View Full Version : Honda Accord (1990 - 2002)
- 96 4 door accord stock horsepower?
- need info on timing belt plz
- Does a 2004 Honda Accord Turbo Kit exist?
- mufflers
- Gettin' Started
- transmission
- Looks or Performance
- h22 swap
- Creaking sound in my Accord H22
- 91 EX smoking from engine bay
- Honda 89 Accord Axle locknut
- Thermostat?
- Erratic RPM's
- LX header to EX header swap
- BOLT PATTERN?
- Good honda mechanic around wash. DC?
- engine not catching
- Type S rims from 3.2TL
- Short Shifter Adapter Installation
- Automatic transmission on 93 accord LX slipping
- Manual Transmission leak at axel
- Boring out f22a Throttle Body
- InJeN iNtAkE for 97 accord
- TIMING BELT: If there is a retainer plate already there....
- speedchip
- Which 95' Accord engine is faster?
- Moved to higher altitude: need help!
- Idle - Annoying car shake with A/C on.
- 18x8.5 wheel on 2004 Accord Sedan?
- Poor Gas Mileage?
- Head studs
- Accord 2000 V6- Replacing Alternator
- 5spd Automatic
- Popping and Shaving
- Good run flat tires?
- my jdm engine blown? =(
- Does 6th gen coupe hood fit a 6th gen sedan?
- Should TDC all be lined up already?
- p13 ecu with f22b1?
- Bulbs
- air intakes/cold air intake/short ram
- Nitrous experience
- '01..how do I find out WHEEL info on what size,offset,width will fit?
- messed up gauges
- Indiglow Needles
- ok.. 94 accord cv joints..
- 89 Accord seatbelt fix
- instant message
- Bar Bar Bar
- this might be off topic but im in desperate need of help
- Rack & Pinion needs replacing on New 2004 Accord?
- Power Steering Fluid Leak
- Air blowing out valve cover
- Eratic engine miss
- going fast
- trans/engine swap
- oil leak
- Timing Belt
- USDM versus EDM - Exhaust
- FS 1992 Accord OEM alloy rims with tires
- Mugen Lip Material
- Spring rates
- 96 Honda accord EX Halo Projector headlight problems?
- cross-threaded spark plug
- Emergency brake light periodically comes on
- New problem
- slow power windows
- 5-Lug Conversion
- how much should it cost to put stock springs back on
- Automatic short shifter?
- ABS Light?
- NKG or Bosch Oxygen Sensor? Any difference?
- 98 Accord timing belt, balance shaft belt alignment
- Gas Gauge Not Accurate - 1995 Accord EX 4 Door
- Automatic Door Lock Replacement - 1995 Accord EX 4 Door
- Automatic Antenna Replacement - 1995 Accord EX 4 Door
- A/C hp boost?
- Too much slack?
- accord power help!
- 88 accord keeps stalling???
- Car can feel EVERY bump in the road...
- 91 Accord rear struts
- 1992 Accord Specs.
- SHORT SHIFTER!!!
- CV Boots
- Money Decision, Need Help
- Buying tomorrow
- OKHead bolt
- Distributor Rebuild
- Battery Replacement
- possible transmission problem
- Hey, New to Honda-Tech, Looking at Accords
- srs light
- 99-2001 pcm immobilizer problems
- 90 accord question.
- strut tower bars ?
- 95 Accord Check Engine Light Code 1 WILL NOT go away!!!
- Quick ? changing rear disc brakes 93 accord ex
- Springs and Coilovers from Prelude
- a quick noob question about AC
- 82 Accord EK1 Head Bolt Torque
- 94 accord suspension problem
- best drill bit to drill bolts out?
- can't put my key into lock position
- thing on teh wiper
- EGR insufficient flow? P0401 code
- 91 Accord Help
- ride quality!!!
- iPod to 7gen accord!
- AZECT CARBON FIBER FRONT LIP GROUP BUY
- Where is the 'right brake light sensor'?
- 94 accord lx auto...won't start
- 91 accord coolant hose repair?
- Camber Kit Needed?
- The Tornado tv commericial
- 94 Accord EX idles rough only at about 2000 RPM?
- acceleration
- adjusting Konis
- alright, doing some research for my brother....looking for some opinions....
- Water temp.
- 92 accord dx!!!!
- Torque specs for head
- Shifter problems!!!
- 1991 Accord Probem really weird
- Hybrid Accord
- Thinking of buying a 96 accord wagon
- stuck throttle
- Black deposits --> Mixture rich?
- f22 swap
- 1991 Accord - 15.5 mpg?
- Finished auto to manual, now have ABS light on?
- 5th gen headlight install help
- Clutch Problem Need Help!!!
- do I have to replace it?
- Need Help - CD PLAYER - CODES???
- attention 94 accord owners, didint have much luck in the audio forum
- H22A In A 95 accord coupe having problems running too rich.
- 1991 Accord Cooling Fan Wiring Diagrams
- Rims for a 95 Accord
- Overheating Question
- Replacing Rotors and Bearings... Need Puller?
- 91 accord problemz
- TDC QUESTION:
- Jdm vs Usdm prelude
- Prelude rims on an accord?
- nos?
- gen 6 (Accord 2000 ex v6) AC stopped working all of a sudden
- H22A swap into 99 accord problems. Converting OBD2 to OBD1
- f22 turbo mani
- Simple question on a 90 Accord.
- ABS Pump Replacement
- Help swaping F22B1 in to 1994 accord LX
- Big Problems 91 accord someone help me out
- f23a1 retard timing HELP!
- what gen. accord??
- what wrong with my car
- K20 head swap
- Car will not go past 5,500rpms????/
- my 2004 sunglasses holder
- Best rear camber kit for 1995 Accord EX V6 ?
- Accord f22a - Prelude h22a v-tec transplant possible?
- Need help ASAP
- Accord/Prelude Transmission Question
- Any Installation TIPS for Suspension Tecniques Swaybars on 1996 Accord DX sedan
- My Accord, the wild rodeo bronco
- cooling fan clicks??
- Who changed their timing belt only at 105000 miles?
- H22 swap problems
- ABS Pump Replacement - 94 Accord - Price Check
- '91 Accord- power mirror problems?
- 94 h22 accord vs wrx
- Accord pics.
- Horn Doesn't work when car is on ?????
- springs question..
- 89 Accord LX Idle Fluctuating Problems
- Door Latch Retaining Screws Loose - '94 Accord EX
- 89 accord dx sputtering out
- Transmission Noises!?
- 92 Accord w/ H22 swap...got some questions!
- 96 accord h22 swap need help
- Neuspeed rotors question
- 97 cycl accord timing belt job
- 91 2.2 timing marks for balance shaft?
- '03 Dash Replacement?
- Pull Engine To Change Timing Belt???
- 94 lx exhaust mani vs 97 ex
- 12v10w BULBS
- Accord included in recent Honda recall
- Tire wear
- cams
- the best for a rebuild on a h22
- Removing ecu to prevent theft?
- Updated pics of Strut bar (unpainted)
- Factory Perofrmance Package. Worth it?
- main engine harness
- Need DIY: 02 Accord coupe uninstalling stock suspensions
- Hardwire radar detector
- Door buzzing
- any 6th genaration v6 accords using Unorthodox pulleys??...
- clock
- Changing my springs
- HELP! 97 accord muffler sound
- fuse keeps blowing............
- Read This First!
- head unit problems
- what makes auto tranny slip?
- f22 accord will turn over but won't start??? flooding maybe?
- 1997 Accord Stolen! seeking help
- Fuel Filter Help!
- smog problems on 90 accord ex
- hooking up power door locks and car alarm
- Accord Coupe 6sp vs. TSX vs. CL-S !! Help me choose
- Accord suspension problem?
- 03 accord coupe springs
- Crazy Humming!!!
- Quiet exhaust ?!?!
- EXVL??
- F22 vs. F23 Header
- 98 Accord rear Caliper
- dry vs. wet shot
- jdm h22a motor vs usdm h22a1 head gasket
- 94 EXA Won't start, brake stuck
- Front brake rotors
- A cheap place for OEM parts?
- Interior Question
- Crank bolt wont come off!!!
- trunk springs
- Power Line
- h22a and h22a type-s
- 1998 Honda Accord EX 4-Door Spark Plugs
- Newb questions...
- '92 Accord: super-hot from vents and occasional rumbly engine
- TSX Headlights/5th gen accord?
- MSD-5 Ignition
- 1990 Accord EX, Taking off front brake rotor HELP! PICS
- Timing belt change on 98 Accord EX 4L
- 95 Accord H22 Turbo, got a lil problem...
- 2001 Accord V6 needs brake pads all the way round. Easy?
- 01 accord GEAR light is off? help
- bilstein and cb7
- 91 accord lx help needed!
- fuse diagram
- tornado
- idle
- tweek tranny
- Engine swap for a 1995 Accord
- dumb question
- Question regarding ECU
- Turbo Automatic?????
- Header install question
