make the transition as smooth as possible header design is relative to the application
Old Jun 10, 2003 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick M &raquo;</TD></TR><TR><TD CLASS="quote">to make big horsepower requires lots of air, whether that is from NA high revving or forcing it in with a turbo or sc</TD></TR></TABLE>
Lots of air of fast flowing air. If the piping is too big, the exhaust gases won't flow right and, if I'm not misunderstood, more backpressure.
Excessive backpressure=
Old Jun 10, 2003 | 05:00 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeping4drLS &raquo;</TD></TR><TR><TD CLASS="quote">
Excessive backpressure= </TD></TR></TABLE>
Old Jun 14, 2003 | 12:32 PM
arkytec's Avatar
excessive back pressure is bad for both cars and humans...
Old Jun 14, 2003 | 05:23 PM
The_In_Kid's Avatar
Default Re: Diffrent between 4-2-1 and 4-1 (arkytec)
i find my 4-2-1 ractive header yes i have a ractive header it was cheap and better then pace setter so **** on a stick :D anyways i find that the ractive 4-2-1 for 4th gen accords give a great Top end more then anything but they definately gave me sort of an all around power but mostly its noticeable in the topend
94LSmanual
Jul 22, 2006 10:15 AM
Fidelio25
Jul 27, 2004 10:15 AM
IntegraGSR321
Sep 30, 2003 06:16 PM
jt-sport
Aug 26, 2003 03:57 PM
SCsol
Apr 7, 2002 06:30 AM
