PDA
View Full Version : Honda Accord (1990 - 2002)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 [266] 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372
  1. 89 Accord, crunching noise while turning and accelerating...??
  2. someone stole my wheels...he was a dumb ass
  3. Should I have the injectors cleaned?
  4. OT preparing my car for a road trip.
  5. CEL code socket location?
  6. 92 Accord Brake Light Problems
  7. Second O2 plug..OBD-II..f23....help
  8. Engine vibrates at ~700-800 rpm. disappears when add more gas (~1k rpm). Help!
  9. I just bought a used accord! Was this a good buy? Also "Side Airbag" Light Question
  10. Dynamat Question???
  11. Need some help with a 1994 accord im buying
  12. Will a 6th gen coupe front bumper fit on the sedan?
  13. Anyone parting out a 1998-2002 Accord
  14. check engone light leak in canister
  15. Head Swap on 1997 Honda Accord
  16. 93 accord air bag light on after fixed
  17. Engine Noise
  18. 1992 Honda Ex accelerates to slow
  19. high idle
  20. Problems with tire rubbing..
  21. 93 Drivers side mount problem....
  22. Quick steering wheel upgrade question. MOMO EVO vs. S2000 wheel.
  23. fuses??
  24. so i changed my timing belt
  25. Lowering a '97 Accord with 18's
  26. automatic trans problem
  27. Header and a high flow midpipe?
  28. euro r?
  29. Mounting HIDs in 5th gen V6.
  30. Prokit.....Sportline?
  31. i miss my accord.
  32. WTB 98+ accord v6 engine harness
  33. f22 tranny with h22 motor question
  34. 01 h22 accord ecu jumper harness question
  35. Pls advise on selecting engine mounts.
  36. 1988 Accord LXi... Check Engine Light Codes
  37. 91 Accord EX Possible Transmission Prob?
  38. motor year
  39. 2001 v6 axle nut removal?
  40. buying struts
  41. o2 sensor replacement
  42. K series engine swap Mounts
  43. solenoid help...?
  44. door locks acting weird!!
  45. Honda Accord reminder chime
  46. Engine idling loud?
  47. Problem when applying brakes
  48. 99 Accord w/ FMAX Kit w/ DSM 450's - E-Manage
  49. Urgent: Where is the brake master cylinder located? 6gen
  50. Question re: '99 accord V6....tranny reliability & possibles swaps...
  51. still need help
  52. Accord Knock
  53. 98 accord valve adjustment
  54. 98 4CYL Auto Tranny Probs
  55. side markers
  56. 5spd trans not spinning motor but engaging...
  57. Clutch problem?
  58. how much defferent vtec- non vtec
  59. 95 accord EX EGR problem
  60. '88 Accord LX Timing Belt question about marks
  61. apexi ws2 not fitting 97 se
  62. Need Help In Kansas City with '89 tranny
  63. '88 Accord LXi Tran+Clutch?
  64. Car engine noise sound going to the speakers?? Fixable?
  65. Clutch Alignment Tool?
  66. 89 Accord
  67. vtec swap ?
  68. is this market price for a 96 accord?
  69. 87' LXi Accord engines swap
  70. any pics of kteller system ?
  71. 440cc Injectors too damn big
  72. cat o2 sensor tricks?
  73. Electrical Troubles
  74. Very strange MIL code on 4cyl Accord..
  75. F22 series head shaving/milling, how much?
  76. Possibly buying 1987 Accord LX
  77. short throw shifter help
  78. Cross-reference for Suspension on 1988 LX-i
  79. cb7 trunk leak
  80. EGR Valve\Checkengine light
  81. help my car wont start (not starter)
  82. Suddering/Miss Fire on idle and deceleration?
  83. Oil Filter Size
  84. 1990 Accord Shifting Problem! Help!
  85. Rotor over hub coversion
  86. 1996 honda accord idle problem
  87. Really Weird Problem, PLEASE HELP
  88. What ecu is in the 00' Accord w/ F23? Also, what needs to be done to run a Hondata S200 w/ boost?
  89. 5th gen Wagon owners susp. Q
  90. Dumb question...how do I determine which engine I have?
  91. Code 80 -Exhaust Gas Recirculation on 99 accord
  92. 91 Accord with steering wheel shutter.
  93. flashing maintain light
  94. axles...
  95. 93 accord corner marker light
  96. 98 Accord LX sohc vtec CEL...Cat problem but no solution?
  97. Earn $10 easy
  98. Safely removing power steering?
  99. 1991 honda accord, F22A series head gasket suggestions, need more suggestions!!!
  100. Can you take the tranny "shield" off w/out seperating the tranny?
  101. Need HELP on H&R race springs. Please read! Thanks.
  102. ive searched but no results
  103. NRG engine damper
  104. D4 light blinking and tran making grinding noise check engine light on
  105. 5thgen brake upgrade question
  106. Getting a 1992 Accord LX....have questions
  107. Spark knock!!
  108. Suspension question.
  109. 98LE Headlight Replacement
  110. 5th gen ECU
  111. ne one tell me what causes this.Please Please
  112. 5G rotor conversion
  113. Completed 99 accord turbo! (comments welcome)
  114. changing wheel studs PLEASE HELP!!
  115. 5TH GEN. SUSPENSION QUESTION......
  116. help!!! Motor Wash
  117. 91 Accord leeking coolent and Check oil lights on
  118. TIRE FITTING HELP
  119. Home from Hawaii. My 2000 Accord 4cyl. sounds like a diesel, slightly!
  120. 1991 honda accord, F22A series head gasket suggestions, need help!
  121. new clutch /pedal is super soft ,is it normal ?
  122. does a 96 ex transmission fit a 91-93?
  123. J35 with CL-S heads in a 6th gen Accord.
  124. 2004 accord engine
  125. Would I have to get an alignment done twice after installing springs and two different size wheels?
  126. ecu
  127. Changing ignition switch?
  128. Did My Tranny Go to Honda Heaven
  129. 2000 Accord LX - what grade gas?
  130. pcb ecu pinouts
  131. 94 Accord LX - stereo won't turn on
  132. I have a 92 honda accord ex that shut off can you help me
  133. 03 accord with dsm denso 450cc injectors work???????
  134. Problem w/ starter cranking non-stop when car is off.
  135. h22 into 91 accord problem
  136. 85 Accord camshaft failure...suspected causes?
  137. can you fit a S2000 motor an accord?
  138. Accord Tranny question
  139. 90 Accord EX Swap
  140. shift stuck at park
  141. Girl Here... Need Help!!!!
  142. WTB Misc 1996 Accord LX 4 c yld.automatic parts
  143. 2003-2005 Accord Stock Spring Rates? Other gen spring rates?
  144. Got in a wreck today with my 2004 Accord EX-L. Advice?
  145. Need HELP on H&R race springs. Please read! Thanks.
  146. Need some help Converting from Obd2-Obd1
  147. 95 Accord 4 Door "What rims to get" Rota Circuit 10 or Rota Circuit 8
  148. i took out my interior
  149. D4 or D3?
  150. over heating problem with accord
  151. 98+ accord owners w/ stock cd player in here....
  152. 6th gen accord stereo
  153. general question about gas...
  154. ABS and CHECK ENGINE LIGHT 99 ACCORD
  155. hey i need some help on deciding what to do to my car first
  156. hi, i'm having a problem with the ABS light on. Need Some ADvice/
  157. 1988 honda a20 a1
  158. Turn signal on altezza
  159. Will a 96-97 oem accord front bumper fit on a 95 accord???????
  160. S2000 F22c vs. Accord F22b1
  161. Can you turbocharge a Vtec ULEV?
  162. Shaking on Acceleration w/ new Axles
  163. Do Accord shocks fit civic/integras? Just the top shock mount actually
  164. driver's seat stuck forward
  165. how to reset the ECU?!
  166. Help Installing
  167. How much should i expect to pay?
  168. Best coilover set?? Heared H&R the best.
  169. anyone know hot to take this out?
  170. 1985 holding it's revs during shifts
  171. Need a bit of help with a quick question
  172. 93 Accord with a high Hydrocarbon count. It won't pass emissions in Colorado
  173. Engine Flush - Comments and suggestions.
  174. Power windows go up and down with no key in the ignition
  175. Two situation or problems
  176. Car running like $%!@ '94 Accord Ex Canadian Auto.
  177. Possible Starter or Ignition issue?
  178. Anyone know where to unload two 3.0 V6 Vtec engines??
  179. When will the Accord sedan offer a V6 with a Manual tranny?
  180. CEL Code 7 after Seafoam
  181. Need help assessing this car, should I buy it? H22'd 96 Accord for $2000
  182. Power Steering Fluid
  183. Headlight problem
  184. 95 Accord EX stalled, and won't start again...
  185. good idea to remove power steering?
  186. maintenance light
  187. Shuddering Problem?
  188. 94 Accord Spoon Sporst EPROM Question
  189. Gas Padel (accord 2004)
  190. f22b1 in a 4th gen
  191. Low Fuel Light
  192. led dash conversion kit
  193. Clutch install question (searched)
  194. Stupid Newbie Motor Swap question.
  195. Spark Plugs
  196. 93 DX - installing cruise control?
  197. Gen5 JDM clear corners
  198. 88 ls, cannot hold idle in drive
  199. cold air intake 4th gen
  200. Rear power window does not work!!! PLEASE HELP!!!!
  201. spark plug gap
  202. ?'s about a 90-93 accord
  203. OILS
  204. Anyone attempted EK9 seat install?
  205. Which engines are direct bolt ons to a 1986 Accord?
  206. 6th gen accord, how to run a code.
  207. Hot naked chicks on my accord!
  208. Adding parts for turbo accord h22 engine..
  209. '88 Accord LX Timing Belt/Oil Seals
  210. Engien and trans swpa help needed
  211. Installing TSX seats in '99 Accord EX V6
  212. 91 steering wheel
  213. Auxiliary driving lights on 99 Accord?
  214. dissapearing oil (problem)
  215. transaxle fluid
  216. 94 accord fields sfc/ vtec controller help...
  217. Right hand drive swap?
  218. what the hell
  219. advice: thinking about getting a 98-02 accord.....
  220. DIY headlights. Need help...
  221. ignition switch alarm q?
  222. 95' power door locks (4 dr)
  223. Q about 5 lug swap ????????
  224. 2003 Accord V6 Radio Diagram
  225. HONDA ACCORD COILOVER INSTALLATION
  226. F22A Hybrid
  227. headers ???????
  228. 99 accord f23a1
  229. Car will not start.....Any Ideas???????
  230. headlight setup
  231. aftermarket cd changer
  232. P0420 Catalyst system efficiency below threshold (bank1) o2 or cat?
  233. h22 into 95 accord
  234. headlight lens
  235. Removing scrape by other car
  236. Key trouble Help!
  237. Reset Check Engine Light
  238. h22 accord problem!!!!
  239. 2point6's CB7 Is going even faster...
  240. Lowering springs?
  241. 95 rear wheel hub replacement
  242. Member????
  243. How can you tell if your rims are leaking air??
  244. are 98-02 accord v6's DOHC?
  245. Jet Performance module....worth the money?
  246. Quick Exhaust Removal Parts Question. do I need to buy a Donut??
  247. key wont stay in on position?
  248. Busted engine mount 91Ex
  249. JDM Vigor 1 piece on cb7
  250. Performance Heads
