View Full Version : Honda Accord (1990 - 2002)
- Injectors.....does it matter?
- Bed squeaking noise from front passenger side
- Stripped Lug Nut safe to drive?
- 4dr 4th generation accord w/h22a???
- clock in dash
- Where can I get an engine for my accord???
- Advice needed: +/-'s of 92-93 Accord EX's
- cool accord commercial
- Accord to Prelude/Integra-R/anything suspension swap?
- Suspension *clunk* ?
- Brembo OEM Brake Rotors
- H22A into 6th Gen Accord 4CYL???
- Seat Help
- Need Advice on Removing RPM Gauge Overlay on 94-97 accord
- ecu code 41
- Can the Idle Air Control Valve be adjusted/reset?
- cold air intake
- Is AEM the only...
- 4-line brake line kit or 6-line brake line kit?
- got a question about a brand in lowering springs?
- honda accord temp problem
- to 6th gen accords...
- cooling problem again
- cooling problem
- intake air bypass system in a 91
- Advanced Timing....*READ*
- modifications for h22 in 4th gen
- UK Accord Commercial
- My '92 Accord has the amazing CRICKET noise coming from the glove box and I can't stop it!!!!
- parking accord in garage
- What is normal operating water temperature?
- im back
- Did I mess up adjusting the valves?
- VTEC Head Swap...93 Accord dx
- im tryin to put the resistor part of my chip into a sensor i have no idea where or what it is
- Halfshaft CV Boot Keeps Ripping HELP!?!?!!
- Just changed my racing springs to sport springs
- faulty alternators
- help with installing gauges?
- SAFC / VAFC results
- where can i get a power antenna???
- 91 Accord.. Radiator fan possessed?
- f22 with 296hp with 6.5lbs of boost???
- Raspy exhaust
- parking brake button?
- Broken Exhaust Manifold Bolt
- turbo like sound between 2.5 and 4.5 rpm on a non turbo 93 lx
- h22 tranny or accord tranny experiences
- sunroof glass replacement
- vafc information, f22b1? archives disabled STILL.
- F22 Boosted???
- How hard is it to screw up t belt install
- Which place to look up for 6th gen CEL codes?
- help! car is hesitating
- need help finding a supercharger
- Problems after installing SPC Ball Joint Camber Kits?
- Clutch Slipping? Help needed...
- Stats on 2003 Accord popularity?
- Need Help, Local. vancouver, wa
- 98-00 exhaust question
- main relay?
- Vtec Engin Valve?
- Accord Lips?
- Higher output lightbulbs for my 95 accord
- Quarter-Mile times for a 95 body coupe accord w/H22, intake & exhaust??
- headwork
- parts from h22 in to f22a
- t-belt trouble? 93 accord
- 96 Header Install
- Older post about Junkyards
- 91 lx broken into
- picture of a 98-2002 manual tranny mount
- Sister just bought an Accord
- Best Place for 5th Gen. JDM headlights?
- All guages stopped working.
- 1157 bulb socket
- idling problems part 2
- 2003 Accord Alignment
- accord car alarm automatic shut off and sound?
- coilover choice
- power steering noise - 92 accord
- short throw people, hows your snychros and tranny feel?
- H22A Power Steering RETURN hose question...
- Adjustable throttle body. What size to choose?
- HT MEET: Bowie Town Center.....Click for Details
- top speed 90 accord LX
- 93 accord-Fried Engine?
- Walbro 255hp intank with everything else w/ fuel system stock??
- Power mirror problem
- Racing Radiator or Regular?
- 6speed 98 Accord V6
- Got my Ported & Polished intake manifold back --Pics inside -=56K beware=-
- ? on replacing fuel pump?
- weighed my beast... !
- ecu symptoms.
- no stereo "Code e"
- first honda
- h22 distributor.... 5G swap
- Turning a 92 Accord LX into 92 Accord Si-R
- ecu numbers....
- Bye-bye Civix EX
- How to install 6 1/2 speakers in 2000 accord
- Ball Joint Camber Kits for 90-97 Acccords
- what size speakers come in a 96 accord ex?
- Whats Your Opinion On SPC Balljoints?
- Tanabe Hyper Medallion
- blinkers in corner lights?
- the green S on my 91 accord stays on , even when the button is not pressed inn.
- What happened to ....
- surging idle
- SRS cell on 94 Acoord
- Water pump help plz!?
- Please Help with Heater blower problem
- f22b2 (non-vtec) to f22b1 (vtec) wiring
- Finally finished my H22a!!!
- removing axles! passernger side wont come out
- '89 LX-I Swap?
- Re: Clutch Is too high (brodsterH22) 7:38 PM 4/4/2003
- problem while driving 94 accord
- Automatic ECU/ Manual ECU(Need Help Quick)
- Where can I get an HID kit or Xenon bulbs for 2003 Accord Coupe?
- I need a 96-97 front bumper ASAP
- Reverse Issue
- PROBLEM STARTING 97 ACCORD LX (Blinking and Clicking)
- Blinker's stopped working
- '92 Accord EX auto - Valve adjust spec??? THX
- Honda Gage
- Little confused about break in period
- my thoughts on AEM pulleys vs. Unorthodox pulleys
- piston question
- F22B1 vs H22A: Torque comparison RPM to RPM
- Suspension Question
- Is there any diffrents in a 90 EX tranny and a 93 LX trany?
- ngk info? the archives are not searchable I looked.
- Oil Leak help
- Cranks, cuts off, cranks, cuts off, cranks, cuts off...
- 92 Accord - Squealing Belt at Cold Startup!
- burn out's only spin left tire?!?
- Clutch Is too high
- 1993 Accord F22A6
- Accord Help
- 89 Accord PA Sensor
- High oil consumption normal for F23? Honda says it's okay
- For Sale F22 A1
- warped rotors
- Time has come to replace oil pan gasket
- Has anybody seen a rear sunshade installed on a Honda?
- did search...nothing found on auto trans prob on 94-97 accord. wont go in gear. help
- 2001 accord 4cyl auto into 92 dx 5spd
- Where to get floor mats.
- Need a under-hood fuse block diagram....
- H22 parts
- in need some muffler help
- Where is the best place to get an OEM parts for accord?
- 99 4 cyl Accord
- fuel pump relay
- AEM's recommended cam gear setting?
- anyone gota spare 90-97 rotor/hub/plate assembly?
- how do you aim the 5th gen's headlights correctly?
- 97 tranny in a 91 trans mount question
- Turbocharger on EX?
- how to remove tint
- Side Airbag light comes on and does not throw a Diagnostic trouble code
- help! huge problem with gf's accord
- 2003 v6 coupe hard to start...
- 3Best Power Steering Fluid For 93 Accord LX
- 5zigen S-08 fit on 6th gen coupe?
- I'm new here, little info:
- uninstall stock radio on a 96 accord.
- Do I need to have the front license plate?
- 93 Accord Dies...Its not the battery help
- 2003 accord grinding brakes
- How much do you think this 93 Accord Sedan w/ H22 is worth?
- accord bolt patter
- clutch question?
- Overheating when the A/C is off
- weird noises at certain rpm
- need some expertise please.
- i have an option with cai and short intake
- 6th Gen Weight Removal?
- front and rear camber kit question
- Excuse the repost... best service guide for 92 Accord EX?
- cel on obd2
- wagon pics
- brakes goin out????
- power lock help!!!
- Washer and bolt to correct camber --> how is it done on a 6th gen Accord?
- Accord Touchup paint question
- Comptech Supercharger
- Question about body damage. Please respond
- Stock Radio Wire Diagram
- Clutch Burned
- Speed Tricks
- H22 Swap and Gas Consumption
- why honda products suck!
- Hack the Honda Navigation System??
- Supercharger on a 99 Accord LX?
- h22A into 98 Accord Coupe 5spd
- light 15x7 wheel....
- AEM Looking for Vehicle for R&D
- H22a crunch time
- Fuel Pump location 93 Accord
- 93 accord DIED!
- Fan question 1986 lxi
- Detach front grill
- Stay with Tanbe's Coilvoers or Koni with Ground Control ?
- question for all of you accord/import owners!
- Do 94-97 shocks/ springs Fit 90-93 accord ?
- Does any one know if the mugen chips poa ecu for 94 accord really work?
- 6gen accord v6 tranny swap
- Observation: Tail-light bulbs prone to burn out on 5th Gen??
- Speedometer doesn't work
- Wrapping Intake
- Accord Turbo Retailers
- accord problem
- Turbo Manifold
- What size rims will fit on my accord???
- I'm redo-ing my headliner, should I dynamat?
- A/C problems
- Which is a better header Ceramic or Stainless Steal??????
- Prelude shocks?
- AEM Test Car Needed
- Can i drive without a thermostat?
- need a pic of prelude si rim on accord
- programming 03 Accord door locks
- Does anyone know how to wire a WATER TEMP to F22a1 ACCORD 93 LX?
- Good, Affordable shocks for stock replacement?
- automatic gear box????
- Selling Accord or not...
- Is it clutch or something else
- dust covers - where to get them?
- 5th gen accords
- Idling
- need help please, gettin frustrated!!!
- what do yall do with the back seat after puting in racing seats?
- MY94 accord vtec F22B1 skematics??
- Odd Electrical Problem, READ!
- trouble installing halfshafts on `93 Accord
- prelude cluster in accord?
- Problems with exterior trim
- DIY: engine mounts>>?? where !?
- Does anyone have pictures of their intercooler??
- Removing the Shifting Cables
- how to remove front brake discs???
- Accord Sedan/Coupe Suspension Products same as Accord Wagon?
- IAB hook up? accord 4thgen
- Weird backfiring sound...
- F20B & H22A
- anyone in here have a 95-97v6
- What's the trick to removing headlight from a 94 accord
